Additional Storage Locations for Channels DVR Recordings
Pretty sure you are the only three users who will use this feature, so no GUI is planned. The current directory picker code is complicated enough as-is.. :slight_smile:
I have the ā€œRecordingsā€ share from the NAS named WDChannels mounted on the iMac.
IMac-4:~ Debbie$ ls -alh /Volumes/Recordings/TV
total 1077512
drwxrwxrwx 1 Debbie staff 264B Jul 1 00:36 .
drwx------@ 1 Debbie staff 264B Jul 1 01:40 …
-rwxrwxrwx@ 1 Debbie staff 6.0K Jul 1 01:18 .DS_Store
-rwxrwxrwx@ 1 Debbie staff 526M Jun 6 17:00 2017-06-06-1649 House 2012-04-16 S08E17 We Need the Eggs.mpg
drwxrwxrwx 1 Debbie staff 264B Jun 6 16:49 House
IMac-4:~ Debbie$ ls -alh /WDChannels/Recordings/TV
ls: /WDChannels/Recordings/TV: No such file or directory
IMac-4:~ Debbie$ ls -alh /Volumes/WDChannels/Recordings/TV
ls: /Volumes/WDChannels/Recordings/TV: No such file or directory
So what is my path?
P.S.
I won’t normally be running the iMac. The DVR is going to run on either the Qnap or Shield
Sounds like you need to set ExtraPaths to /Volumes/Recordings
So when I add a third disk location, I would have 2 /Volumes/Recordings?
Seems like I should be able to set the name of the actual drive in the path…
macOS uses share name as the path. You can navigate to /Volumes (apple+shift+G) in Finder, or ā€œls -alh /Volumesā€ to see for yourself.
Not running DVR on Mac. Running on Qnap & Shield.
It’s late for both of us…tomorrow I’ll do some more testing :scream:
/Volumes is macOS specific. For other platforms you need to figure out where the recordings directory is and tell Channels that path
Experimented more earlier today, with no luck so far. :cry:
However, if I can get the Shield to record to a mounted network disk…then I already have the path to the attached USB 3, which would then be used for the Extra-Paths statement.
Of course, early yesterday I was trying to make that external connection and botched that up. Gave up and went on to the easy (?) task of adding additional Storage location. :confounded:
Perhaps another user who can figure out how to change Shield recording path to external network mount…will post results :four_leaf_clover:
In the meantime, I’ll continue experimenting.
Thanks so much for adding these capabilities…hopefully, once resolved ā€œno more 3rd party workaroundsā€ :clap:
As stated in Nvidia Shield thread, I was able to fix my error and now have this function working.
I do have one process question:
Since it has been previously recommended that local storage (versus remote) be utilized for DVR, am I correct in assuming that it is VERY preferable to attach two local disks to the Shield (DVR recordings & Extra Path recordings) rather than directing DVR storage to a NAS and attaching one disk locally (Extra Path recordings).
Originally, I was using a mac mini with DVR recordings on a NAS…without any experiencing any connect/disconnect problems.
The Shield has been reliable for DVR recording on local drive, however at times it has been very flaky for network discovery/connection.
I am having a problem setting up certain secondary locations on my NAS: I can easily setup a secondary (storage) location on the the ā€œmainā€ data volume and also the attached USB3 for my NAS, however I haven’t been able to setup a secondary location on a mounted SMB share.
Testing on the Shield, I am able to add a secondary location directly from the Channels DVR share on the Qnap (it is mounted on Shield & also I didn’t have to add a ā€œIMOā€ superfluous ā€œrecordingā€ folder). In several tests, In order to achieve an acceptable transcoding rate >1 I did have to lower the transcoding settings on the DVR from 10mbps to 8 or 6mbps, several tests were OK at Hardware, 10mbps, blend.
I’d really like to be able to add a secondary (tertiary) network storage location without having to mount the drive/share on the DVR device, if possible. IIRC, this is possible on SDDVR, but it’s been a long time (>6 mo) since I tested their offering. I will be glad to retest on SDDVR, if necessary. Just looking for any possible way to circumvent the necessity of mounting network shares to Channels DVR device, as it’s another potential point of failure.
Does the above behaviour comport with current program or am I making an error (entirely possible) in my tests?
The DVR only understands directory paths. It is up to your Operating System to mount network shares at a known path so that the DVR can access them. Implementing various network filesystem protocols inside Channels DVR is way out-of-scope and not going to happen. There’s also no reason to believe that direct access would be any more reliable than via a mount.
Understand completely re: beyond the scope.
Is it theoretically possible to setup a (secondary) path on the Qnap to a network share on another NAS for the Channels DVR. I assume yes, since I can mount an smb share to the Qnap to be available in Qnap’s File Station.
If so, I will continue to investigate the proper path statement to be used on the DVR settings. I just don’t want to waste my time trying to chase the impossible dream. :grin:
Channels DVR does not know or care about network shares. All it wants is the path to a directory where the recordings are stored.
Thank you. :blush:
Still struggling with setting a correct path (on the Qnap settings) to utilize a directory path to add the mounted NAS (Wd My Cloud) as a secondary location…
At this point, I am giving up, unless another user can offer some additional hints…possibly @karlmitchell or @timstephens24. I admit I am a complete neophyte in figuring out correct path syntax, probably it as simple as a prepend of /share or /mnt (neither of which works), but I’m completely stumped.
Finally, after reviewing Plex path and using the directory picker to verify I was able to ascertain the path (hopefully correct).
In my case, it is: /mnt/rf/nd/0/04005d371e2518cd502e1a0baeb791b79ff46823/Recordings
                 However, Channels is not playing the listed file(s):  EDIT:  Fixed it, I think:  My fault
Will do a few more tests.
WooHoo
It’s working fine.
Thanks for your help. This is a fantastic addition for those of us who were out (or nearly out) of disk storage space. Not having to use Plex/MrMC for playback is priceless.
Just wanted to bring this back around and thank you for adding it. I’m using this now for recording on my Mac and then backing everything up to my NAS and deleting them off the limited storage on my Mac.
