An easy way for Channels DVR to watch YouTube Live vids
Some of the confusion stems from a different thread where @Steffi_333 had been trying to address an issue with FAR more frequent timeouts (like every few hours.) That thread was closed as it wasn't about Channels DVR. Youtube to m3u - #3 by Stefi_333
Still not about Channels DVR. As you were told by one of the developers and administrator of this forum, this is off-topic, and your questions about other applications belong elsewhere. Please don't get this thread locked too :pray:
Wow, this is awesome! Thanks so much. I'll give it a shot and see how it goes. Super cool, I'm learning a lot from this and appreciate you sharing.
I :heart: The Kister Method.
Nice! It works.
Ok, its not about Channels Dvr, i understand.
I dont get my threat locked, my opinion is that is you.
But ok, i understand, thanks!!!
Any ideas why this request to twit is failing?
2023/02/28 23:52:08.062967 [ERR] Failed to start stream for ch13: M3U: Could not fetch playlist: kister.net: get https://kister.net/mpl/yt2m3u8?w=@twit: 429 Too Many Requests
2023/02/28 23:52:08.166412 [HLS] Couldn't generate stream playlist for ch13-dANY-ip192.168.1.10: M3U: Could not fetch playlist: kister.net: get https://kister.net/mpl/yt2m3u8?w=@twit: 429 Too Many Requests
2023/02/28 23:52:08.166412 [HLS] Stopping transcoder session ch13-dANY-ip192.168.1.10
Just as a data point, I just tested and my TWiT livestream via the Kister Method is working fine. Hmm.
I don't have anything that I can think of that would generate any 429. And I don't relay any error that youtube sends. Do you happen to use a proxy server or VPN ?
25 posts were split to a new topic: TWiT XMLTV guide data
Can we do 4k streams? It seems it tops at 1080p for this video
It should if/when youtube allows 4k streaming to web browers. I think they only allow it to the youtube apps right now.
Still loving the Kister Method, one of my favorite use cases is setting up Channels as a jukebox of some favorite YouTube Live streams (lo-fi music, in this example.) I realize this is a niche case but maybe others are interested to learn from it. And if there's a reason this happens, perhaps it can be addressed. Anyway, when I first set these up as custom channels, everything works perfectly and the display even includes the proper emoji in the descriptions:
Then, I'll notice, some days later, that all emojis are lost and it's just some odd characters in its place.
I'm not sure what triggers it to display properly again, sometimes a reboot, but not always.
Anyway, not a big deal but certainly curious, as it does display nicely at first. And everything else about it works amazingly well, and quickly. Super slick, thanks again @jkister!
Also here is the URL for some of the 24/7 music livestreams included above, for use as the Custom Channel, if it inspires any.
https://kister.net/mpl/yt2m3u8?v=rUxyKA_-grg,c=60005&v=bLlloaA4b4g,c=60006&v=WIU-A596KKU,c=60007&v=@thebootlegboy2,c=60008&v=8YA825ZNAIE,c=60009
Looks like this response header:
Content-Type: application/vnd.apple.mpegurl; charset=ISO-8859-1
It would be preferable if the contents were served up as UTF-8
Fixed!
Wow! Amazing. I’m so grateful. This exchange made my day. Thank you both. Rock stars!
Unfortunately I've noticed this problem has returned, there's unicode characters appearing again. And it's intermittent, sometimes the emoji appear properly, although I can't discern a pattern of when or why. No big deal, not worth spending time debugging. I still recognize these channels by their thumbnails. But just wanted to share in case others find similar issues with emojis in their shows' descriptions in the future.
20 posts were merged into an existing topic: Playlists for YouTube Live channels using the Kister Method
@jkister
Just wanted to say Thanks again for creating and sharing this.
I've been using this and hlstube side by side for four months and when hlstube fails (couple times/month), your method always continues working on the same feed.
@jkister
Do you have a Donation or Buy Me a Coffee link?
Thanks- the likes on this thread are good enough :slight_smile:
Finally got a chance to play with this over the weekend. Very cool stuff!
Because I’m notoriously typo prone, I decided to create an iOS Shortcut that will transform a YouTube Live link into a Kister url and copies it to the Clipboard.
It’s working great for just a basic url without specifying channel or other parameters but I’m thinking of adding that capability. It also occurs to me that that this would probably be possible with a Google Sheet with some formulas (Replace/Substitute) & you could have drop-downs to choose some of the parameters.
