A docker-compose for every Channels-related extension -- suitable for Portainer-Stacks!
You need to stop and remove the old container first, then pull the latest image and run.
Or let Watchtower update it.
Here's how I update my Portainer (of course you need to use your version of the run statement)
docker stop portainer
docker rm portainer
docker pull portainer/portainer-ce:latest
docker run --detach --env 'TZ=America/Los_Angeles' --name=portainer --restart=always -p 8000:8000 -p 9000:9000 -p 9443:9443 -v /var/run/docker.sock:/var/run/docker.sock -v /volume1/docker/portainer:/data portainer/portainer-ce:latest
Unfortunately, my client names have spaces in them. Is there a way to format the text for the CHANNELS_CLIENTS variable to accommodate that?
The values needed here are the LAN hostnames or IP addresses of your Channels clients -- not the names used in the CDVR server webUI.
The move away from calling it Docker is part of a move by most linux Distros to support other types of Containers, not just Docker Containers.
Just about every Docker Compose in Post #1 here has been updated! If you're using Portainer, make sure you have the latest compose, and have reviewed the sample env var overrides for any that apply to your setup.
