I've had ADBTuner running since close to its inception, but noticed recently that my channels were tuning using a fallback method (Chrome Capture). I found that ADB Tuner was not running in Docker and wasn't listed in the Containers section. I went into "Images" in Docker, saw a turtletank99/adbtuner image that didn't have the green dot next to it, so I selected the "Run" option, leaving the defaults. I still can't access ADB Tuner. Short of a reinstall, is there a way to get this back so I don't lose all my settings/channels? I should note that my installation predates anything like OliveTin, so that was one item I had running outside of OliveTin. Thanks.
ADB Tuner has a config file, so updating and reloading the Docker is easy.
You should be able to delete the docker, update the app, and load the Docker image without losing your ADB tuner settings.
This assumes when you load the Docker that you are pointing to the config file, which shouldn't be an issue if you are using the default commands.
I don't use Olivetin, so can't comment on that.
Did you remember if you used Docker Compose to set this up? If so, you can open a terminal in the directory with the docker-compose.yml file and run these commands to delete the container, download a fresh image, and start a new container without losing your configuration (which would normally be stored in a docker volume).
docker-compose stop
docker-compose rm
docker-compose pull
docker-compose up -d
If ADBTuner fails to start after that, the Docker logs should provide some info we can use to troubleshoot further.
docker-compose logs
If you want to backup your configuration just in case you can download config.db and the two adbkey files in the Volumes tab of Docker Desktop.
Well as a positive, HDR->SDR tone mapping works correctly when using the ATDH dongle with an Onn 4K Pro. So one could actually use it with an SDR television or capture device.
As far as automating this app I’m not going to make any effort in doing so. It doesn’t support deep links, you can’t enter channel numbers, there is no search, it sometimes crashes while loading channels, and as was shown in that video some channels have interactive content that needs to be cleared.
As far as over-the-air TV is concerned, it’s better to just stick with an HDHomeRun and ATSC 1. It works every time lol.
Thanks for the reply. Reading your reply and finding all my setup notes from back when I had first installed ADBTuner got me on track. I did a "cd" command in Terminal (macOS) to go into the directory holding my docker-compose.yml file, and ran the "docker-compose up -d" command. All is working now (to be determined if the problem rears its head again). I did run the logs command, and the log entries were all from when I got it back up and running.
I do have the latest version, I believe. Even though I created this outside of OliveTin and Portainer, the stack does show up in Portainer with Control "Limited", and Watchtower seems to keep it up to date.
The odd thing was that this popped up now, after running with zero issues for months. I'm not sure what the change was. Around the same time, I also noticed a change in Streaming Library Manager, where it dropped Apple TV+ from my streaming services and I lost all those shows until adding it back (I don't think I would have had any reason to have done that, but it's possible a misclick on my part happened somewhere).
Anyone using DirecTV stream? I have two channels (NESN and NESN+) that are both numbered "628". I cannot tune to NESN+ because NESN has 628... I tried 629 and that doesn't work. Any suggestions? It's just this one channel.
Are you saying they both have the same deeplink?
I'm happy to try! Right now it tunes via channel numbers, so I need to research how these deeplinks work to test that
I think you're posting in the wrong thread. The original DTV support in ah4c used channel numbers, but that's been switched to deeplinks now. ADBTuner has always used deeplinks, and last I checked is not compatible with DTV. It sounds like you're using ah4c.
The Walmart Onn HD sticks on sale for about $13. Only 1080p but would be fine for almost any streaming channels.
https://www.walmart.com/ip/2262757145
They make nice spares just in case a future android update messes with ADB functionality. I assume the stick will be stuck on 12 for the rest of its life.
@turtletank I can't figure out why but ADBTuner keeps crashing and seemingly taking docker down with it. One thing I have noticed is that I get tons of keep alive requests. Are those supposed to happen at a set interval? The server it's running on is pretty spec'd out and I can't figure what the issue is
Do you have any docker logs you can share that might help troubleshoot this?
There was an issue with a build a month ago in which some of the image layers were not being updated with a standard pull. I have since reverted that change, but a few people here had to delete their existing container, cached image, and pull a fresh copy to get things back to normal.
2025-04-24 21:59:20.568 | 2025-04-25 01:59:20.567 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:20.626 | 2025-04-25 01:59:20.626 - lib.adb - ADB: Connected.
2025-04-24 21:59:20.627 | 2025-04-25 01:59:20.627 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:20.627 | 2025-04-25 01:59:20.627 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:20.728 | 2025-04-25 01:59:20.728 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:20.788 | 2025-04-25 01:59:20.788 - lib.adb - ADB: Connected.
2025-04-24 21:59:20.788 | 2025-04-25 01:59:20.788 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:20.788 | 2025-04-25 01:59:20.788 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:20.888 | 2025-04-25 01:59:20.888 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:20.928 | 2025-04-25 01:59:20.928 - lib.adb - ADB: Connected.
2025-04-24 21:59:20.928 | 2025-04-25 01:59:20.928 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:20.928 | 2025-04-25 01:59:20.928 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:21.005 | 2025-04-25 01:59:21.005 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:21.054 | 2025-04-25 01:59:21.053 - lib.adb - ADB: Connected.
2025-04-24 21:59:21.054 | 2025-04-25 01:59:21.054 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:21.054 | 2025-04-25 01:59:21.054 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:21.127 | 2025-04-25 01:59:21.127 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:21.188 | 2025-04-25 01:59:21.188 - lib.adb - ADB: Connected.
2025-04-24 21:59:21.188 | 2025-04-25 01:59:21.188 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:21.188 | 2025-04-25 01:59:21.188 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:21.290 | 2025-04-25 01:59:21.290 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:21.344 | 2025-04-25 01:59:21.343 - lib.adb - ADB: Connected.
2025-04-24 21:59:21.344 | 2025-04-25 01:59:21.344 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:21.344 | 2025-04-25 01:59:21.344 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:22.774 | 2025-04-25 01:59:22.774 - server - Tuner: Waiting for playback start. Status: unknown
2025-04-24 21:59:27.018 | 2025-04-25 01:59:27.018 - lib.adb - Failed to get status from media_session.
2025-04-24 21:59:28.624 | 2025-04-25 01:59:28.624 - lib.adb - Failed to get status from media_session.
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Available Tuners:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 1 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 2 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 5 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 6 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 7 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 8 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 9 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 10 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 11 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Name: YTTV 12 Priority:
2025-04-24 21:59:29.847 | 2025-04-25 01:59:29.847 - server - Selecting random tuner
2025-04-24 21:59:29.848 | 2025-04-25 01:59:29.848 - server - Reserved Tuner: Name: YTTV 8 Priority:
2025-04-24 21:59:29.848 | 2025-04-25 01:59:29.848 - server - Using tuner id: 8 for stream.
2025-04-24 21:59:29.848 | 2025-04-25 01:59:29.848 - uvicorn.access - 192.168.65.1:38254 - "GET /stream/37 HTTP/1.1" 307
2025-04-24 21:59:29.851 | 2025-04-25 01:59:29.851 - server - Tuner: Tuning to ESPN2 on YTTV 8
2025-04-24 21:59:29.852 | 2025-04-25 01:59:29.852 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:29.904 | 2025-04-25 01:59:29.903 - lib.adb - ADB: Connected.
2025-04-24 21:59:29.904 | 2025-04-25 01:59:29.903 - lib.adb - ADB: 192.168.1.209 - settings list global
2025-04-24 21:59:30.005 | 2025-04-25 01:59:30.005 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 21:59:30.005 | 2025-04-25 01:59:30.005 - lib.adb - ADB: 192.168.1.209 - dumpsys display
2025-04-24 21:59:30.056 | 2025-04-25 01:59:30.055 - lib.adb - ADB: 192.168.1.209 - getprop ro.build.version.release
2025-04-24 21:59:30.088 | 2025-04-25 01:59:30.088 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 21:59:30.089 | 2025-04-25 01:59:30.089 - lib.adb - ADB: 192.168.1.209 - pm list packages -3
2025-04-24 21:59:30.092 | 2025-04-25 01:59:30.092 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.149 | 2025-04-25 01:59:30.148 - lib.adb - ADB: 192.168.1.209 - pidof com.google.android.youtube.tvunplugged
2025-04-24 21:59:30.152 | 2025-04-25 01:59:30.152 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.152 | 2025-04-25 01:59:30.152 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.152 | 2025-04-25 01:59:30.152 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:30.197 | 2025-04-25 01:59:30.197 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:30.197 | 2025-04-25 01:59:30.197 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:30.244 | 2025-04-25 01:59:30.244 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.287 | 2025-04-25 01:59:30.287 - root - Using https://tv.youtube.com/watch/rV3_bg6VJHs to load channel.
2025-04-24 21:59:30.287 | 2025-04-25 01:59:30.287 - lib.adb - ADB: 192.168.1.209 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/rV3_bg6VJHs" com.google.android.youtube.tvunplugged
2025-04-24 21:59:30.289 | 2025-04-25 01:59:30.289 - lib.adb - Detected 100.0% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 21:59:30.289 | 2025-04-25 01:59:30.289 - server - Tuner: Tuning completed in 11.03 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 21:59:30.289 | 2025-04-25 01:59:30.289 - lib.adb - ADB: Closing connection - 192.168.1.204
2025-04-24 21:59:30.290 | 2025-04-25 01:59:30.290 - uvicorn.access - 192.168.65.1:42406 - "GET /stream/4/110 HTTP/1.1" 200
2025-04-24 21:59:30.299 | 2025-04-25 01:59:30.298 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.300 | 2025-04-25 01:59:30.300 - root - Tuner: Stream open (attempt 1).
2025-04-24 21:59:30.301 | 2025-04-25 01:59:30.301 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.301 | 2025-04-25 01:59:30.301 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:30.403 | 2025-04-25 01:59:30.403 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.419 | 2025-04-25 01:59:30.418 - httpx - HTTP Request: GET http://192.168.1.200/12.ts "HTTP/1.1 200 OK"
2025-04-24 21:59:30.459 | 2025-04-25 01:59:30.458 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.459 | 2025-04-25 01:59:30.459 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.459 | 2025-04-25 01:59:30.459 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:30.539 | 2025-04-25 01:59:30.539 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.587 | 2025-04-25 01:59:30.587 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.587 | 2025-04-25 01:59:30.587 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.587 | 2025-04-25 01:59:30.587 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:30.761 | 2025-04-25 01:59:30.761 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.818 | 2025-04-25 01:59:30.817 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.818 | 2025-04-25 01:59:30.818 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.818 | 2025-04-25 01:59:30.818 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:30.893 | 2025-04-25 01:59:30.893 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:30.946 | 2025-04-25 01:59:30.946 - lib.adb - ADB: Connected.
2025-04-24 21:59:30.947 | 2025-04-25 01:59:30.946 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:30.947 | 2025-04-25 01:59:30.946 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.059 | 2025-04-25 01:59:31.059 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.127 | 2025-04-25 01:59:31.127 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.128 | 2025-04-25 01:59:31.127 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:31.128 | 2025-04-25 01:59:31.128 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.231 | 2025-04-25 01:59:31.231 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.302 | 2025-04-25 01:59:31.302 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.303 | 2025-04-25 01:59:31.302 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:31.303 | 2025-04-25 01:59:31.303 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.414 | 2025-04-25 01:59:31.414 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.479 | 2025-04-25 01:59:31.479 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.480 | 2025-04-25 01:59:31.479 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:31.480 | 2025-04-25 01:59:31.479 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.583 | 2025-04-25 01:59:31.583 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.646 | 2025-04-25 01:59:31.646 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.646 | 2025-04-25 01:59:31.646 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:31.646 | 2025-04-25 01:59:31.646 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.712 | 2025-04-25 01:59:31.712 - server - Available Tuners:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.712 - server - Name: YTTV 1 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.712 - server - Name: YTTV 2 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.712 - server - Name: YTTV 5 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 6 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 7 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 9 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 10 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 11 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Name: YTTV 12 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Selecting random tuner
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Reserved Tuner: Name: YTTV 1 Priority:
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - server - Using tuner id: 1 for stream.
2025-04-24 21:59:31.713 | 2025-04-25 01:59:31.713 - uvicorn.access - 192.168.65.1:64840 - "GET /stream/36 HTTP/1.1" 307
2025-04-24 21:59:31.716 | 2025-04-25 01:59:31.716 - server - Tuner: Tuning to ESPN on YTTV 1
2025-04-24 21:59:31.718 | 2025-04-25 01:59:31.718 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.768 | 2025-04-25 01:59:31.768 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:31.777 | 2025-04-25 01:59:31.777 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.777 | 2025-04-25 01:59:31.777 - lib.adb - ADB: 192.168.1.201 - settings list global
2025-04-24 21:59:31.841 | 2025-04-25 01:59:31.841 - lib.adb - ADB: Connected.
2025-04-24 21:59:31.841 | 2025-04-25 01:59:31.841 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:31.841 | 2025-04-25 01:59:31.841 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:31.872 | 2025-04-25 01:59:31.871 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0, verifier_verify_adb_installs=0
2025-04-24 21:59:31.872 | 2025-04-25 01:59:31.872 - lib.adb - ADB: 192.168.1.201 - dumpsys display
2025-04-24 21:59:31.925 | 2025-04-25 01:59:31.925 - lib.adb - ADB: 192.168.1.201 - getprop ro.build.version.release
2025-04-24 21:59:31.959 | 2025-04-25 01:59:31.959 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 21:59:31.961 | 2025-04-25 01:59:31.960 - lib.adb - ADB: 192.168.1.201 - pm list packages -3
2025-04-24 21:59:31.963 | 2025-04-25 01:59:31.963 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.008 | 2025-04-25 01:59:32.007 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.008 | 2025-04-25 01:59:32.007 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.008 | 2025-04-25 01:59:32.008 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.018 | 2025-04-25 01:59:32.018 - lib.adb - ADB: 192.168.1.201 - pidof com.google.android.youtube.tvunplugged
2025-04-24 21:59:32.074 | 2025-04-25 01:59:32.074 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.075 | 2025-04-25 01:59:32.075 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:32.075 | 2025-04-25 01:59:32.075 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:32.120 | 2025-04-25 01:59:32.119 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.120 | 2025-04-25 01:59:32.120 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.120 | 2025-04-25 01:59:32.120 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.137 | 2025-04-25 01:59:32.136 - root - Using https://tv.youtube.com/watch/pwrdbfRlE_E to load channel.
2025-04-24 21:59:32.137 | 2025-04-25 01:59:32.136 - lib.adb - ADB: 192.168.1.201 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/pwrdbfRlE_E" com.google.android.youtube.tvunplugged
2025-04-24 21:59:32.195 | 2025-04-25 01:59:32.195 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.239 | 2025-04-25 01:59:32.239 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.240 | 2025-04-25 01:59:32.239 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.240 | 2025-04-25 01:59:32.240 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.321 | 2025-04-25 01:59:32.321 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.381 | 2025-04-25 01:59:32.381 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.382 | 2025-04-25 01:59:32.381 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.382 | 2025-04-25 01:59:32.382 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.482 | 2025-04-25 01:59:32.482 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.536 | 2025-04-25 01:59:32.536 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.537 | 2025-04-25 01:59:32.536 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.537 | 2025-04-25 01:59:32.536 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.642 | 2025-04-25 01:59:32.642 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.699 | 2025-04-25 01:59:32.699 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.700 | 2025-04-25 01:59:32.699 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.700 | 2025-04-25 01:59:32.699 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:32.817 | 2025-04-25 01:59:32.816 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:32.868 | 2025-04-25 01:59:32.867 - lib.adb - ADB: Connected.
2025-04-24 21:59:32.868 | 2025-04-25 01:59:32.868 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:32.868 | 2025-04-25 01:59:32.868 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:33.001 | 2025-04-25 01:59:33.000 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:33.042 | 2025-04-25 01:59:33.042 - lib.adb - ADB: Connected.
2025-04-24 21:59:33.042 | 2025-04-25 01:59:33.042 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:33.042 | 2025-04-25 01:59:33.042 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:33.129 | 2025-04-25 01:59:33.129 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:33.171 | 2025-04-25 01:59:33.170 - lib.adb - ADB: Connected.
2025-04-24 21:59:33.171 | 2025-04-25 01:59:33.171 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:33.171 | 2025-04-25 01:59:33.171 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:33.231 | 2025-04-25 01:59:33.231 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:33.289 | 2025-04-25 01:59:33.289 - lib.adb - Detected 99.99% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 21:59:33.290 | 2025-04-25 01:59:33.289 - server - Tuner: Waiting for playback start. Status: playing
2025-04-24 21:59:33.290 | 2025-04-25 01:59:33.289 - server - Tuner: Tuning completed in 3.44 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 21:59:33.290 | 2025-04-25 01:59:33.289 - lib.adb - ADB: Closing connection - 192.168.1.209
2025-04-24 21:59:33.290 | 2025-04-25 01:59:33.290 - uvicorn.access - 192.168.65.1:38254 - "GET /stream/8/37 HTTP/1.1" 200
2025-04-24 21:59:33.295 | 2025-04-25 01:59:33.294 - lib.adb - ADB: Connected.
2025-04-24 21:59:33.295 | 2025-04-25 01:59:33.295 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:33.296 | 2025-04-25 01:59:33.295 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:33.304 | 2025-04-25 01:59:33.304 - root - Tuner: Stream open (attempt 1).
2025-04-24 21:59:33.391 | 2025-04-25 01:59:33.391 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:33.447 | 2025-04-25 01:59:33.445 - httpx - HTTP Request: GET http://192.168.1.205/12.ts "HTTP/1.1 200 OK"
2025-04-24 21:59:33.455 | 2025-04-25 01:59:33.454 - lib.adb - ADB: Connected.
2025-04-24 21:59:33.455 | 2025-04-25 01:59:33.455 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:33.455 | 2025-04-25 01:59:33.455 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:35.588 | 2025-04-25 01:59:35.588 - lib.adb - Detected 100.0% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 21:59:35.589 | 2025-04-25 01:59:35.589 - server - Tuner: Waiting for playback start. Status: playing
2025-04-24 21:59:35.589 | 2025-04-25 01:59:35.589 - server - Tuner: Tuning completed in 3.87 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 21:59:35.589 | 2025-04-25 01:59:35.589 - lib.adb - ADB: Closing connection - 192.168.1.201
2025-04-24 21:59:35.590 | 2025-04-25 01:59:35.590 - uvicorn.access - 192.168.65.1:64840 - "GET /stream/1/36 HTTP/1.1" 200
2025-04-24 21:59:35.601 | 2025-04-25 01:59:35.601 - root - Tuner: Stream open (attempt 1).
2025-04-24 21:59:35.718 | 2025-04-25 01:59:35.717 - httpx - HTTP Request: GET http://192.168.1.200/0.ts "HTTP/1.1 200 OK"
2025-04-24 21:59:55.039 | 2025-04-25 01:59:55.039 - server - Tuner: Playback failed.
2025-04-24 21:59:55.041 | 2025-04-25 01:59:55.041 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:55.042 | 2025-04-25 01:59:55.041 - server - Tuner: Playback failed.
2025-04-24 21:59:55.045 | 2025-04-25 01:59:55.044 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:55.114 | 2025-04-25 01:59:55.114 - lib.adb - ADB: Connected.
2025-04-24 21:59:55.114 | 2025-04-25 01:59:55.114 - lib.adb - ADB: 192.168.1.203 - settings list global
2025-04-24 21:59:55.117 | 2025-04-25 01:59:55.117 - lib.adb - ADB: Connected.
2025-04-24 21:59:55.117 | 2025-04-25 01:59:55.117 - lib.adb - ADB: 192.168.1.204 - settings list global
2025-04-24 21:59:55.190 | 2025-04-25 01:59:55.189 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 21:59:55.190 | 2025-04-25 01:59:55.190 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:55.190 | 2025-04-25 01:59:55.190 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:55.214 | 2025-04-25 01:59:55.213 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 21:59:55.214 | 2025-04-25 01:59:55.213 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:55.214 | 2025-04-25 01:59:55.213 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:55.275 | 2025-04-25 01:59:55.275 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-24 21:59:55.318 | 2025-04-25 01:59:55.317 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-24 21:59:55.376 | 2025-04-25 01:59:55.376 - lib.adb - ADB: Closing connection - 192.168.1.203
2025-04-24 21:59:55.377 | 2025-04-25 01:59:55.376 - server - Released tuner ID: 3
2025-04-24 21:59:55.377 | 2025-04-25 01:59:55.376 - server - Tuner: Cleanup complete. YTTV 3 (TNT)
2025-04-24 21:59:55.377 | 2025-04-25 01:59:55.377 - server - http disconnect
2025-04-24 21:59:55.408 | 2025-04-25 01:59:55.408 - lib.adb - ADB: Closing connection - 192.168.1.204
2025-04-24 21:59:55.409 | 2025-04-25 01:59:55.408 - server - Released tuner ID: 4
2025-04-24 21:59:55.409 | 2025-04-25 01:59:55.408 - server - Tuner: Cleanup complete. YTTV 4 (TRUTVHD)
2025-04-24 21:59:55.410 | 2025-04-25 01:59:55.410 - server - http disconnect
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.717 - server - Available Tuners:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 2 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 3 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 4 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 5 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 6 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 7 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 9 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 10 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 11 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Name: YTTV 12 Priority:
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Selecting random tuner
2025-04-24 21:59:55.718 | 2025-04-25 01:59:55.718 - server - Reserved Tuner: Name: YTTV 5 Priority:
2025-04-24 21:59:55.719 | 2025-04-25 01:59:55.719 - server - Using tuner id: 5 for stream.
2025-04-24 21:59:55.720 | 2025-04-25 01:59:55.719 - uvicorn.access - 192.168.65.1:42406 - "GET /stream/108 HTTP/1.1" 307
2025-04-24 21:59:55.723 | 2025-04-25 01:59:55.723 - server - Tuner: Tuning to TNT on YTTV 5
2025-04-24 21:59:55.725 | 2025-04-25 01:59:55.725 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:55.775 | 2025-04-25 01:59:55.775 - server - Available Tuners:
2025-04-24 21:59:55.775 | 2025-04-25 01:59:55.775 - server - Name: YTTV 2 Priority:
2025-04-24 21:59:55.775 | 2025-04-25 01:59:55.775 - server - Name: YTTV 3 Priority:
2025-04-24 21:59:55.775 | 2025-04-25 01:59:55.775 - server - Name: YTTV 4 Priority:
2025-04-24 21:59:55.775 | 2025-04-25 01:59:55.775 - server - Name: YTTV 6 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.775 - server - Name: YTTV 7 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Name: YTTV 9 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Name: YTTV 10 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Name: YTTV 11 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Name: YTTV 12 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Selecting random tuner
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Reserved Tuner: Name: YTTV 6 Priority:
2025-04-24 21:59:55.776 | 2025-04-25 01:59:55.776 - server - Using tuner id: 6 for stream.
2025-04-24 21:59:55.777 | 2025-04-25 01:59:55.776 - uvicorn.access - 192.168.65.1:47015 - "GET /stream/110 HTTP/1.1" 307
2025-04-24 21:59:55.781 | 2025-04-25 01:59:55.781 - server - Tuner: Tuning to TRUTVHD on YTTV 6
2025-04-24 21:59:55.782 | 2025-04-25 01:59:55.781 - lib.adb - ADB: Connected.
2025-04-24 21:59:55.782 | 2025-04-25 01:59:55.781 - lib.adb - ADB: 192.168.1.206 - settings list global
2025-04-24 21:59:55.787 | 2025-04-25 01:59:55.785 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:55.846 | 2025-04-25 01:59:55.846 - lib.adb - ADB: Connected.
2025-04-24 21:59:55.846 | 2025-04-25 01:59:55.846 - lib.adb - ADB: 192.168.1.207 - settings list global
2025-04-24 21:59:55.887 | 2025-04-25 01:59:55.885 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 21:59:55.891 | 2025-04-25 01:59:55.888 - lib.adb - ADB: 192.168.1.206 - dumpsys display
2025-04-24 21:59:55.919 | 2025-04-25 01:59:55.919 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 21:59:55.919 | 2025-04-25 01:59:55.919 - lib.adb - ADB: 192.168.1.207 - dumpsys display
2025-04-24 21:59:55.940 | 2025-04-25 01:59:55.940 - lib.adb - ADB: 192.168.1.206 - getprop ro.build.version.release
2025-04-24 21:59:55.971 | 2025-04-25 01:59:55.970 - lib.adb - ADB: 192.168.1.207 - getprop ro.build.version.release
2025-04-24 21:59:55.975 | 2025-04-25 01:59:55.975 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 21:59:55.976 | 2025-04-25 01:59:55.976 - lib.adb - ADB: 192.168.1.206 - pm list packages -3
2025-04-24 21:59:55.980 | 2025-04-25 01:59:55.980 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.026 | 2025-04-25 01:59:56.025 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 21:59:56.026 | 2025-04-25 01:59:56.026 - lib.adb - ADB: 192.168.1.207 - pm list packages -3
2025-04-24 21:59:56.029 | 2025-04-25 01:59:56.029 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.030 | 2025-04-25 01:59:56.030 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.030 | 2025-04-25 01:59:56.030 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.030 | 2025-04-25 01:59:56.030 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.036 | 2025-04-25 01:59:56.036 - lib.adb - ADB: 192.168.1.206 - pidof com.google.android.youtube.tvunplugged
2025-04-24 21:59:56.079 | 2025-04-25 01:59:56.078 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.079 | 2025-04-25 01:59:56.079 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.079 | 2025-04-25 01:59:56.079 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.089 | 2025-04-25 01:59:56.085 - lib.adb - ADB: 192.168.1.207 - pidof com.google.android.youtube.tvunplugged
2025-04-24 21:59:56.089 | 2025-04-25 01:59:56.086 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:56.089 | 2025-04-25 01:59:56.086 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:56.106 | 2025-04-25 01:59:56.105 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.149 | 2025-04-25 01:59:56.148 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.149 | 2025-04-25 01:59:56.149 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.149 | 2025-04-25 01:59:56.149 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.151 | 2025-04-25 01:59:56.151 - root - Using https://tv.youtube.com/watch/eJenLQXJcVw to load channel.
2025-04-24 21:59:56.151 | 2025-04-25 01:59:56.151 - lib.adb - ADB: 192.168.1.206 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/eJenLQXJcVw" com.google.android.youtube.tvunplugged
2025-04-24 21:59:56.155 | 2025-04-25 01:59:56.154 - lib.adb - ADB: Stopping media playback.
2025-04-24 21:59:56.155 | 2025-04-25 01:59:56.154 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 21:59:56.172 | 2025-04-25 01:59:56.172 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.224 | 2025-04-25 01:59:56.223 - root - Using https://tv.youtube.com/watch/FhKP3WYUe60 to load channel.
2025-04-24 21:59:56.224 | 2025-04-25 01:59:56.224 - lib.adb - ADB: 192.168.1.207 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/FhKP3WYUe60" com.google.android.youtube.tvunplugged
2025-04-24 21:59:56.225 | 2025-04-25 01:59:56.224 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.227 | 2025-04-25 01:59:56.227 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.228 | 2025-04-25 01:59:56.227 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.229 | 2025-04-25 01:59:56.228 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.281 | 2025-04-25 01:59:56.281 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.282 | 2025-04-25 01:59:56.281 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.282 | 2025-04-25 01:59:56.282 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.301 | 2025-04-25 01:59:56.300 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.354 | 2025-04-25 01:59:56.353 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.354 | 2025-04-25 01:59:56.354 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.354 | 2025-04-25 01:59:56.354 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.440 | 2025-04-25 01:59:56.440 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.489 | 2025-04-25 01:59:56.488 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.489 | 2025-04-25 01:59:56.489 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.491 | 2025-04-25 01:59:56.490 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.491 | 2025-04-25 01:59:56.490 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.538 | 2025-04-25 01:59:56.537 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.538 | 2025-04-25 01:59:56.538 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.538 | 2025-04-25 01:59:56.538 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.593 | 2025-04-25 01:59:56.593 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.640 | 2025-04-25 01:59:56.640 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.641 | 2025-04-25 01:59:56.641 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.642 | 2025-04-25 01:59:56.641 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.642 | 2025-04-25 01:59:56.641 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.691 | 2025-04-25 01:59:56.689 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.691 | 2025-04-25 01:59:56.690 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.691 | 2025-04-25 01:59:56.690 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.729 | 2025-04-25 01:59:56.728 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.792 | 2025-04-25 01:59:56.791 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.797 | 2025-04-25 01:59:56.797 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.798 | 2025-04-25 01:59:56.798 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.798 | 2025-04-25 01:59:56.798 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.849 | 2025-04-25 01:59:56.849 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.849 | 2025-04-25 01:59:56.849 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.849 | 2025-04-25 01:59:56.849 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.900 | 2025-04-25 01:59:56.900 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.942 | 2025-04-25 01:59:56.942 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:56.945 | 2025-04-25 01:59:56.944 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.945 | 2025-04-25 01:59:56.945 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.945 | 2025-04-25 01:59:56.945 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:56.996 | 2025-04-25 01:59:56.995 - lib.adb - ADB: Connected.
2025-04-24 21:59:56.996 | 2025-04-25 01:59:56.996 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:56.996 | 2025-04-25 01:59:56.996 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.020 | 2025-04-25 01:59:57.020 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.064 | 2025-04-25 01:59:57.064 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.065 | 2025-04-25 01:59:57.064 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.065 | 2025-04-25 01:59:57.064 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.070 | 2025-04-25 01:59:57.069 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.118 | 2025-04-25 01:59:57.118 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.119 | 2025-04-25 01:59:57.118 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.119 | 2025-04-25 01:59:57.118 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.195 | 2025-04-25 01:59:57.194 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.238 | 2025-04-25 01:59:57.238 - server - Skipping keep alive tasks as it's currently the top or middle of the hour.
2025-04-24 21:59:57.242 | 2025-04-25 01:59:57.242 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.243 | 2025-04-25 01:59:57.242 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.243 | 2025-04-25 01:59:57.243 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.330 | 2025-04-25 01:59:57.329 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.388 | 2025-04-25 01:59:57.388 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.394 | 2025-04-25 01:59:57.393 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.395 | 2025-04-25 01:59:57.394 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.395 | 2025-04-25 01:59:57.394 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.439 | 2025-04-25 01:59:57.439 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.440 | 2025-04-25 01:59:57.439 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.440 | 2025-04-25 01:59:57.439 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.494 | 2025-04-25 01:59:57.494 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.541 | 2025-04-25 01:59:57.541 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.547 | 2025-04-25 01:59:57.547 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.547 | 2025-04-25 01:59:57.547 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.547 | 2025-04-25 01:59:57.547 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.600 | 2025-04-25 01:59:57.599 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.600 | 2025-04-25 01:59:57.600 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.600 | 2025-04-25 01:59:57.600 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:57.694 | 2025-04-25 01:59:57.694 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 21:59:57.743 | 2025-04-25 01:59:57.742 - lib.adb - ADB: Connected.
2025-04-24 21:59:57.743 | 2025-04-25 01:59:57.743 - lib.adb - ADB: Sending keep alive.
2025-04-24 21:59:57.743 | 2025-04-25 01:59:57.743 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 21:59:58.975 | 2025-04-25 01:59:58.975 - lib.adb - Detected 99.98% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 21:59:58.975 | 2025-04-25 01:59:58.975 - server - Tuner: Waiting for playback start. Status: playing
2025-04-24 21:59:58.975 | 2025-04-25 01:59:58.975 - server - Tuner: Tuning completed in 3.2 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 21:59:58.975 | 2025-04-25 01:59:58.975 - lib.adb - ADB: Closing connection - 192.168.1.207
2025-04-24 21:59:58.976 | 2025-04-25 01:59:58.975 - uvicorn.access - 192.168.65.1:47015 - "GET /stream/6/110 HTTP/1.1" 200
2025-04-24 21:59:58.987 | 2025-04-25 01:59:58.987 - root - Tuner: Stream open (attempt 1).
2025-04-24 21:59:59.103 | 2025-04-25 01:59:59.103 - httpx - HTTP Request: GET http://192.168.1.205/4.ts "HTTP/1.1 200 OK"
2025-04-24 21:59:59.411 | 2025-04-25 01:59:59.410 - lib.adb - Detected 100.0% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 21:59:59.411 | 2025-04-25 01:59:59.410 - server - Tuner: Waiting for playback start. Status: playing
2025-04-24 21:59:59.411 | 2025-04-25 01:59:59.410 - server - Tuner: Tuning completed in 3.69 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 21:59:59.411 | 2025-04-25 01:59:59.411 - lib.adb - ADB: Closing connection - 192.168.1.206
2025-04-24 21:59:59.412 | 2025-04-25 01:59:59.411 - uvicorn.access - 192.168.65.1:42406 - "GET /stream/5/108 HTTP/1.1" 200
2025-04-24 21:59:59.421 | 2025-04-25 01:59:59.420 - root - Tuner: Stream open (attempt 1).
2025-04-24 21:59:59.482 | 2025-04-25 01:59:59.482 - httpx - HTTP Request: GET http://192.168.1.205/0.ts "HTTP/1.1 200 OK"
2025-04-24 22:00:07.790 | 2025-04-25 02:00:07.790 - server - Tuner: Playback failed.
2025-04-24 22:00:07.792 | 2025-04-25 02:00:07.792 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:07.832 | 2025-04-25 02:00:07.831 - server - Tuner: Playback failed.
2025-04-24 22:00:07.836 | 2025-04-25 02:00:07.836 - lib.adb - ADB: Connected.
2025-04-24 22:00:07.836 | 2025-04-25 02:00:07.836 - lib.adb - ADB: 192.168.1.209 - settings list global
2025-04-24 22:00:07.838 | 2025-04-25 02:00:07.838 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:07.895 | 2025-04-25 02:00:07.893 - lib.adb - ADB: Connected.
2025-04-24 22:00:07.896 | 2025-04-25 02:00:07.894 - lib.adb - ADB: 192.168.1.201 - settings list global
2025-04-24 22:00:07.908 | 2025-04-25 02:00:07.907 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 22:00:07.909 | 2025-04-25 02:00:07.908 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:07.909 | 2025-04-25 02:00:07.908 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:07.984 | 2025-04-25 02:00:07.983 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-24 22:00:08.014 | 2025-04-25 02:00:08.014 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0, verifier_verify_adb_installs=0
2025-04-24 22:00:08.014 | 2025-04-25 02:00:08.014 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:08.014 | 2025-04-25 02:00:08.014 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:08.072 | 2025-04-25 02:00:08.072 - lib.adb - ADB: Closing connection - 192.168.1.209
2025-04-24 22:00:08.072 | 2025-04-25 02:00:08.072 - server - Released tuner ID: 8
2025-04-24 22:00:08.072 | 2025-04-25 02:00:08.072 - server - Tuner: Cleanup complete. YTTV 8 (ESPN2)
2025-04-24 22:00:08.073 | 2025-04-25 02:00:08.073 - server - http disconnect
2025-04-24 22:00:08.094 | 2025-04-25 02:00:08.094 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Available Tuners:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 2 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 3 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 4 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 7 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 8 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 9 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 10 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 11 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Name: YTTV 12 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.129 - server - Selecting random tuner
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.130 - server - Reserved Tuner: Name: YTTV 4 Priority:
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.130 - server - Using tuner id: 4 for stream.
2025-04-24 22:00:08.131 | 2025-04-25 02:00:08.130 - uvicorn.access - 192.168.65.1:38254 - "GET /stream/37 HTTP/1.1" 307
2025-04-24 22:00:08.139 | 2025-04-25 02:00:08.138 - server - Tuner: Tuning to ESPN2 on YTTV 4
2025-04-24 22:00:08.142 | 2025-04-25 02:00:08.141 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.200 | 2025-04-25 02:00:08.200 - lib.adb - ADB: Closing connection - 192.168.1.201
2025-04-24 22:00:08.208 | 2025-04-25 02:00:08.206 - server - Released tuner ID: 1
2025-04-24 22:00:08.208 | 2025-04-25 02:00:08.206 - server - Tuner: Cleanup complete. YTTV 1 (ESPN)
2025-04-24 22:00:08.210 | 2025-04-25 02:00:08.209 - server - http disconnect
2025-04-24 22:00:08.212 | 2025-04-25 02:00:08.212 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.213 | 2025-04-25 02:00:08.212 - lib.adb - ADB: 192.168.1.204 - settings list global
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Available Tuners:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 1 Priority:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 2 Priority:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 3 Priority:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 7 Priority:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 8 Priority:
2025-04-24 22:00:08.260 | 2025-04-25 02:00:08.260 - server - Name: YTTV 9 Priority:
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.260 - server - Name: YTTV 10 Priority:
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.260 - server - Name: YTTV 11 Priority:
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.261 - server - Name: YTTV 12 Priority:
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.261 - server - Selecting random tuner
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.261 - server - Reserved Tuner: Name: YTTV 10 Priority:
2025-04-24 22:00:08.261 | 2025-04-25 02:00:08.261 - server - Using tuner id: 10 for stream.
2025-04-24 22:00:08.262 | 2025-04-25 02:00:08.262 - uvicorn.access - 192.168.65.1:64840 - "GET /stream/36 HTTP/1.1" 307
2025-04-24 22:00:08.266 | 2025-04-25 02:00:08.266 - server - Tuner: Tuning to ESPN on YTTV 10
2025-04-24 22:00:08.268 | 2025-04-25 02:00:08.268 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.344 | 2025-04-25 02:00:08.343 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 22:00:08.344 | 2025-04-25 02:00:08.344 - lib.adb - ADB: 192.168.1.204 - dumpsys display
2025-04-24 22:00:08.346 | 2025-04-25 02:00:08.344 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.346 | 2025-04-25 02:00:08.345 - lib.adb - ADB: 192.168.1.212 - settings list global
2025-04-24 22:00:08.396 | 2025-04-25 02:00:08.396 - lib.adb - ADB: 192.168.1.204 - getprop ro.build.version.release
2025-04-24 22:00:08.431 | 2025-04-25 02:00:08.431 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 22:00:08.432 | 2025-04-25 02:00:08.432 - lib.adb - ADB: 192.168.1.204 - pm list packages -3
2025-04-24 22:00:08.437 | 2025-04-25 02:00:08.436 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.481 | 2025-04-25 02:00:08.480 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 22:00:08.481 | 2025-04-25 02:00:08.480 - lib.adb - ADB: 192.168.1.212 - dumpsys display
2025-04-24 22:00:08.489 | 2025-04-25 02:00:08.488 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.491 | 2025-04-25 02:00:08.490 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.491 | 2025-04-25 02:00:08.490 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.492 | 2025-04-25 02:00:08.492 - lib.adb - ADB: 192.168.1.204 - pidof com.google.android.youtube.tvunplugged
2025-04-24 22:00:08.531 | 2025-04-25 02:00:08.531 - lib.adb - ADB: 192.168.1.212 - getprop ro.build.version.release
2025-04-24 22:00:08.547 | 2025-04-25 02:00:08.544 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:08.547 | 2025-04-25 02:00:08.544 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:08.560 | 2025-04-25 02:00:08.559 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.567 | 2025-04-25 02:00:08.567 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 22:00:08.568 | 2025-04-25 02:00:08.568 - lib.adb - ADB: 192.168.1.212 - pm list packages -3
2025-04-24 22:00:08.614 | 2025-04-25 02:00:08.614 - root - Using https://tv.youtube.com/watch/rV3_bg6VJHs to load channel.
2025-04-24 22:00:08.616 | 2025-04-25 02:00:08.615 - lib.adb - ADB: 192.168.1.204 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/rV3_bg6VJHs" com.google.android.youtube.tvunplugged
2025-04-24 22:00:08.618 | 2025-04-25 02:00:08.616 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.623 | 2025-04-25 02:00:08.621 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.623 | 2025-04-25 02:00:08.621 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.625 | 2025-04-25 02:00:08.625 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.676 | 2025-04-25 02:00:08.676 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.676 | 2025-04-25 02:00:08.676 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.676 | 2025-04-25 02:00:08.676 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.693 | 2025-04-25 02:00:08.693 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.760 | 2025-04-25 02:00:08.760 - lib.adb - ADB: 192.168.1.212 - pidof com.google.android.youtube.tvunplugged
2025-04-24 22:00:08.763 | 2025-04-25 02:00:08.763 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.767 | 2025-04-25 02:00:08.766 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.767 | 2025-04-25 02:00:08.767 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.767 | 2025-04-25 02:00:08.767 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.812 | 2025-04-25 02:00:08.811 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.812 | 2025-04-25 02:00:08.812 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.812 | 2025-04-25 02:00:08.812 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.826 | 2025-04-25 02:00:08.826 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:08.826 | 2025-04-25 02:00:08.826 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:08.863 | 2025-04-25 02:00:08.862 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.917 | 2025-04-25 02:00:08.916 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:08.920 | 2025-04-25 02:00:08.917 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.921 | 2025-04-25 02:00:08.919 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.921 | 2025-04-25 02:00:08.919 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:08.929 | 2025-04-25 02:00:08.929 - root - Using https://tv.youtube.com/watch/pwrdbfRlE_E to load channel.
2025-04-24 22:00:08.931 | 2025-04-25 02:00:08.929 - lib.adb - ADB: 192.168.1.212 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/pwrdbfRlE_E" com.google.android.youtube.tvunplugged
2025-04-24 22:00:08.979 | 2025-04-25 02:00:08.978 - lib.adb - ADB: Connected.
2025-04-24 22:00:08.981 | 2025-04-25 02:00:08.980 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:08.982 | 2025-04-25 02:00:08.980 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.006 | 2025-04-25 02:00:09.005 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.061 | 2025-04-25 02:00:09.061 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.064 | 2025-04-25 02:00:09.064 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.068 | 2025-04-25 02:00:09.067 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.068 | 2025-04-25 02:00:09.067 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.114 | 2025-04-25 02:00:09.114 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.115 | 2025-04-25 02:00:09.115 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.115 | 2025-04-25 02:00:09.115 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.149 | 2025-04-25 02:00:09.148 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.217 | 2025-04-25 02:00:09.217 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.217 | 2025-04-25 02:00:09.217 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.222 | 2025-04-25 02:00:09.217 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.227 | 2025-04-25 02:00:09.227 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.279 | 2025-04-25 02:00:09.278 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.279 | 2025-04-25 02:00:09.279 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.279 | 2025-04-25 02:00:09.279 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.333 | 2025-04-25 02:00:09.333 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.382 | 2025-04-25 02:00:09.382 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.384 | 2025-04-25 02:00:09.383 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.384 | 2025-04-25 02:00:09.383 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.384 | 2025-04-25 02:00:09.383 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.438 | 2025-04-25 02:00:09.437 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.438 | 2025-04-25 02:00:09.437 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.438 | 2025-04-25 02:00:09.437 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.449 | 2025-04-25 02:00:09.449 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.498 | 2025-04-25 02:00:09.497 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.498 | 2025-04-25 02:00:09.498 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.498 | 2025-04-25 02:00:09.498 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.522 | 2025-04-25 02:00:09.521 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.588 | 2025-04-25 02:00:09.588 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.592 | 2025-04-25 02:00:09.591 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.592 | 2025-04-25 02:00:09.591 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.592 | 2025-04-25 02:00:09.592 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.654 | 2025-04-25 02:00:09.654 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.657 | 2025-04-25 02:00:09.657 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.657 | 2025-04-25 02:00:09.657 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.687 | 2025-04-25 02:00:09.687 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.749 | 2025-04-25 02:00:09.749 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.749 | 2025-04-25 02:00:09.749 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.749 | 2025-04-25 02:00:09.749 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.768 | 2025-04-25 02:00:09.768 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.833 | 2025-04-25 02:00:09.833 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.834 | 2025-04-25 02:00:09.833 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.834 | 2025-04-25 02:00:09.834 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.852 | 2025-04-25 02:00:09.852 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:09.908 | 2025-04-25 02:00:09.908 - lib.adb - ADB: Connected.
2025-04-24 22:00:09.909 | 2025-04-25 02:00:09.908 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:09.909 | 2025-04-25 02:00:09.908 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:09.936 | 2025-04-25 02:00:09.936 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:10.003 | 2025-04-25 02:00:10.003 - lib.adb - ADB: Connected.
2025-04-24 22:00:10.004 | 2025-04-25 02:00:10.003 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:10.004 | 2025-04-25 02:00:10.003 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:10.014 | 2025-04-25 02:00:10.014 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:10.068 | 2025-04-25 02:00:10.068 - lib.adb - ADB: Connected.
2025-04-24 22:00:10.069 | 2025-04-25 02:00:10.068 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:10.069 | 2025-04-25 02:00:10.069 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:10.164 | 2025-04-25 02:00:10.163 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:10.214 | 2025-04-25 02:00:10.213 - lib.adb - ADB: Connected.
2025-04-24 22:00:10.214 | 2025-04-25 02:00:10.214 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:10.214 | 2025-04-25 02:00:10.214 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:11.616 | 2025-04-25 02:00:11.615 - lib.adb - Detected 99.97% black pixels. Assuming HDCP is active and video is playing.
2025-04-24 22:00:11.616 | 2025-04-25 02:00:11.615 - server - Tuner: Waiting for playback start. Status: playing
2025-04-24 22:00:11.616 | 2025-04-25 02:00:11.616 - server - Tuner: Tuning completed in 3.48 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 22:00:11.616 | 2025-04-25 02:00:11.616 - lib.adb - ADB: Closing connection - 192.168.1.204
2025-04-24 22:00:11.617 | 2025-04-25 02:00:11.616 - uvicorn.access - 192.168.65.1:38254 - "GET /stream/4/37 HTTP/1.1" 200
2025-04-24 22:00:11.625 | 2025-04-25 02:00:11.625 - root - Tuner: Stream open (attempt 1).
2025-04-24 22:00:11.748 | 2025-04-25 02:00:11.747 - httpx - HTTP Request: GET http://192.168.1.200/12.ts "HTTP/1.1 200 OK"
2025-04-24 22:00:11.830 | 2025-04-25 02:00:11.828 - server - Tuner: Waiting for playback start. Status: unknown
2025-04-24 22:00:16.133 | 2025-04-25 02:00:16.133 - lib.adb - Failed to get status from media_session.
2025-04-24 22:00:17.767 | 2025-04-25 02:00:17.767 - lib.adb - Media session playback has started.
2025-04-24 22:00:17.767 | 2025-04-25 02:00:17.767 - server - Tuner: Tuning completed in 9.5 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 22:00:17.767 | 2025-04-25 02:00:17.767 - lib.adb - ADB: Closing connection - 192.168.1.212
2025-04-24 22:00:17.768 | 2025-04-25 02:00:17.768 - uvicorn.access - 192.168.65.1:64840 - "GET /stream/10/36 HTTP/1.1" 200
2025-04-24 22:00:17.781 | 2025-04-25 02:00:17.780 - root - Tuner: Stream open (attempt 1).
2025-04-24 22:00:17.903 | 2025-04-25 02:00:17.903 - httpx - HTTP Request: GET http://192.168.1.210/4.ts "HTTP/1.1 200 OK"
2025-04-24 22:00:17.909 | 2025-04-25 02:00:17.909 - server - http disconnect
2025-04-24 22:00:17.912 | 2025-04-25 02:00:17.912 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:17.967 | 2025-04-25 02:00:17.967 - lib.adb - ADB: Connected.
2025-04-24 22:00:17.967 | 2025-04-25 02:00:17.967 - lib.adb - ADB: 192.168.1.212 - settings list global
2025-04-24 22:00:18.079 | 2025-04-25 02:00:18.079 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 22:00:18.079 | 2025-04-25 02:00:18.079 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:18.079 | 2025-04-25 02:00:18.079 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:18.175 | 2025-04-25 02:00:18.174 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-24 22:00:18.278 | 2025-04-25 02:00:18.277 - lib.adb - ADB: Closing connection - 192.168.1.212
2025-04-24 22:00:18.278 | 2025-04-25 02:00:18.278 - server - Released tuner ID: 10
2025-04-24 22:00:18.279 | 2025-04-25 02:00:18.278 - server - Tuner: Cleanup complete. YTTV 10 (ESPN)
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Available Tuners:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 1 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 2 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 3 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 7 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 8 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 9 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 10 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 11 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Name: YTTV 12 Priority:
2025-04-24 22:00:18.943 | 2025-04-25 02:00:18.943 - server - Selecting random tuner
2025-04-24 22:00:18.944 | 2025-04-25 02:00:18.943 - server - Reserved Tuner: Name: YTTV 9 Priority:
2025-04-24 22:00:18.944 | 2025-04-25 02:00:18.944 - server - Using tuner id: 9 for stream.
2025-04-24 22:00:18.945 | 2025-04-25 02:00:18.944 - uvicorn.access - 192.168.65.1:63314 - "GET /stream/36 HTTP/1.1" 307
2025-04-24 22:00:18.951 | 2025-04-25 02:00:18.951 - server - Tuner: Tuning to ESPN on YTTV 9
2025-04-24 22:00:18.955 | 2025-04-25 02:00:18.955 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.018 | 2025-04-25 02:00:19.018 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.018 | 2025-04-25 02:00:19.018 - lib.adb - ADB: 192.168.1.211 - settings list global
2025-04-24 22:00:19.126 | 2025-04-25 02:00:19.126 - root - adb_allowed_connection_time=0, adb_enabled=1, adb_wifi_enabled=0
2025-04-24 22:00:19.127 | 2025-04-25 02:00:19.126 - lib.adb - ADB: 192.168.1.211 - dumpsys display
2025-04-24 22:00:19.176 | 2025-04-25 02:00:19.176 - lib.adb - ADB: 192.168.1.211 - getprop ro.build.version.release
2025-04-24 22:00:19.210 | 2025-04-25 02:00:19.209 - lib.adb - ADB: Android Version: 12.0.
2025-04-24 22:00:19.211 | 2025-04-25 02:00:19.210 - lib.adb - ADB: 192.168.1.211 - pm list packages -3
2025-04-24 22:00:19.215 | 2025-04-25 02:00:19.214 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.277 | 2025-04-25 02:00:19.277 - lib.adb - ADB: 192.168.1.211 - pidof com.google.android.youtube.tvunplugged
2025-04-24 22:00:19.289 | 2025-04-25 02:00:19.288 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.289 | 2025-04-25 02:00:19.288 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:19.289 | 2025-04-25 02:00:19.288 - lib.adb - ADB: 192.168.1.201 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:19.330 | 2025-04-25 02:00:19.330 - lib.adb - ADB: Stopping media playback.
2025-04-24 22:00:19.330 | 2025-04-25 02:00:19.330 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_MEDIA_STOP
2025-04-24 22:00:19.378 | 2025-04-25 02:00:19.378 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.440 | 2025-04-25 02:00:19.439 - root - Using https://tv.youtube.com/watch/pwrdbfRlE_E to load channel.
2025-04-24 22:00:19.440 | 2025-04-25 02:00:19.439 - lib.adb - ADB: 192.168.1.211 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/pwrdbfRlE_E" com.google.android.youtube.tvunplugged
2025-04-24 22:00:19.457 | 2025-04-25 02:00:19.457 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.458 | 2025-04-25 02:00:19.458 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:19.458 | 2025-04-25 02:00:19.458 - lib.adb - ADB: 192.168.1.202 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:19.564 | 2025-04-25 02:00:19.563 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.624 | 2025-04-25 02:00:19.622 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.624 | 2025-04-25 02:00:19.623 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:19.624 | 2025-04-25 02:00:19.623 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:19.736 | 2025-04-25 02:00:19.735 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.788 | 2025-04-25 02:00:19.787 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.790 | 2025-04-25 02:00:19.789 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:19.792 | 2025-04-25 02:00:19.791 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:19.887 | 2025-04-25 02:00:19.887 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:19.951 | 2025-04-25 02:00:19.950 - lib.adb - ADB: Connected.
2025-04-24 22:00:19.952 | 2025-04-25 02:00:19.952 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:19.952 | 2025-04-25 02:00:19.952 - lib.adb - ADB: 192.168.1.206 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.069 | 2025-04-25 02:00:20.068 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.124 | 2025-04-25 02:00:20.123 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.124 | 2025-04-25 02:00:20.124 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.125 | 2025-04-25 02:00:20.124 - lib.adb - ADB: 192.168.1.207 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.214 | 2025-04-25 02:00:20.214 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.290 | 2025-04-25 02:00:20.288 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.290 | 2025-04-25 02:00:20.288 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.290 | 2025-04-25 02:00:20.288 - lib.adb - ADB: 192.168.1.208 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.385 | 2025-04-25 02:00:20.384 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.441 | 2025-04-25 02:00:20.440 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.442 | 2025-04-25 02:00:20.441 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.442 | 2025-04-25 02:00:20.441 - lib.adb - ADB: 192.168.1.209 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.550 | 2025-04-25 02:00:20.550 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.603 | 2025-04-25 02:00:20.603 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.604 | 2025-04-25 02:00:20.604 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.604 | 2025-04-25 02:00:20.604 - lib.adb - ADB: 192.168.1.212 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.684 | 2025-04-25 02:00:20.684 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.751 | 2025-04-25 02:00:20.751 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.752 | 2025-04-25 02:00:20.751 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.752 | 2025-04-25 02:00:20.751 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:20.857 | 2025-04-25 02:00:20.857 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:00:20.924 | 2025-04-25 02:00:20.923 - lib.adb - ADB: Connected.
2025-04-24 22:00:20.924 | 2025-04-25 02:00:20.924 - lib.adb - ADB: Sending keep alive.
2025-04-24 22:00:20.924 | 2025-04-25 02:00:20.924 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_WAKEUP
2025-04-24 22:00:22.590 | 2025-04-25 02:00:22.589 - server - Tuner: Waiting for playback start. Status: unknown
2025-04-24 22:00:26.895 | 2025-04-25 02:00:26.895 - lib.adb - Failed to get status from media_session.
2025-04-24 22:00:28.637 | 2025-04-25 02:00:28.637 - lib.adb - Media session playback has started.
2025-04-24 22:00:28.638 | 2025-04-25 02:00:28.637 - server - Tuner: Tuning completed in 9.69 seconds. Display was on, application (com.google.android.youtube.tvunplugged) was running.
2025-04-24 22:00:28.638 | 2025-04-25 02:00:28.638 - lib.adb - ADB: Closing connection - 192.168.1.211
2025-04-24 22:00:28.639 | 2025-04-25 02:00:28.639 - uvicorn.access - 192.168.65.1:63314 - "GET /stream/9/36 HTTP/1.1" 200
2025-04-24 22:00:28.651 | 2025-04-25 02:00:28.651 - root - Tuner: Stream open (attempt 1).
2025-04-24 22:00:28.773 | 2025-04-25 02:00:28.773 - httpx - HTTP Request: GET http://192.168.1.210/0.ts "HTTP/1.1 200 OK"
2025-04-24 22:14:37.787 | 2025-04-25 02:14:37.787 - server - Tuner: Playback failed.
2025-04-24 22:14:37.788 | 2025-04-25 02:14:37.788 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:14:37.789 | 2025-04-25 02:14:37.788 - server - Tuner: Playback failed.
2025-04-24 22:14:37.790 | 2025-04-25 02:14:37.790 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:14:37.853 | 2025-04-25 02:14:37.853 - server - Tuner: Playback failed.
2025-04-24 22:14:37.855 | 2025-04-25 02:14:37.855 - lib.adb - ADB: Connecting to device (attempt 1).
2025-04-24 22:14:42.792 | 2025-04-25 02:14:42.792 - lib.adb - timed out
2025-04-24 22:14:42.792 | 2025-04-25 02:14:42.792 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:42.796 | 2025-04-25 02:14:42.795 - lib.adb - timed out
2025-04-24 22:14:42.796 | 2025-04-25 02:14:42.795 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:42.861 | 2025-04-25 02:14:42.860 - lib.adb - timed out
2025-04-24 22:14:42.861 | 2025-04-25 02:14:42.861 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:43.793 | 2025-04-25 02:14:43.792 - lib.adb - ADB: Connecting to device (attempt 2).
2025-04-24 22:14:43.797 | 2025-04-25 02:14:43.796 - lib.adb - ADB: Connecting to device (attempt 2).
2025-04-24 22:14:43.862 | 2025-04-25 02:14:43.861 - lib.adb - ADB: Connecting to device (attempt 2).
2025-04-24 22:14:48.797 | 2025-04-25 02:14:48.796 - lib.adb - timed out
2025-04-24 22:14:48.797 | 2025-04-25 02:14:48.797 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:48.798 | 2025-04-25 02:14:48.797 - lib.adb - timed out
2025-04-24 22:14:48.798 | 2025-04-25 02:14:48.797 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:48.867 | 2025-04-25 02:14:48.866 - lib.adb - timed out
2025-04-24 22:14:48.867 | 2025-04-25 02:14:48.867 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:49.798 | 2025-04-25 02:14:49.797 - lib.adb - ADB: Connecting to device (attempt 3).
2025-04-24 22:14:49.799 | 2025-04-25 02:14:49.798 - lib.adb - ADB: Connecting to device (attempt 3).
2025-04-24 22:14:49.868 | 2025-04-25 02:14:49.867 - lib.adb - ADB: Connecting to device (attempt 3).
2025-04-24 22:14:54.804 | 2025-04-25 02:14:54.803 - lib.adb - timed out
2025-04-24 22:14:54.804 | 2025-04-25 02:14:54.804 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:54.805 | 2025-04-25 02:14:54.804 - lib.adb - timed out
2025-04-24 22:14:54.805 | 2025-04-25 02:14:54.805 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:54.874 | 2025-04-25 02:14:54.873 - lib.adb - timed out
2025-04-24 22:14:54.874 | 2025-04-25 02:14:54.874 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-24 22:14:55.805 | 2025-04-25 02:14:55.804 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-24 22:14:55.806 | 2025-04-25 02:14:55.805 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-24 22:14:55.875 | 2025-04-25 02:14:55.874 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-24 22:15:00.811 | 2025-04-25 02:15:00.810 - lib.adb - timed out
@waltgrace
Thanks for sharing the log information.
ADBTuner itself seems to be running fine, but at the end the log you shared it looks like networking issues? Are you also seeing high CPU usage? Memory consumption?
Admittedly, I didn't test the keep alive feature in an environment with that many tuners. Does the situation improve if you disable that? It runs every 5 minutes and when one channel is tuned the other tuners are woken up just in case they are needed for a channel change.
@turtletank I blew away the container and deleted the image. I rebuilt it with the latest image but with my existing data store. I just ran it again and here are the logs. I am not using the keep alive feature on this deployment of adbtuner
2025-04-25 14:56:09.924 - lib.adb - ADB: Connecting to device (attempt 3).
2025-04-25 14:56:14.905 - lib.adb - timed out
2025-04-25 14:56:14.905 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-25 14:56:14.929 - lib.adb - timed out
2025-04-25 14:56:14.929 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-25 14:56:14.930 - lib.adb - timed out
2025-04-25 14:56:14.930 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-25 14:56:15.906 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-25 14:56:15.930 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-25 14:56:15.931 - lib.adb - ADB: Connecting to device (attempt 4).
2025-04-25 14:56:17.595 - lib.adb - [Errno 113] No route to host
2025-04-25 14:56:17.596 - lib.adb - ADB: Connection failed.
2025-04-25 14:56:17.596 - lib.adb - ADB: Connecting to device (attempt 5).
2025-04-25 14:56:17.596 - lib.adb - [Errno 113] No route to host
2025-04-25 14:56:17.597 - lib.adb - [Errno 113] No route to host
2025-04-25 14:56:17.597 - lib.adb - ADB: Connection failed.
2025-04-25 14:56:17.597 - lib.adb - ADB: Connecting to device (attempt 5).
2025-04-25 14:56:17.598 - lib.adb - ADB: Connecting to device (attempt 5).
2025-04-25 14:56:20.667 - lib.adb - [Errno 113] No route to host
2025-04-25 14:56:20.667 - lib.adb - ADB: Connection failed.
2025-04-25 14:56:20.667 - lib.adb - ADB: 192.168.1.203 - settings list global
2025-04-25 14:56:20.667 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:20.667 - lib.adb - Failed to retrieve current configuration. Will not update Android device configuration.
2025-04-25 14:56:20.667 - lib.adb - ADB: Stopping media playback.
2025-04-25 14:56:20.667 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_MEDIA_STOP
2025-04-25 14:56:20.668 - lib.adb - ADB: 192.168.1.203 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-25 14:56:20.668 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:20.668 - lib.adb - ADB: Closing connection - 192.168.1.203
2025-04-25 14:56:20.668 - server - Released tuner ID: 3
2025-04-25 14:56:20.668 - server - Tuner: Cleanup complete. YTTV 3 (ESPNews)
2025-04-25 14:56:20.668 - server - http disconnect
2025-04-25 14:56:22.603 - lib.adb - timed out
2025-04-25 14:56:22.603 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-25 14:56:22.604 - lib.adb - timed out
2025-04-25 14:56:22.604 - lib.adb - ADB: Connection error. Device may be waking up. Trying again.
2025-04-25 14:56:23.604 - lib.adb - ADB: 192.168.1.204 - settings list global
2025-04-25 14:56:23.604 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:23.604 - lib.adb - ADB: 192.168.1.214 - settings list global
2025-04-25 14:56:23.604 - lib.adb - Failed to retrieve current configuration. Will not update Android device configuration.
2025-04-25 14:56:23.604 - lib.adb - ADB: Stopping media playback.
2025-04-25 14:56:23.604 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_MEDIA_STOP
2025-04-25 14:56:23.605 - lib.adb - ADB: 192.168.1.204 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-25 14:56:23.605 - lib.adb - ADB: Stopping media playback.
2025-04-25 14:56:23.605 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:23.605 - lib.adb - ADB: 192.168.1.211 - settings list global
2025-04-25 14:56:23.605 - lib.adb - ADB: 192.168.1.213 - settings list global
2025-04-25 14:56:23.605 - lib.adb - Failed to retrieve current configuration. Will not update Android device configuration.
2025-04-25 14:56:23.605 - lib.adb - ADB: Closing connection - 192.168.1.204
2025-04-25 14:56:23.605 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_MEDIA_STOP
2025-04-25 14:56:23.606 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_MEDIA_STOP
2025-04-25 14:56:23.606 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:23.606 - lib.adb - ADB: 192.168.1.213 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-25 14:56:23.606 - lib.adb - Failed to retrieve current configuration. Will not update Android device configuration.
2025-04-25 14:56:23.606 - server - Released tuner ID: 4
2025-04-25 14:56:23.607 - lib.adb - ADB: Closing connection - 192.168.1.213
2025-04-25 14:56:23.606 - lib.adb - ADB: 192.168.1.214 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-25 14:56:23.607 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:23.607 - server - Released tuner ID: 11
2025-04-25 14:56:23.606 - lib.adb - ADB: Stopping media playback.
2025-04-25 14:56:23.607 - lib.adb - ADB: Closing connection - 192.168.1.214
2025-04-25 14:56:23.606 - server - Tuner: Cleanup complete. YTTV 4 (ESPN2)
2025-04-25 14:56:23.607 - server - Tuner: Cleanup complete. YTTV 11 (FS1)
2025-04-25 14:56:23.607 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_MEDIA_STOP
2025-04-25 14:56:23.607 - server - Released tuner ID: 12
2025-04-25 14:56:23.608 - server - Tuner: Cleanup complete. YTTV 12 (FS2)
2025-04-25 14:56:23.608 - server - http disconnect
2025-04-25 14:56:23.608 - lib.adb - ADB: 192.168.1.211 - input keyevent KEYCODE_MEDIA_PAUSE
2025-04-25 14:56:23.608 - lib.adb - ADB: Error while running command. Check for approval popup on device.
2025-04-25 14:56:23.609 - lib.adb - ADB: Closing connection - 192.168.1.211
2025-04-25 14:56:23.609 - server - Released tuner ID: 9
2025-04-25 14:56:23.609 - server - Tuner: Cleanup complete. YTTV 9 (ESPN)
2025-04-25 14:56:23.609 - server - http disconnect
@turtletank So networking is my speciality and I've very confused by the no route to host messages. I don't see the chromecasts falling off the network and I setup some monitors for the 12 IPs to see if I see any drops. I know enough about docker to use it but I'm not familiar with troubleshooting the networking inside of it.
side note: I've spun up a new instance with the experimental branch with the keep alive turned on and youtube tv chosen as the application and it seems more stable with all the new features being utilized
Per request, I added a simple status page at http://<adbtuner ip address>:5592/up. This is available in both the stable and experimental releases.
If ADBTuner is running, and all of your android devices/endpoints are connected, it will return a HTTP 200 status, otherwise, 500. This should work well with uptime monitoring/alerting solutions (ex. Uptime Kuma).
A JSON object is included in the response with more specific information.
    "name": "Tuner 1",
    "device_ip_address": "x.x.x.x",
    "device_connected": true,
    "streaming_endpoint": "http://x.x.x.x",
    "streaming_endpoint_connected": true
    "name": "Tuner 2",
@turtletank
INFO  [alembic.runtime.migration] Context impl SQLiteImpl.
INFO  [alembic.runtime.migration] Will assume non-transactional DDL.
  File "/app/server.py", line 37, in <module>
    from lib.utils import IndentedJSONResponse
  File "/app/lib/utils.py", line 2, in <module>
    import orjson
ModuleNotFoundError: No module named 'orjson'
    import orjson
    import orjson
    import orjson
Please let me know what you find. As you suggested, the problem could be in Docker's networking layer, or in the container itself.
There are definitely a few things I did in ADBTuner that might be a problem with that many connected devices. The experimental build uses a more aggressive means of closing streaming proxy connections that may be coincidentally solving your issue. Otherwise, it's basically the same as the stable build.
Thank you so much for the reporting this. A fix has been pushed.
