I can't seem to post the portainer log
This is the AH4C log
Last updated: 3/17/2025, 7:37:59 AM
2025/03/17 07:01:42 [START] ah4c is starting
2025/03/17 07:01:42 [ENV] Not loading env
2025/03/17 07:01:42 [ENV] IPADDRESS 192.168.4.35:7654
2025/03/17 07:01:42 [ENV] ALERT_SMTP_SERVER
2025/03/17 07:01:42 [ENV] ALERT_AUTH_SERVER
2025/03/17 07:01:42 [ENV] ALERT_EMAIL_FROM
2025/03/17 07:01:42 [ENV] ALERT_EMAIL_PASS
2025/03/17 07:01:42 [ENV] ALERT_EMAIL_TO
2025/03/17 07:01:42 [ENV] ALERT_WEBHOOK_URL
2025/03/17 07:01:42 [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2025/03/17 07:01:42 [ENV] Creating tuner 1
2025/03/17 07:01:42 [ENV] ENCODER1_URL http://192.168.4.89:81/ts/1_0
2025/03/17 07:01:42 [ENV] TUNER1_IP 192.168.4.225:5555
2025/03/17 07:01:42 [ENV] CMD1
2025/03/17 07:01:42 [ENV] TEECMD1
2025/03/17 07:01:42 [ENV] PRE SCRIPT ./scripts/firetv/dtvstream/prebmitune.sh
2025/03/17 07:01:42 [ENV] START SCRIPT ./scripts/firetv/dtvstream/bmitune.sh
2025/03/17 07:01:42 [ENV] STOP SCRIPT ./scripts/firetv/dtvstream/stopbmitune.sh
2025/03/17 07:01:42 [ENV] REBOOT SCRIPT ./scripts/firetv/dtvstream/reboot.sh
2025/03/17 07:01:42 [START] ah4c is ready
2025/03/17 07:02:32 [GIN-debug] Request: 172.18.0.1 GET /m3u/dtvstreamdeeplinks.m3u, latency: 12.317959ms, status: 200
2025/03/17 07:03:12 Attempting network tune for device http://192.168.4.89:81/ts/1_0 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428
2025/03/17 07:03:12 [EXECUTE] Running [./scripts/firetv/dtvstream/prebmitune.sh 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428]
2025/03/17 07:03:15 [EXECUTE] Stdout: 'already connected to 192.168.4.225:5555
Starting: Intent { cmp=com.att.tv/com.clientapp.MainActivity }
Starting com.att.tv on 192.168.4.225:5555
prebmitune.sh is exiting for 192.168.4.225:5555 with exit code 0
2025/03/17 07:03:15 [EXECUTE] Stderr: '+ streamerIP=192.168.4.225:5555
+ streamerNoPort=192.168.4.225
+ adbTarget='adb -s 192.168.4.225:5555'
+ mkdir -p 192.168.4.225
+ trap finish EXIT
+ main
+ adbConnect
+ adb connect 192.168.4.225:5555
+ local -i adbMaxRetries=3
+ local -i adbCounter=0
+ true
+ adb -s 192.168.4.225:5555 shell input keyevent KEYCODE_WAKEUP
+ local adbEventSuccess=0
+ [[ 0 -eq 0 ]]
+ break
+ adbWake
+ packageLaunch=com.clientapp.MainActivity
+ packageName=com.att.tv
++ adb -s 192.168.4.225:5555 shell pidof com.att.tv
+ packagePID=
+ '[' '!' -z ']'
+ adb -s 192.168.4.225:5555 shell am start -n com.att.tv/com.clientapp.MainActivity
+ echo 'Starting com.att.tv on 192.168.4.225:5555'
+ finish
+ echo 'prebmitune.sh is exiting for 192.168.4.225:5555 with exit code 0'
2025/03/17 07:03:15 [EXECUTE] Finished running ./scripts/firetv/dtvstream/prebmitune.sh in 2.407720448s
2025/03/17 07:03:15 [EXECUTE] Running [./scripts/firetv/dtvstream/bmitune.sh CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428 192.168.4.225:5555]
2025/03/17 07:03:15 [IOINFO] Successfully copied 25192 bytes
2025/03/17 07:03:15 [IOINFO] Transfer speed: 523.8579207985132 Mbits/second
2025/03/17 07:03:15 Performing Close() for 192.168.4.225:5555
2025/03/17 07:03:15 [EXECUTE] Running [./scripts/firetv/dtvstream/stopbmitune.sh 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428]
2025/03/17 07:04:07 [EXECUTE] Stdout: 'Current PID for this script is 83
Not a special channel (exit nor reboot)
Current app in focus is com.amazon.tv.launcher
Active audio stream not yet detected -- loudness is -70.0 LUF. Continuing...
Active audio stream detected with -36.7 LUF.
Active audio stream detected with -27.4 LUF.
2025/03/17 07:04:07 [EXECUTE] Stderr: '+ channelID='"CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428"'
+ specialID=CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428
+ m3uName=dtvstream.m3u
+ trap finish EXIT
+ main
+ updateReferenceFiles
+ [[ -f 192.168.4.225/stream_stopped ]]
+ echo 0
+ [[ -f 192.168.4.225/last_channel ]]
+ echo 0
+ echo 83
+ echo 'Current PID for this script is 83'
+ matchEncoderURL
+ case "$streamerIP" in
+ encoderURL=http://192.168.4.89:81/ts/1_0
+ specialChannels
+ '[' CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428 = exit ']'
+ '[' CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428 = reboot ']'
+ [[ -f 192.168.4.225/adbCommunicationFail ]]
+ echo 'Not a special channel (exit nor reboot)'
++ grep -E mCurrentFocus
++ adb -s 192.168.4.225:5555 shell dumpsys window windows
++ cut -d / -f1
++ sed 's/.* //g'
+ appFocus=com.amazon.tv.launcher
+ echo 'Current app in focus is com.amazon.tv.launcher'
+ activeAudioCheck 42 true 0 1
++ date +%s
+ local startTime=1742209395
+ local maxDuration=42
+ local minimumLoudness=-50
+ local sleepBeforeAudioCheck=0
+ local sleepAfterAudioCheck=1
+ local preTuneAudioCheck=true
+ true
+ sleep 0
++ awk '/I: /{print $2}'
++ ffmpeg -t 1 -i http://192.168.4.89:81/ts/1_0 -filter:a ebur128 -map 0:a -f null -hide_banner -
+ checkLoudness=-70.0
++ date +%s
+ (( 1742209402 - 1742209395 > 42 ))
++ bc -l
++ echo '-70.0 > -50'
+ (( 0 ))
+ echo 'Active audio stream not yet detected -- loudness is -70.0 LUF. Continuing...'
+ sleep 1
+ true
+ sleep 0
++ date +%s
+ (( 1742209409 - 1742209395 > 42 ))
++ bc -l
+ (( 0 ))
+ sleep 1
+ true
+ sleep 0
++ ffmpeg -t ++ 1 awk '/I: /{print $2}'
+ checkLoudness=-36.7
++ date +%s
+ (( 1742209417 - 1742209395 > 42 ))
++ bc -l
++ echo '-36.7 > -50'
+ (( 1 ))
+ echo 'Active audio stream detected with -36.7 LUF.'
+ break
+ tuneChannel
++ awk -F, '/channel-id="CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428"/ {print $2}' m3u/dtvstream.m3u
+ channelName=
++ sed 's/^/"/;s/$/"/'
++ echo
+ channelName='""'
+ numberOfBackspaces=25
++ (( i=0 ))
++ (( i<25 ))
++ echo -n ' KEYCODE_MEDIA_REWIND'
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
+ clearSearchBackspaces=' KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND'
+ directvMenu='input keyevent KEYCODE_MENU; sleep 6'
+ directvSearch='input keyevent KEYCODE_DPAD_LEFT; input keyevent KEYCODE_DPAD_UP; input keyevent KEYCODE_DPAD_CENTER; sleep 1; input keyevent KEYCODE_DPAD_CENTER; sleep 1'
+ directvClearSearch='input keyevent KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND'
+ directvTune='input keyevent KEYCODE_MEDIA_PLAY_PAUSE; sleep 1; input keyevent KEYCODE_DPAD_DOWN; input keyevent KEYCODE_DPAD_DOWN; input keyevent KEYCODE_DPAD_DOWN; input keyevent KEYCODE_DPAD_CENTER'
+ adb -s 192.168.4.225:5555 shell input keyevent 'KEYCODE_MENU;' sleep 6
+ adb -s 192.168.4.225:5555 shell input keyevent 'KEYCODE_DPAD_LEFT;' input keyevent 'KEYCODE_DPAD_UP;' input keyevent 'KEYCODE_DPAD_CENTER;' sleep '1;' input keyevent 'KEYCODE_DPAD_CENTER;' sleep 1
+ adb -s 192.168.4.225:5555 shell input keyevent KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND KEYCODE_MEDIA_REWIND
+ adb -s 192.168.4.225:5555 shell input text '""'
+ adb -s 192.168.4.225:5555 shell input keyevent 'KEYCODE_MEDIA_PLAY_PAUSE;' sleep '1;' input keyevent 'KEYCODE_DPAD_DOWN;' input keyevent 'KEYCODE_DPAD_DOWN;' input keyevent 'KEYCODE_DPAD_DOWN;' input keyevent KEYCODE_DPAD_CENTER
+ activeAudioCheck 24 false 5 1
++ date +%s
+ local startTime=1742209435
+ local maxDuration=24
+ local sleepBeforeAudioCheck=5
+ local preTuneAudioCheck=false
+ true
+ sleep 5
++ ffmpeg -t 1 -i http://192.168.4.89:81/ts/1_0 ++ awk '/I: /{print $2}'
+ checkLoudness=-27.4
++ date +%s
+ (( 1742209447 - 1742209435 > 24 ))
++ bc -l
++ echo '-27.4 > -50'
+ (( 1 ))
+ echo 'Active audio stream detected with -27.4 LUF.'
+ break
+ finish
+ echo 'bmitune.sh is exiting for 192.168.4.225:5555 with exit code 0'
2025/03/17 07:04:07 [EXECUTE] Finished running ./scripts/firetv/dtvstream/bmitune.sh in 51.841899212s
2025/03/17 07:04:10 [EXECUTE] Stdout: 'Waiting for bmitune.sh to complete...
Streaming stopped for 192.168.4.225:5555
Sleep initiated for 192.168.4.225:5555
192.168.4.225/stream_stopped written with epoch stop time
2025/03/17 07:04:10 [EXECUTE] Stderr: '+ streamerIP=192.168.4.225:5555
+ main
+ bmituneDone
+ bmitunePID=83
+ ps -p 83
+ echo 'Waiting for bmitune.sh to complete...'
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ sleep 2
+ ps -p 83
+ adbStop
+ stop='am force-stop com.att.tv'
+ adb -s 192.168.4.225:5555 shell am force-stop com.att.tv
+ sleep 2
+ echo 'Streaming stopped for 192.168.4.225:5555'
+ adbSleep
+ sleep='input keyevent KEYCODE_SLEEP'
+ adb -s 192.168.4.225:5555 shell input keyevent KEYCODE_SLEEP
+ echo 'Sleep initiated for 192.168.4.225:5555'
+ date +%s
+ echo '192.168.4.225/stream_stopped written with epoch stop time'
2025/03/17 07:04:10 [EXECUTE] Finished running ./scripts/firetv/dtvstream/stopbmitune.sh in 54.982418757s
2025/03/17 07:04:10 [GIN-debug] Request: 172.18.0.1 GET /play/tuner/CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428, latency: 57.412974551s, status: 200
2025/03/17 07:23:29 [START] ah4c is starting
2025/03/17 07:23:29 [ENV] Not loading env
2025/03/17 07:23:29 [ENV] IPADDRESS 192.168.4.35:7654
2025/03/17 07:23:29 [ENV] ALERT_SMTP_SERVER
2025/03/17 07:23:29 [ENV] ALERT_AUTH_SERVER
2025/03/17 07:23:29 [ENV] ALERT_EMAIL_FROM
2025/03/17 07:23:29 [ENV] ALERT_EMAIL_PASS
2025/03/17 07:23:29 [ENV] ALERT_EMAIL_TO
2025/03/17 07:23:29 [ENV] ALERT_WEBHOOK_URL
2025/03/17 07:23:29 [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2025/03/17 07:23:29 [ENV] Creating tuner 1
2025/03/17 07:23:29 [ENV] ENCODER1_URL http://192.168.4.89:81/ts/1_0
2025/03/17 07:23:29 [ENV] TUNER1_IP 192.168.4.225:5555
2025/03/17 07:23:29 [ENV] CMD1
2025/03/17 07:23:29 [ENV] TEECMD1
2025/03/17 07:23:29 [ENV] PRE SCRIPT ./scripts/firetv/dtvstream/prebmitune.sh
2025/03/17 07:23:29 [ENV] START SCRIPT ./scripts/firetv/dtvstream/bmitune.sh
2025/03/17 07:23:29 [ENV] STOP SCRIPT ./scripts/firetv/dtvstream/stopbmitune.sh
2025/03/17 07:23:29 [ENV] REBOOT SCRIPT ./scripts/firetv/dtvstream/reboot.sh
2025/03/17 07:23:29 [START] ah4c is ready
2025/03/17 07:24:05 Attempting network tune for device http://192.168.4.89:81/ts/1_0 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428
2025/03/17 07:24:05 [EXECUTE] Running [./scripts/firetv/dtvstream/prebmitune.sh 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428]
2025/03/17 07:24:07 [EXECUTE] Stdout: 'already connected to 192.168.4.225:5555
2025/03/17 07:24:07 [EXECUTE] Stderr: '+ streamerIP=192.168.4.225:5555
+ trap finish EXIT
+ main
+ adbConnect
+ true
+ [[ 0 -eq 0 ]]
+ break
+ adbWake
+ packagePID=
+ '[' '!' -z ']'
+ finish
2025/03/17 07:24:07 [EXECUTE] Finished running ./scripts/firetv/dtvstream/prebmitune.sh in 1.982134334s
2025/03/17 07:24:07 [EXECUTE] Running [./scripts/firetv/dtvstream/bmitune.sh CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428 192.168.4.225:5555]
2025/03/17 07:24:08 [IOINFO] Successfully copied 23312 bytes
2025/03/17 07:24:08 [IOINFO] Transfer speed: 1.215498096058997 Mbits/second
2025/03/17 07:24:08 Performing Close() for 192.168.4.225:5555
2025/03/17 07:24:08 [EXECUTE] Running [./scripts/firetv/dtvstream/stopbmitune.sh 192.168.4.225:5555 CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428]
2025/03/17 07:25:00 [EXECUTE] Stdout: 'Current PID for this script is 82
Active audio stream detected with -19.2 LUF.
Active audio stream detected with -25.2 LUF.
2025/03/17 07:25:00 [EXECUTE] Stderr: '+ channelID='"CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428"'
+ trap finish EXIT
+ main
+ echo 82
+ echo 'Current PID for this script is 82'
+ matchEncoderURL
+ specialChannels
++ cut -d / ++ grep -E mCurrentFocus
-f1
++ sed 's/.* //g'
++ date +%s
+ local startTime=1742210648
+ true
+ sleep 0
++ date +%s
+ (( 1742210655 - 1742210648 > 42 ))
++ bc -l
+ (( 0 ))
+ sleep 1
+ true
+ sleep 0
++ ffmpeg -t 1 ++ -i awk '/I: /{print $2}'
++ date +%s
+ (( 1742210663 - 1742210648 > 42 ))
++ bc -l
+ (( 0 ))
+ sleep 1
+ true
+ sleep 0
++ ffmpeg -t 1 -i ++ http://192.168.4.89:81/ts/1_0 awk '/I: /{print $2}'
+ checkLoudness=-19.2
++ date +%s
+ (( 1742210670 - 1742210648 > 42 ))
++ bc -l
++ echo '-19.2 > -50'
+ (( 1 ))
+ echo 'Active audio stream detected with -19.2 LUF.'
+ break
+ tuneChannel
+ channelName=
++ echo
+ channelName='""'
++ (( i=0 ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ (( i++ ))
++ (( i<25 ))
++ date +%s
+ local startTime=1742210689
+ true
+ sleep 5
++ ffmpeg -t 1 -i http://192.168.4.89:81/ts/1_0 ++ awk '/I: /{print $2}'-filter:a
+ checkLoudness=-25.2
++ date +%s
+ (( 1742210700 - 1742210689 > 24 ))
++ bc -l
++ echo '-25.2 > -50'
+ (( 1 ))
+ echo 'Active audio stream detected with -25.2 LUF.'
+ break
+ finish
2025/03/17 07:25:00 [EXECUTE] Finished running ./scripts/firetv/dtvstream/bmitune.sh in 53.025984273s
2025/03/17 07:25:05 [EXECUTE] Stdout: 'Waiting for bmitune.sh to complete...
2025/03/17 07:25:05 [EXECUTE] Stderr: '+ streamerIP=192.168.4.225:5555
+ main
+ bmituneDone
+ bmitunePID=82
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ sleep 2
+ ps -p 82
+ adbStop
+ sleep 2
+ adbSleep
+ date +%s
2025/03/17 07:25:05 [EXECUTE] Finished running ./scripts/firetv/dtvstream/stopbmitune.sh in 57.119948552s
2025/03/17 07:25:05 [GIN-debug] Request: 172.18.0.1 GET /play/tuner/CNNHD~d3603aea-f5d8-e789-786c-43c5e8799428, latency: 59.264167527s, status: 200
2025/03/17 07:37:51 [GIN-debug] Request: 172.18.0.1 GET /logs, latency: 177.545794ms, status: 200
