Advanced Passes: Multiple CONTAINS/EXCLUDES (prerelease)
I didn’t have a specific expectation because I didn’t realize that the show would be shorter on Saturday than during the week. But I guess I would expect the DVR to be smart enough to not record 0 minutes of a show.
I am thinking this could work in 1 of 2 ways:
  1. The DVR could ignore the padding if the padding time is >= the show time
Or
  1. Rather than setting the padding to subtract from the end of the show, we tell the DRV to only record the first X minutes of the show. If a show is 2 hours, set the DVR to record the first 60 minutes. On days that the show is 60 minutes, would not fail.
Just wanted to say thank you for these new features! I love the end recordings early. You can record the late night show monologues now without the entire program
I hadn't even considered such a use case. Your example got me thinking about Regional broadcasts of our local basketball team. These broadcasts typically include 15-20 minutes of "analysis" prior to the game. Omitting this portion from the recording is quite appealing to me.
The only shortcoming is when the team appears on a National broadcast that does things slightly differently. When that happens, I may end up with a partial recording of the game itself missing the first X minutes of play.
If only we could configure advance passes for a given recording on a per channel basis.
Ahhh! So excited about the new padding features. I have my Grandmother using our Channels DVR and she loves to watch Family Feud, but only the Fast Money so that'll be so great to just be able to record the last five minutes of the bajillion Family Feud airings. Being able to record just the first half hour of the late-night shows, as someone here mentioned, is awesome too and I didn't even think of it. Can't wait to play around with the passes with this, thank you!
Yeah I don't mind about recording all of a show (HD space is cheap!) - What I would love to see is negative padding implemented as a baked in Ad-Skip. (And maybe it's implemented this way right now because it can be, and implementing as an Ad-Skip is a future / separate feature).
For that Basketball example above, that would mean the recording would always come with a 15 minute ad-skip to easily skip the pre-game-analysis. If a broadcast doesn't have that, then you just don't do the ad-skip that time.
The podcast app I use "Overcast" has this, and it's called "Skip Intro" and "Skip Outro" -- maybe instead of being set with the recording, it makes more sense to be set with the playback settings for a show.
I do like the idea of combining with the Ad Skip UI / feature though. That means if you have auto ad-skip enabled the Intro/Outro skip would be automatic. If you like a little more control, then it would be just one additional "click" (two if you had intro and outro set) when you watched those shows.
Sounds like you could do that with two passes.
One gets the Regional airings using whatever channels they air on and starts 15-20 mins late using negative pre-pad.
Another gets the National airings using whatever channels they air on and records the whole airing.
Don't know your specifics, but say...
Regional airings are on channels 10 and 20 and 30.
National airings are on channels 15 and 25 and 35.
Regional pass that starts 15-20 minutes late would have
Whatever SeriesID, Title, etc. to select the show
Start Padding 15 mins after (or custom defined # seconds)
End Padding None
Channel CONTAINS 10
Channel CONTAINS 20
Channel CONTAINS 30
National pass that records whole airing would have
Start Padding None
End Padding None
Channel CONTAINS 15
Channel CONTAINS 25
Channel CONTAINS 35
I thought Channels doesn't support multiple passes for the same recording/show? I could swear that is still a limitation.
You originally posted "If only we could configure advance passes for a given recording on a per channel basis."
Like I said "Don't know your specifics". Since you didn't mention, we don't know.
If it's the same show/title and doesn't air on different channels, my idea won't work.
If it does air on different channels, my examples should work.
If you don't wish to provide specifics, that's fine. I was just offering a suggestion.
@tmm1 Did you have any thoughts on this? In the meantime, I modified the original pass to exclude Saturdays and then created a second pass that would include only Saturdays, with no negative padding. Would these two passes be consolidated into one show in the DVR? Or will I now have the show listed twice since there are two passes?
No, the show would only appear once. They are combined based upon the SeriesID, which would remain the same.
Could we get this described in the advanced pass window please. it was really hard to search for how to use OR's
Agreed, I use advanced passes all the time but I've never really understood all the logic with the combos. It would be awesome if it was on the web page.
Tivo made it very easy with their wishlists because you could set what was or'd and what was and'd when you created one. And they documented it there.
