Here's the m3u:
#EXTM3U
#EXTINF:-1 channel-id="9991",TVNZ 1
http://{{ .IPADDRESS }}/play/tuner/1
#EXTINF:-1 channel-id="9992",TVNZ 2
http://{{ .IPADDRESS }}/play/tuner/2
#EXTINF:-1 channel-id="9993",three
http://{{ .IPADDRESS }}/play/tuner/3
#EXTINF:-1 channel-id="9994",Bravo NZ
http://{{ .IPADDRESS }}/play/tuner/4
#EXTINF:-1 channel-id="9995",WHAKAATA MAORI
http://{{ .IPADDRESS }}/play/tuner/5
#EXTINF:-1 channel-id="9996",TVNZ Duke
http://{{ .IPADDRESS }}/play/tuner/6
#EXTINF:-1 channel-id="9997",TVNZ 2+
http://{{ .IPADDRESS }}/play/tuner/7
#EXTINF:-1 channel-id="9998",Eden
http://{{ .IPADDRESS }}/play/tuner/8
#EXTINF:-1 channel-id="9999",Bravo +1
http://{{ .IPADDRESS }}/play/tuner/9
#EXTINF:-1 channel-id="99910",Te Reo
http://{{ .IPADDRESS }}/play/tuner/10
#EXTINF:-1 channel-id="99911",TVNZ 1+
http://{{ .IPADDRESS }}/play/tuner/11
#EXTINF:-1 channel-id="99912",TVNZ Duke +1
http://{{ .IPADDRESS }}/play/tuner/12
#EXTINF:-1 channel-id="99913",three +1
http://{{ .IPADDRESS }}/play/tuner/13
#EXTINF:-1 channel-id="99914",Rush
http://{{ .IPADDRESS }}/play/tuner/14
#EXTINF:-1 channel-id="99915",Sky Open
http://{{ .IPADDRESS }}/play/tuner/15
#EXTINF:-1 channel-id="99918",Eden +1
http://{{ .IPADDRESS }}/play/tuner/18
#EXTINF:-1 channel-id="99919",HGTV NZ
http://{{ .IPADDRESS }}/play/tuner/19
#EXTINF:-1 channel-id="99920",Aljazeera
http://{{ .IPADDRESS }}/play/tuner/20
#EXTINF:-1 channel-id="99921",Sky Open +1
http://{{ .IPADDRESS }}/play/tuner/21
#EXTINF:-1 channel-id="99923",TSN1 NZ
http://{{ .IPADDRESS }}/play/tuner/23
#EXTINF:-1 channel-id="99924",TSN2 NZ
http://{{ .IPADDRESS }}/play/tuner/24
#EXTINF:-1 channel-id="99931",Parliament NZ
http://{{ .IPADDRESS }}/play/tuner/31
#EXTINF:-1 channel-id="99932",A32 Aukland
http://{{ .IPADDRESS }}/play/tuner/32
#EXTINF:-1 channel-id="99933",Channel 33
http://{{ .IPADDRESS }}/play/tuner/33
#EXTINF:-1 channel-id="99938",Juice TV
http://{{ .IPADDRESS }}/play/tuner/38
#EXTINF:-1 channel-id="99941",Wairarapa TV
http://{{ .IPADDRESS }}/play/tuner/41
#EXTINF:-1 channel-id="99948",TV Hawke's Bay
http://{{ .IPADDRESS }}/play/tuner/48
#EXTINF:-1 channel-id="99950",Radio NZ National
http://{{ .IPADDRESS }}/play/tuner/50
#EXTINF:-1 channel-id="99951",Radio NZ Concert
http://{{ .IPADDRESS }}/play/tuner/51
#EXTINF:-1 channel-id="99970",George FM
http://{{ .IPADDRESS }}/play/tuner/70
#EXTINF:-1 channel-id="99971",Radio Aotearoa
http://{{ .IPADDRESS }}/play/tuner/71
#EXTINF:-1 channel-id="999200",CH200
http://{{ .IPADDRESS }}/play/tuner/200
Here's the Channels DVR log:
2024/05/18 09:58:54.990139 [ERR] Failed to start stream for ch9456: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:58:56.033179 [HLS] Couldn't generate stream playlist for ch9456-dANY-ip192.168.1.209: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:58:56.033513 [HLS] Stopping transcoder session ch9456-dANY-ip192.168.1.209 (out=0s finished=false first_seq=0 last_seq=-1)
2024/05/18 09:59:00.987080 [ERR] Failed to start stream for ch9456: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:02.026108 [HLS] Couldn't generate stream playlist for ch9456-dANY-ip192.168.1.209: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:02.026379 [HLS] Stopping transcoder session ch9456-dANY-ip192.168.1.209 (out=0s finished=false first_seq=0 last_seq=-1)
2024/05/18 09:59:07.015191 [ERR] Failed to start stream for ch9456: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:08.047648 [HLS] Couldn't generate stream playlist for ch9456-dANY-ip192.168.1.209: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:08.047936 [HLS] Stopping transcoder session ch9456-dANY-ip192.168.1.209 (out=0s finished=false first_seq=0 last_seq=-1)
2024/05/18 09:59:13.041850 [ERR] Failed to start stream for ch9456: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:14.083922 [HLS] Couldn't generate stream playlist for ch9456-dANY-ip192.168.1.209: M3U: 901 Tuner Unreachable: Timeout after 4s connecting to: http://http://192.168.132.205:7654/play/tuner/2
2024/05/18 09:59:14.084212 [HLS] Stopping transcoder session ch9456-dANY-ip192.168.1.209 (out=0s finished=false first_seq=0 last_seq=-1)
Where would I find the Portainer logs? I don't think you want the Portainer docker log, as the last entry is when I started Portainer in April.
Edit: After posting, I see the double http: bits in the log right above. I'm sure it's operator error somewhere.
