I don't mind hard coding the values for now as doing env variables in a stacks file kind of sucks. I'll add the ports but I cant make out the screenshot unfortunately. I tried zooming in but I just couldn't make it any bigger.
Go into advanced mode in the Environment variables section, and you can copy and paste. It's actually easier than hard coding values.
version: '3.9'
services:
ah4c:
image: bnhf/ah4c:${TAG}
container_name: ah4c
hostname: ah4c
dns_search: ${DOMAIN} # Specify the name of your LAN's domain, usually local or localdomain
ports:
- ${ADBS_PORT}:5037 # Port used by adb-server
- ${HOST_PORT}:7654 # Port used by this ah4c proxy
- ${WSCR_PORT}:8000 # Port used by ws-scrcpy
environment:
- NUMBER_TUNERS=${NUMBER_TUNERS} # Number of tuners you'd like defined 1, 2, 3 or 4 supported
- ENCODER1_URL=${ENCODER1_URL} # Full URL for tuner #1 in the form http://hostname/stream or http://ip/stream
- ENCODER2_URL=${ENCODER2_URL} # Full URL for tuner #2 in the form http://hostname/stream or http://ip/stream
- ENCODER3_URL=${ENCODER3_URL} # Full URL for tuner #3 in the form http://hostname/stream or http://ip/stream
- ENCODER4_URL=${ENCODER4_URL} # Full URL for tuner #4 in the form http://hostname/stream or http://ip/stream
- ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # The domainname:port of the SMTP server you'll be using like smtp.gmail.com:587. This is for sending ah4c alerts if tuning fails.
- ALERT_AUTH_SERVER=${ALERT_AUTH_SERVER} # The auth server for the e-mail you'll be using like smtp.gmail.com
- ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # The e-mail address you'd like your ah4c failure alert e-mails to show as being from.
- ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # Gmail and Yahoo both support the creation of app-specific e-mail passwords, and this is the way to go! It's NOT recommended to use your everyday e-mail password.
- ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # The e-mail address you'd like your alert e-mails sent to.
#- ALERT_WEBHOOK_URL=""
- LIVETV_ATTEMPTS=${LIVETV_ATTEMPTS} # For FireTV Live Guide tuning only, set maximum number of attempts at finding the desired channel
- CREATE_M3US=${CREATE_M3US} # Set to true to create device-specific M3Us for use with Amazon Prime Premium channels -- requires a FireTV device
- UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set to true if you'd like the sample scripts and STREAMER_APP scripts updated whether they exist or not
- UPDATE_M3US=${UPDATE_M3US} # Set to true if you'd like the sample m3us updated whether they exist or not
volumes:
- ${HOST_DIR}/ah4c/scripts:/opt/scripts # pre/stop/bmitune.sh scripts will be stored in this bound host directory under streamer/app
- ${HOST_DIR}/ah4c/m3u:/opt/m3u # m3u files will be stored here and hosted at http://<hostname or ip>:7654/m3u for use in Channels DVR - Custom Channels settings
- ${HOST_DIR}/ah4c/adb:/root/.android # Persistent data directory for adb keys
restart: unless-stopped
TAG=latest
DOMAIN=localdomain
ADBS_PORT=5037
HOST_PORT=7654
WSCR_PORT=7655
IPADDRESS=htpc6:7654
NUMBER_TUNERS=2
TUNER1_IP=firestick-rack1:5555
ENCODER1_URL=http://encoder_48007/0.ts
TUNER2_IP=firestick-rack2:5555
ENCODER2_URL=http://encoder_48007/4.ts
STREAMER_APP=scripts/firetv/directv
CHANNELSIP=media-server6
ALERT_AUTH_SERVER=smtp.gmail.com
[email protected]
ALERT_EMAIL_PASS=xxxxxxxxxxxxxxxx
[email protected]
LIVETV_ATTEMPTS=45
CREATE_M3US=false
UPDATE_SCRIPTS=true
UPDATE_M3US=true
TZ=US/Mountain
HOST_DIR=/data
looks like the only thing I was missing was the port on the end of the ah4c IP. I changed that and restarted the container with the same result. I tried it from curl on the Channels server and same failure.
seth@channelsdvr:~$ curl http://192.168.12.18:8000/play/tuner/17153
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Cannot GET /play/tuner/17153</pre>
</body>
</html>
Unless you added env vars, you don't have any of your ports defined. As you know, the port number you're using on the docker host side is to the left of the colon.
Also, once you get your host side port assignments sorted out, port 8000 is the ws-scrcpy port. ah4c is on 7654.
So what would it look like then?
ports:
- 5037:5037 # Port used by adb-server
- 7654:7654 # Port used by this ah4c proxy
- 8000:8000 # Port used by ws-scrcpy
That would be correct if you're hard coding values.
same error. I dont want you to have to waste any more time. I seem to be the only one having issues getting this to work so the issue has to be me.
Are you sure you're using the right port with curl? Did you miss this post:
I just tried it on my system and I see:
root@htpc6:~# curl http://htpc6:7654/play/tuner/212
Warning: Binary output can mess up your terminal. Use "--output -" to tell
Warning: curl to output it to your terminal anyway, or consider "--output
Warning: <FILE>" to save to a file.
Which seems about right for output, though I haven't ever tried using curl on an ah4c port before.
sure
connected to 192.168.12.177:5555
Existing ./scripts/firetv/directv/prebmitune.sh found, and will be preserved
Existing ./scripts/firetv/directv/bmitune.sh found, and will be preserved
Existing ./scripts/firetv/directv/stopbmitune.sh found, and will be preserved
No existing directv.m3u found or UPDATE_M3US set to true
No existing dtvdeeplinks.m3u found or UPDATE_M3US set to true
No existing dtvosprey.m3u found or UPDATE_M3US set to true
No existing dtvstream.m3u found or UPDATE_M3US set to true
No existing dtvstreamdeeplinks.m3u found or UPDATE_M3US set to true
No existing foo-fighters.m3u found or UPDATE_M3US set to true
No existing fubo.m3u found or UPDATE_M3US set to true
No existing hulu.m3u found or UPDATE_M3US set to true
No existing livetv.m3u found or UPDATE_M3US set to true
No existing nbc.m3u found or UPDATE_M3US set to true
No existing npo.m3u found or UPDATE_M3US set to true
No existing pbs-seatac.m3u found or UPDATE_M3US set to true
No existing pbs-worcester.m3u found or UPDATE_M3US set to true
No existing silicondust.m3u found or UPDATE_M3US set to true
No existing sling.m3u found or UPDATE_M3US set to true
No existing spectrum.m3u found or UPDATE_M3US set to true
No existing xfinity.m3u found or UPDATE_M3US set to true
No existing youtubetv_shield.m3u found or UPDATE_M3US set to true
No existing youtubetv.m3u found or UPDATE_M3US set to true
[START] ah4c is starting
[ENV] Not loading env
[ENV] IPADDRESS 192.168.12.18:7654
[ENV] ALERT_SMTP_SERVER
[ENV] ALERT_AUTH_SERVER
[ENV] ALERT_EMAIL_FROM
[ENV] ALERT_EMAIL_PASS
[ENV] ALERT_EMAIL_TO
[ENV] ALERT_WEBHOOK_URL
[ENV] ALLOW_DEBUG_VIDEO_PREVIEW
[ENV] Creating tuner 1
[ENV] ENCODER1_URL http://192.168.12.16:8090/stream0
[ENV] TUNER1_IP 192.168.12.177:5555
[ENV] CMD1
[ENV] TEECMD1
[ENV] PRE SCRIPT ./scripts/firetv/bbc/prebmitune.sh
[ENV] START SCRIPT ./scripts/firetv/bbc/bmitune.sh
[ENV] STOP SCRIPT ./scripts/firetv/bbc/stopbmitune.sh
[ENV] REBOOT SCRIPT ./scripts/firetv/bbc/reboot.sh
[GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
- using env: export GIN_MODE=release
- using code: gin.SetMode(gin.ReleaseMode)
[GIN-debug] GET /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
[GIN-debug] HEAD /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
[GIN-debug] Loaded HTML Templates (11):
- index.html
- routes.html
- status.html
- stream.html
- edit.html
- logs.html
- m3us.html
- status_and_logs.html
- config.html
- editm3u.html
[GIN-debug] GET /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
[GIN-debug] HEAD /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
[GIN-debug] GET / --> main.run.func1 (2 handlers)
[GIN-debug] GET /routes --> main.run.func2 (2 handlers)
[GIN-debug] GET /play/tuner:tuner/:channel --> main.run.func3 (2 handlers)
[GIN-debug] GET /m3u/:channel --> main.run.func4 (2 handlers)
[GIN-debug] GET /env --> main.run.func5 (2 handlers)
[GIN-debug] GET /logs/text --> main.run.func6 (2 handlers)
[GIN-debug] GET /logs --> main.run.func7 (2 handlers)
[GIN-debug] GET /status/andlogs --> main.run.func8 (2 handlers)
[GIN-debug] GET /logs/json --> main.run.func9 (2 handlers)
[GIN-debug] GET /video --> main.run.func10 (2 handlers)
[GIN-debug] GET /status --> main.statusPageHandler (2 handlers)
[GIN-debug] GET /api/status --> main.apiStatusHandler (2 handlers)
[GIN-debug] GET /stream --> main.run.func11 (2 handlers)
[GIN-debug] GET /test/webhook --> main.run.func12 (2 handlers)
[GIN-debug] GET /test/email --> main.run.func13 (2 handlers)
[GIN-debug] GET /status/channelsactivity --> main.run.func14 (2 handlers)
[GIN-debug] GET /edit --> main.run.func15 (2 handlers)
[GIN-debug] POST /save --> main.run.func16 (2 handlers)
[GIN-debug] POST /m3usave/:file --> main.run.func17 (2 handlers)
[GIN-debug] GET /m3us --> main.run.func18 (2 handlers)
[GIN-debug] GET /editm3u/:file --> main.run.func19 (2 handlers)
[GIN-debug] GET /config --> main.run.func20 (2 handlers)
[GIN-debug] POST /configsave --> main.run.func21 (2 handlers)
[START] ah4c is ready
[GIN-debug] Listening and serving HTTP on :7654
> [email protected] start
> node ./index.js
Listening on:
http://ah4c:8000 http://localhost:8000
http://127.0.0.1:8000 http://192.168.12.18:8000
http://[::1]:8000
[GIN-debug] Request: 172.16.1.11 GET /status/andlogs, latency: 4.11206ms, status: 200
[GIN-debug] Request: 172.16.1.11 GET /favicon.ico, latency: 824.386µs, status: 200
[GIN-debug] Request: 172.16.1.11 GET /logs?notime, latency: 2.421034ms, status: 200
[GIN-debug] Request: 172.16.1.11 GET /status, latency: 4.255339ms, status: 200
You're missing about the first dozen lines of the log, which is part of what I wanted to see.
Regarding what you're trying to do with curl, are you just trying to confirm the port is open?
How about using netcat:
root@htpc6:~# nc -zv htpc6 7654
htpc6.tailxxxxx.ts.net [192.168.110.111] 7654 (?) open
EDIT: If you go to http://192.168.12.18:7654 in your browser you should see this:
And, if you go to http://192.168.12.18:8000 you should see this:
No i was just trying to test the script to see if it would turn the channel properly is that my issue? Its not able to bet tested in that way?
Here are the logs after a reboot:
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
192.168.12.18 ah4c
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
[ENV] CMD1
[ENV] TEECMD1
- index.html
- routes.html
- status.html
- stream.html
- edit.html
- logs.html
- m3us.html
- config.html
- editm3u.html
> node ./index.js
Listening on:
http://[::1]:8000
[STATS] CPU usage: 8.161495702290626%
[STATS] Alloc = 2 MiB
[STATS] TotalAlloc = 47 MiB
[STATS] Sys = 20 MiB
[STATS] NumGC = 39
[STATS] Total memory: 31941 MiB
[STATS] Memory used: 10742 MiB
[STATS] Memory used percent: 33.63025935246027%
[STATS] CPU usage: 6.836631615675354%
[STATS] NumGC = 54
[STATS] Memory used: 10810 MiB
[STATS] Memory used percent: 33.842338300961565%
127.0.0.1 localhost
192.168.12.18 ah4c
[ENV] CMD1
[ENV] TEECMD1
- editm3u.html
- index.html
- routes.html
- stream.html
- config.html
- edit.html
- logs.html
- m3us.html
- status.html
> node ./index.js
Listening on:
http://[::1]:8000
I've never done it that way, and as I posted earlier, when I tried it I got an error regarding binary output to the terminal. Testing with VLC would be much more useful.
Why don't you try these for scripts:
prebmitune.sh:
#!/bin/bash
#prebmitune.sh for firetv/bbc
#Debug on if uncommented
set -x
streamerIP="$1"
streamerNoPort="${streamerIP%%:*}"
adbTarget="adb -s $streamerIP"
mkdir -p $streamerNoPort
#Trap end of script run
finish() {
echo "prebmitune.sh is exiting for $streamerIP with exit code $?"
trap finish EXIT
adbConnect() {
adb connect $streamerIP
local -i adbMaxRetries=3
local -i adbCounter=0
while true; do
$adbTarget shell input keyevent KEYCODE_WAKEUP
local adbEventSuccess=$?
if [[ $adbEventSuccess -eq 0 ]]; then
break
fi
if (($adbCounter > $adbMaxRetries)); then
touch $streamerNoPort/adbCommunicationFail
echo "Communication with $streamerIP failed after $adbMaxRetries retries"
exit 1
fi
sleep 1
((adbCounter++))
done
adbWake() {
packageLaunch="com.clientapp.MainActivity"
packageName="uk.co.bbc.iplayer"
packagePID=$($adbTarget shell pidof $packageName)
if [ ! -z $packagePID ]; then
$adbTarget shell am start -n $packageName/$packageLaunch
echo "Waking $streamerIP"
touch $streamerNoPort/adbAppRunning
else
echo "Starting $packageName on $streamerIP"
fi
main() {
adbConnect
adbWake
main
bmitune.sh:
#!/bin/bash
#bmitune.sh for firetv/bbc
set -x
#Global
channelID=\""$1\""
specialID="$1"
streamerIP="$2"
packageName=uk.co.bbc.iplayer
m3uName="${STREAMER_APP#*/*/}.m3u"
finish() {
echo "bmitune.sh is exiting for $streamerIP with exit code $?"
trap finish EXIT
updateReferenceFiles() {
# Handle cases where stream_stopped or last_channel don't exist
[[ -f "$streamerNoPort/stream_stopped" ]] || echo 0 > "$streamerNoPort/stream_stopped"
[[ -f "$streamerNoPort/last_channel" ]] || echo 0 > "$streamerNoPort/last_channel"
# Write PID for this script to bmitune_pid for use in stopbmitune.sh
echo $$ > "$streamerNoPort/bmitune_pid"
echo "Current PID for this script is $$"
#Set encoderURL based on the value of streamerIP
matchEncoderURL() {
case "$streamerIP" in
"$TUNER1_IP")
encoderURL=$ENCODER1_URL
"$TUNER2_IP")
encoderURL=$ENCODER2_URL
"$TUNER3_IP")
encoderURL=$ENCODER3_URL
"$TUNER4_IP")
encoderURL=$ENCODER4_URL
exit 1
esac
#Check for active audio stream with maxDuration, preTuneAudioCheck, sleepBeforeAudioCheck and sleepAfterAudioCheck as arguments
activeAudioCheck() {
local startTime=$(date +%s)
local maxDuration=$1
local minimumLoudness=-50
local sleepBeforeAudioCheck=$3
local sleepAfterAudioCheck=$4
local preTuneAudioCheck=$2
while true; do
sleep $sleepBeforeAudioCheck
checkLoudness=$(ffmpeg -t 1 -i $encoderURL -filter:a ebur128 -map 0:a -f null -hide_banner - 2>&1 | awk '/I: /{print $2}')
if (( $(date +%s) - $startTime > $maxDuration )); then
echo "Active audio stream not detected in $maxDuration seconds."
if [ $preTuneAudioCheck = "false" ]; then
echo "Active audio stream not detected after tuning completed"
case "$specialID" in
"212")
echo "Possible sports event blackout on NFL Network, so bumping channel up"
$adbTarget shell input keyevent KEYCODE_DPAD_LEFT
exit 1
"213")
echo "Possible sports event blackout on MLB Network, so bumping channel down"
$adbTarget shell input keyevent KEYCODE_DPAD_RIGHT
exit 1
echo "Possible sports event blackout, so bumping channel down"
exit 1
esac
else
exit 1
fi
fi
if (( $(echo "$checkLoudness > $minimumLoudness" | bc -l) )); then
echo "Active audio stream detected with $checkLoudness LUF."
break
fi
echo "Active audio stream not yet detected -- loudness is $checkLoudness LUF. Continuing..."
sleep $sleepAfterAudioCheck
done
#Special channels to kill DirecTV app or reboot FireStick
specialChannels() {
if [ $specialID = "exit" ]; then
echo "Exit $packageName requested on $streamerIP"
rm $streamerNoPort/last_channel $streamerNoPort/adbAppRunning
$adbTarget shell am force-stop $packageName
exit 0
elif [ $specialID = "reboot" ]; then
echo "Reboot $streamerIP requested"
$adbTarget reboot
exit 0
elif [[ -f $streamerNoPort/adbCommunicationFail ]]; then
rm $streamerNoPort/adbCommunicationFail
exit 1
else
echo "Not a special channel (exit nor reboot)"
appFocus=$($adbTarget shell dumpsys window windows | grep -E 'mCurrentFocus' | cut -d '/' -f1 | sed 's/.* //g')
echo "Current app in focus is $appFocus"
fi
#Variable delay based on whether app was running or needed to be launched
#and whether less than maxTime seconds (maxTime/3600 for hours) has passed while sleeping
launchDelay() {
local lastChannel
local lastAwake
local timeNow
local timeElapsed
local maxTime=14400
lastChannel=$(<"$streamerNoPort/last_channel")
lastAwake=$(<"$streamerNoPort/stream_stopped")
timeNow=$(date +%s)
timeElapsed=$(($timeNow - $lastAwake))
if (( $lastChannel == $specialID )) && (( $timeElapsed < $maxTime )); then
echo "Last channel selected on this tuner, no channel change required"
activeAudioCheck 42 true 0 1 # (maxDuration, preTuneAudioCheck, sleepBeforeAudioCheck, sleepAfterAudioCheck)
$adbTarget shell input keyevent KEYCODE_MENU; sleep 2
$adbTarget shell input keyevent KEYCODE_DPAD_CENTER
exit 0
elif [ -f $streamerNoPort/adbAppRunning ] && (( $timeElapsed < $maxTime )); then
#sleep 14
rm $streamerNoPort/adbAppRunning
echo $specialID > "$streamerNoPort/last_channel"
else
#sleep 32
fi
#Tuning is based on channel name values from $m3uName.
tuneChannel() {
"17153")
echo "Tune BBC1"
sleep 3
sleep 1
$adbTarget shell input keyevent KEYCODE_DPAD_DOWN
sleep 1
sleep 1
sleep 1
echo "Invalid channel"
exit 1
esac
main() {
matchEncoderURL
#specialChannels
#launchDelay
#activeAudioCheck 42 true 0 1 # (maxDuration, preTuneAudioCheck, sleepBeforeAudioCheck, sleepAfterAudioCheck)
tuneChannel
#activeAudioCheck 24 false 5 1 # (maxDuration, preTuneAudioCheck, sleepBeforeAudioCheck, sleepAfterAudioCheck)
main
stopbmitune.sh:
#!/bin/bash
#stopbmitune.sh for firetv/bbc
set -x
streamerIP="$1"
#Check if bmitune.sh is done running
bmituneDone() {
bmitunePID=$(<"$streamerNoPort/bmitune_pid")
while ps -p $bmitunePID > /dev/null; do
echo "Waiting for bmitune.sh to complete..."
sleep 2
done
#Stop stream
adbStop() {
#stop="input keyevent KEYCODE_HOME"
stop="am force-stop $packageName"
$adbTarget shell $stop; sleep 2
echo "Streaming stopped for $streamerIP"
#Device sleep
adbSleep() {
sleep="input keyevent KEYCODE_SLEEP"
$adbTarget shell $sleep
echo "Sleep initiated for $streamerIP"
date +%s > $streamerNoPort/stream_stopped
echo "$streamerNoPort/stream_stopped written with epoch stop time"
main() {
bmituneDone
adbStop
adbSleep
main
thanks for doing that. I did try but unfortunately I get the same result. I hate for you to have to spend any more time on this. I'm ok if this just isn't for me. For some reason this is kicking my butt and I still don't have a solid grasp on the inter-workings of this process...
Channels error
2024/09/10 19:51:25.472396 [ERR] Failed to start stream for ch11336: M3U: GET: http://192.168.12.18:8000/play/tuner/17153: 404 Not Found
Logs
[ENV] CMD1
[ENV] TEECMD1
- status.html
- stream.html
- config.html
- edit.html
- editm3u.html
- index.html
- m3us.html
- logs.html
- routes.html
> node ./index.js
Listening on:
http://[::1]:8000
[GIN-debug] Loaded HTML Templates (21):
- xfinity.m3u
- dtvstreamdeeplinks.m3u
- npo.m3u
- pbs-seatac.m3u
- youtubetv_shield.m3u
- bbc.m3u
- dtvosprey.m3u
- fubo.m3u
- youtubetv.m3u
- silicondust.m3u
- spectrum.m3u
- directv.m3u
- hulu.m3u
- livetv.m3u
- pbs-worcester.m3u
- sling.m3u
- dtvdeeplinks.m3u
- dtvstream.m3u
- foo-fighters.m3u
- nbc.m3u
- config.html
- edit.html
- logs.html
- m3us.html
- editm3u.html
- index.html
- routes.html
- status.html
- stream.html
[GIN-debug] Request: 192.168.254.228 GET /m3u/bbc.m3u, latency: 9.653718ms, status: 200
not following closely, but based on your log the 404 is because the url doesn't match any of the GIN-debug lines. it should be /tuner0/ instead of /tuner/
Still no joy
Failed to start stream for ch11336: M3U: GET: http://192.168.12.18:8000/play/tuner0/17153: 404 Not Found
Then it kinda sounds like you're connecting to something else that's running on 8000
Ok...just got my linkpi so I should be set to rock and roll. If I'm able to get sling working, I should be able to share to the class one of my m3us for it
