What did you end up moving to?
YouTubeTV. Seems good so far. DTV was good too, but after 15 years it seemed like time to try something new.
Still trying but I'll get it.
With a time set for 3 hrs, should I see an Adb command in the log, whether it be a keypad or a resend of the deeplinks?
My recollection is, yes you should see it in the logs. But to confirm, you could set the KEEP_WATCHING value temporarily to something like 5m (which is 5 minutes), and then verify it's working visually.
Also for real-world testing of a 4h value, assuming you have OliveTin-for-Channels installed, you can setup long manual recordings of 5 or 6 hours overnight. And then, in the morning confirm it worked in the recording by fast forwarding past the 4 hour mark.
EDIT: Or, if you don't have OliveTin, pick a long movie and add a couple of hours of padding to the end.
It's summer again (almost), more free time to muck about. I
have been trying to figure out how to get ah4c to have a unified m3u play list with different sources (YouTube tv, sling, Hulu, etc). Booted up my back up server and Managed to come with something but could do with some help to make it better. This is what I have working so far with some pay per view channels from YouTube tv and from the HBO max app combined into one m3u.
I am not using the docker version, to be clear.
Sample of "masterppv_contentid.txt" :
501 hbo a903ca8a-6d5e-559b-a027-f82997397694/452e5d78-1cca-59a9-8508-21b25d813874
502 hbo2 0326bb1d-35a8-5e10-a73e-52f75a74dce2/9aa33f8e-4e7e-53e6-843c-370732e42960
503 hbosig a4c770bb-eeab-5236-bad0-c4e3bdcfb67c/b7622186-b110-58be-922f-a42a2dafe29e
506 hbocom 300dbdc3-db0a-513c-8b25-2341eb00c469/0e95ada4-129a-5759-9d8a-d04ac349223b
509 hbozone 5c541620-277c-53fc-9197-763e16d93e4d/aca066fb-98bb-576b-b86a-3d4afed7fb8e
835 showmhd KAQmQyFLRes?onboard=1
836 shofmhd JZjBftgl8WY?onboard=1
837 sho2hd igHq_WgPO8A?utm?onboard=1
838 shonext WkNYP-Sa8qQ?onboard=1
842 stzhd -Y5vv28gO_I?onboard=1
843 stzedge 0aFRvqZJMw8?onboard=1
844 stzhdw Dpm6GnzDtdI?onboard=1
845 stzblk XT6u3OnJWgs?onboard=1
846 stzkds&fam O7ROqxJ8g5I?onboard=1
847 stzcomdedy qsx6OIn4b8M?onboard=1
848 stzcinema Rjr3Yp9kSWc?onboard=1
852 univkids Atjp6gLhvmo?onboard=1
Sample of "masterppv.m3u" :
#EXTM3U
#EXTINF:-1 channel-id="501" tvc-guide-stationid="" tvg-group="" tvg-logo="",HBO
http://{{ .IPADDRESS }}:7654/play/tuner/501
#EXTINF:-1 channel-id="502" tvc-guide-stationid="" tvg-group="" tvg-logo="",HBO2
http://{{ .IPADDRESS }}:7654/play/tuner/502
#EXTINF:-1 channel-id="503" tvc-guide-stationid="" tvg-group="" tvg-logo="",HBOSIG
http://{{ .IPADDRESS }}:7654/play/tuner/503
#EXTINF:-1 channel-id="506" tvc-guide-stationid="" tvg-group="" tvg-logo="",HBOCOM
http://{{ .IPADDRESS }}:7654/play/tuner/506
#EXTINF:-1 channel-id="509" tvc-guide-stationid="" tvg-group="" tvg-logo="",HBOZONE
http://{{ .IPADDRESS }}:7654/play/tuner/509
#EXTINF:-1 channel-id="206" tvc-guide-stationid="67237" tvg-group="" tvg-logo="",SZENHP
http://{{ .IPADDRESS }}:7654/play/tuner/206
#EXTINF:-1 channel-id="800" tvc-guide-stationid="36225" tvg-group="" tvg-logo="",STZENHD
http://{{ .IPADDRESS }}:7654/play/tuner/800
#EXTINF:-1 channel-id="801" tvc-guide-stationid="83404" tvg-group="" tvg-logo="",SZECLHD
http://{{ .IPADDRESS }}:7654/play/tuner/801
#EXTINF:-1 channel-id="830" tvc-guide-stationid="21868" tvg-group="" tvg-logo="",SHOHD
http://{{ .IPADDRESS }}:7654/play/tuner/830
#EXTINF:-1 channel-id="831" tvc-guide-stationid="22532" tvg-group="" tvg-logo="",SHOHDP
http://{{ .IPADDRESS }}:7654/play/tuner/831
#EXTINF:-1 channel-id="832" tvc-guide-stationid="68340" tvg-group="" tvg-logo="",SHOxBET
http://{{ .IPADDRESS }}:7654/play/tuner/832
#EXTINF:-1 channel-id="833" tvc-guide-stationid="60947" tvg-group="" tvg-logo="",SHOXHD
http://{{ .IPADDRESS }}:7654/play/tuner/833
#EXTINF:-1 channel-id="834" tvc-guide-stationid="61001" tvg-group="" tvg-logo="",SHOCSHD
http://{{ .IPADDRESS }}:7654/play/tuner/834
#EXTINF:-1 channel-id="835" tvc-guide-stationid="68338" tvg-group="" tvg-logo="",SHOWMHD
http://{{ .IPADDRESS }}:7654/play/tuner/835
"bmitune.sh" with edits to make it work with master list as it stands. :
#!/bin/bash
echo "$1" > /tmp/temp.txt
echo "$2" >> /tmp/temp.txt
echo "$3" >> /tmp/temp.txt
STATION="$1"
TUNERIP="$2"
CONTENT_FILE="contentid.txt"
CONTENT_ID=""
URL=""
PROVIDER=""
STATUS="notplaying"
ADBSTATUS=""
PID=""
RESULT=""
EXE=""
ISPKG=""
WHICH_PROVIDER=""
APP_NAME="com.google.android.apps.youtube.tvunplugged.activity.MainActivity"
APP_LAUNCH="com.google.android.youtube.tvunplugged"
content_file="masterppv_contentid.txt"
content_id=""
#Make Sure adb is up and connected
#sh /home/moisebuntu/Scripts/startadb.sh
if (( 500 <= $1 && $1 <= 509 ));then
echo "Yes"
else
echo "No"
fi
#Read content_id from file
if [ -f "$content_file" ]; then
content_id=$(grep -w "^$1" "$content_file" | cut -d " " -f3)
fi
#Check if content_id is empty
if [ -z "$content_id" ]; then
echo "Invalid option or content_id not found in $content_file"
exit 1
fi
adb -s $2 shell "am start -a android.intent.action.VIEW -d https://play.max.com/channel/watch/"$content_id""
adb -s $2 shell "input keyevent 22; input keyevent 66"
else
adb -s $TUNERIP shell "am start -a android.intent.action.VIEW -d https://tv.youtube.com/watch/"$content_id"" -n $APP_LAUNCH/$APP_NAME
fi
So if the channels is in the 500 range and thus HBO according to the guide data I am using then the script triggers the HBO Max app. If it is anything above that then it will trigger YouTube tv.
I was wondering though if it would be better to add a column for provider (youtubetv, sling, Hulu, hbomax etc) in the contentid.txt file and then have the script check the number selected when tuning against that data field and launching the relevant app based on this. A line from the contentid.txt would in that case look like this:
836 shofmhd youtubetv JZjBftgl8WY?onboard=1
And that third block would trigger the relevant app via the appropriate adb command.
Anyway, any help with making this better will be appreciated.
Rather than having an additional data file to maintain, I'd suggest having the values you need passed to the script embedded in the M3U's URL. I'm already doing this in a couple of cases where an additional value is needed for tuning. The idea is to use a separator character that's very unlikely to be part of a channel's unique identifier -- to date, I've been using the tilde (~). I'd suggest an M3U that looks like this in your case:
#EXTM3U
http://{{ .IPADDRESS }}/play/tuner/hbomax~a903ca8a-6d5e-559b-a027-f82997397694/452e5d78-1cca-59a9-8508-21b25d813874
http://{{ .IPADDRESS }}/play/tuner/youtubetv~KAQmQyFLRes
Note that I'm also suggesting you remove the hardcoded port after $IPADDRESS, and instead include the port in the $IPADDRESS value.
In bmitune.sh, you can parse these values similar to this:
contentID=$(echo $1 | awk -F~ '{print $2}')
appName=$(echo $1 | awk -F~ '{print $1}')
streamerIP="$2"
adbTarget="adb -s $streamerIP"
Then if you're using Bash functions, you could have a tuning function for each appName, like:
hbomaxTuneChannel() {
packageName=play.max.com
packageAction=android.intent.action.VIEW
$adbTarget shell am start -a $packageAction -d https://"$packageName"/channel/watch/"$contentID"
$adbTarget shell "input keyevent KEYCODE_DPAD_RIGHT; input keyevent KEYCODE_ENTER"
youtubetvTuneChannel() {
packageName=tv.youtube.com
packageLaunch=com.google.android.youtube.tvunplugged
packageTarget=com.google.android.apps.youtube.tvunplugged.activity.MainActivity
$adbTarget shell am start -a $packageAction -d https://"$packageName"/watch/"$contentID" -n $packageLaunch/$packageTarget
main() {
eval "${appName}TuneChannel"
main
Having the M3U be the one and only data source I think is advantageous, especially given the M3U editor that's part ah4c. Also, by writing everything in function form, whatever is specific to tuning for a particular app can be included in its function. This keeps the script very readable, even if it grew to include many apps.
Any way to tune using deep links with osprey box? I have the resource ID and callsign. NESN and NESN PLUS channels are identical channel numbers.
No way tune with deep links I have found for DirecTV channels.
Review posts 312-334 of this thread. They demonstrate how it was handled when the Olympics were using the sub-channels of the USA channel.
It might give you some ideas on how to accomplish your task.
Haven’t given up on the "Keep Watching" screen on dtvstream on Firestick yet but am moving that to my test NAS after I get OliveTin installed there.
I did pick up an Osprey device and installed that on my main server. I edited the m3u to add an additional channel that I wanted. Plan to fully edit the m3u adding all of my desired channels then lock it down.
Everything is working as expected. Tuning takes about 11-12 secs and it plays forever (9+hrs).
Anybody using the USA Network android app? I am trying to figure out the commands to automatically get to live tv channels.
I am able to access its live tv using my current slingtv credentials. It appears to have much better audio than sling tv and better frame rates when watching SYFY and USA through it. Should be a better option for live sports on USA network than Sling.
You'll have to check the manifest file inside the apk for that.
Got my new 5 port LinkPi today (Just trying to swap out my single port URay). As expected, the interfaces are different and confusing. Stopped my stack and edited the environments. Stack deploys but I get the 404 error. Tried hunting and pecking without luck. Reset encoder back to factory specs.
Below are portainer log and environment variables after reset.
I'm going to be out for several hours but any advice to get back up and running would be appreciative.
Portainer log
2025-06-05T15:29:17.470050328Z 127.0.0.1 localhost
2025-06-05T15:29:17.470690285Z ::1 localhost ip6-localhost ip6-loopback
2025-06-05T15:29:17.470736259Z fe00::0 ip6-localnet
2025-06-05T15:29:17.470764133Z ff00::0 ip6-mcastprefix
2025-06-05T15:29:17.470792714Z ff02::1 ip6-allnodes
2025-06-05T15:29:17.470819386Z ff02::2 ip6-allrouters
2025-06-05T15:29:17.470852892Z 172.21.0.2 ah4c
2025-06-05T15:29:17.755162981Z * daemon not running; starting now at tcp:5037
2025-06-05T15:29:17.764687391Z * daemon started successfully
2025-06-05T15:29:17.764722510Z List of devices attached
2025-06-05T15:29:17.765216963Z
2025-06-05T15:29:17.796768521Z connected to 10.0.1.76:5555
2025-06-05T15:29:17.824372348Z connected to 10.0.1.29:5555
2025-06-05T15:29:17.828059393Z No existing ./scripts/firetv/directv/prebmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.829967251Z No existing ./scripts/osprey/directv/prebmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.831168320Z No existing ./scripts/firetv/directv/bmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.832494124Z No existing ./scripts/osprey/directv/bmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.833851128Z No existing ./scripts/firetv/directv/stopbmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.835021663Z No existing ./scripts/osprey/directv/stopbmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T15:29:17.841671686Z Existing directv.m3u found, and will be preserved
2025-06-05T15:29:17.841794763Z Existing dtvdeeplinks.m3u found, and will be preserved
2025-06-05T15:29:17.841851484Z Existing dtvosprey.m3u found, and will be preserved
2025-06-05T15:29:17.841890637Z Existing dtvstream.m3u found, and will be preserved
2025-06-05T15:29:17.841966203Z Existing dtvstreamdeeplinks.m3u found, and will be preserved
2025-06-05T15:29:17.842003659Z Existing foo-fighters.m3u found, and will be preserved
2025-06-05T15:29:17.842032266Z Existing fubo.m3u found, and will be preserved
2025-06-05T15:29:17.842059274Z Existing hulu.m3u found, and will be preserved
2025-06-05T15:29:17.842125449Z Existing livetv.m3u found, and will be preserved
2025-06-05T15:29:17.842177156Z Existing nbc.m3u found, and will be preserved
2025-06-05T15:29:17.842205408Z Existing npo.m3u found, and will be preserved
2025-06-05T15:29:17.842231726Z Existing pbs-seatac.m3u found, and will be preserved
2025-06-05T15:29:17.842297710Z Existing pbs-worcester.m3u found, and will be preserved
2025-06-05T15:29:17.842329679Z Existing silicondust.m3u found, and will be preserved
2025-06-05T15:29:17.842359335Z Existing sling.m3u found, and will be preserved
2025-06-05T15:29:17.842384715Z Existing spectrum.m3u found, and will be preserved
2025-06-05T15:29:17.842449468Z Existing xfinity.m3u found, and will be preserved
2025-06-05T15:29:17.842480350Z Existing youtubetv_shield.m3u found, and will be preserved
2025-06-05T15:29:17.842511145Z Existing youtubetv.m3u found, and will be preserved
2025-06-05T15:29:18.002487239Z [START] ah4c is starting
2025-06-05T15:29:18.002710734Z [ENV] Not loading env
2025-06-05T15:29:18.002755505Z [ENV] IPADDRESS 10.0.1.65:7654
2025-06-05T15:29:18.002800759Z [ENV] ALERT_SMTP_SERVER
2025-06-05T15:29:18.002843781Z [ENV] ALERT_AUTH_SERVER
2025-06-05T15:29:18.002869147Z [ENV] ALERT_EMAIL_FROM
2025-06-05T15:29:18.002948146Z [ENV] ALERT_EMAIL_PASS
2025-06-05T15:29:18.003083233Z [ENV] ALERT_EMAIL_TO
2025-06-05T15:29:18.003110445Z [ENV] ALERT_WEBHOOK_URL
2025-06-05T15:29:18.003134783Z [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2025-06-05T15:29:18.003160638Z [ENV] Creating tuner 1
2025-06-05T15:29:18.003193264Z [ENV] ENCODER1_URL http://10.0.1.34/stream0.ts
2025-06-05T15:29:18.003223325Z [ENV] TUNER1_IP 10.0.1.76:5555
2025-06-05T15:29:18.003250240Z [ENV] CMD1
2025-06-05T15:29:18.003275023Z [ENV] TEECMD1
2025-06-05T15:29:18.003307532Z [ENV] PRE SCRIPT ./scripts/osprey/directv/prebmitune.sh
2025-06-05T15:29:18.003337363Z [ENV] START SCRIPT ./scripts/osprey/directv/bmitune.sh
2025-06-05T15:29:18.003362730Z [ENV] STOP SCRIPT ./scripts/osprey/directv/stopbmitune.sh
2025-06-05T15:29:18.003389385Z [ENV] REBOOT SCRIPT ./scripts/osprey/directv/reboot.sh
2025-06-05T15:29:18.003421541Z [ENV] Creating tuner 2
2025-06-05T15:29:18.003505251Z [ENV] ENCODER2_URL http://10.0.1.34/stream1.ts
2025-06-05T15:29:18.003535152Z [ENV] TUNER2_IP 10.0.1.29:5555
2025-06-05T15:29:18.003563886Z [ENV] CMD2
2025-06-05T15:29:18.003587905Z [ENV] TEECMD2
2025-06-05T15:29:18.003614001Z [ENV] PRE SCRIPT ./scripts/osprey/directv/prebmitune.sh
2025-06-05T15:29:18.003640376Z [ENV] START SCRIPT ./scripts/osprey/directv/bmitune.sh
2025-06-05T15:29:18.003666347Z [ENV] STOP SCRIPT ./scripts/osprey/directv/stopbmitune.sh
2025-06-05T15:29:18.003696511Z [ENV] REBOOT SCRIPT ./scripts/osprey/directv/reboot.sh
2025-06-05T15:29:18.003723676Z [GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
2025-06-05T15:29:18.003760034Z - using env: export GIN_MODE=release
2025-06-05T15:29:18.003791239Z - using code: gin.SetMode(gin.ReleaseMode)
2025-06-05T15:29:18.003819119Z
2025-06-05T15:29:18.003857388Z [GIN-debug] GET /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2025-06-05T15:29:18.003910535Z [GIN-debug] HEAD /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2025-06-05T15:29:18.009239024Z [GIN-debug] Loaded HTML Templates (11):
2025-06-05T15:29:18.009352910Z - status_and_logs.html
2025-06-05T15:29:18.009390300Z -
2025-06-05T15:29:18.009414443Z - edit.html
2025-06-05T15:29:18.009439910Z - routes.html
2025-06-05T15:29:18.009466341Z - logs.html
2025-06-05T15:29:18.009491742Z - m3us.html
2025-06-05T15:29:18.009515610Z - status.html
2025-06-05T15:29:18.009542426Z - stream.html
2025-06-05T15:29:18.009571820Z - config.html
2025-06-05T15:29:18.009596601Z - editm3u.html
2025-06-05T15:29:18.009621049Z - index.html
2025-06-05T15:29:18.009649566Z
2025-06-05T15:29:18.009671234Z [GIN-debug] GET /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2025-06-05T15:29:18.009777858Z [GIN-debug] HEAD /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2025-06-05T15:29:18.009832681Z [GIN-debug] GET / --> main.run.func1 (2 handlers)
2025-06-05T15:29:18.009868066Z [GIN-debug] GET /routes --> main.run.func2 (2 handlers)
2025-06-05T15:29:18.009904294Z [GIN-debug] GET /play/tuner:tuner/:channel --> main.run.func3 (2 handlers)
2025-06-05T15:29:18.009951974Z [GIN-debug] GET /m3u/:channel --> main.run.func4 (2 handlers)
2025-06-05T15:29:18.009984570Z [GIN-debug] GET /env --> main.run.func5 (2 handlers)
2025-06-05T15:29:18.010015150Z [GIN-debug] GET /logs/text --> main.run.func6 (2 handlers)
2025-06-05T15:29:18.010045250Z [GIN-debug] GET /logs --> main.run.func7 (2 handlers)
2025-06-05T15:29:18.010076930Z [GIN-debug] GET /status/andlogs --> main.run.func8 (2 handlers)
2025-06-05T15:29:18.010106509Z [GIN-debug] GET /logs/json --> main.run.func9 (2 handlers)
2025-06-05T15:29:18.010134739Z [GIN-debug] GET /video --> main.run.func10 (2 handlers)
2025-06-05T15:29:18.010164736Z [GIN-debug] GET /status --> main.statusPageHandler (2 handlers)
2025-06-05T15:29:18.010193361Z [GIN-debug] GET /api/status --> main.apiStatusHandler (2 handlers)
2025-06-05T15:29:18.010223393Z [GIN-debug] GET /stream --> main.run.func11 (2 handlers)
2025-06-05T15:29:18.010250873Z [GIN-debug] GET /test/webhook --> main.run.func12 (2 handlers)
2025-06-05T15:29:18.010279554Z [GIN-debug] GET /test/email --> main.run.func13 (2 handlers)
2025-06-05T15:29:18.010308143Z [GIN-debug] GET /status/channelsactivity --> main.run.func14 (2 handlers)
2025-06-05T15:29:18.010348626Z [GIN-debug] GET /edit --> main.run.func15 (2 handlers)
2025-06-05T15:29:18.010378284Z [GIN-debug] POST /save --> main.run.func16 (2 handlers)
2025-06-05T15:29:18.010406121Z [GIN-debug] POST /m3usave/:file --> main.run.func17 (2 handlers)
2025-06-05T15:29:18.010434513Z [GIN-debug] GET /m3us --> main.run.func18 (2 handlers)
2025-06-05T15:29:18.010460789Z [GIN-debug] GET /editm3u/:file --> main.run.func19 (2 handlers)
2025-06-05T15:29:18.010488946Z [GIN-debug] GET /config --> main.run.func20 (2 handlers)
2025-06-05T15:29:18.010516758Z [GIN-debug] POST /configsave --> main.run.func21 (2 handlers)
2025-06-05T15:29:18.010543962Z [START] ah4c is ready
2025-06-05T15:29:18.010569595Z [GIN-debug] Listening and serving HTTP on :7654
2025-06-05T15:29:18.990573015Z
2025-06-05T15:29:18.990693510Z > [email protected] start
2025-06-05T15:29:18.990737473Z > node ./index.js
2025-06-05T15:29:18.990766426Z
2025-06-05T15:29:19.891122451Z Listening on:
2025-06-05T15:29:19.891727987Z http://ah4c:8000 http://localhost:8000
2025-06-05T15:29:19.891785592Z http://127.0.0.1:8000 http://172.21.0.2:8000
2025-06-05T15:30:19.730930971Z Attempting network tune for device http://10.0.1.34/stream0.ts 10.0.1.76:5555 273
2025-06-05T15:30:19.733128985Z [ERR] Failed to fetch source: 404 Not Found
2025-06-05T15:30:19.733204298Z Attempting network tune for device http://10.0.1.34/stream1.ts 10.0.1.29:5555 273
2025-06-05T15:30:19.735494061Z [ERR] Failed to fetch source: 404 Not Found
2025-06-05T15:30:19.735565185Z [ERR] Failed to tune device(s) not available
2025-06-05T15:30:19.735629363Z [GIN-debug] Request: 172.21.0.1 GET /play/tuner/273, latency: 4.729306ms, status: 500
Environment Variables
TAG=latest
DOMAIN=local
ADBS_PORT=5037
HOST_PORT=7654
WSCR_PORT=7655
IPADDRESS=10.0.1.65:7654
NUMBER_TUNERS=2
TUNER1_IP=10.0.1.76:5555
ENCODER1_URL=http://10.0.1.34/stream0.ts
TUNER2_IP=10.0.1.29:5555
ENCODER2_URL=http://10.0.1.34/stream1.ts
TUNER3_IP=
ENCODER3_URL=
TUNER4_IP=
ENCODER4_URL=
TUNER5_IP=
ENCODER5_URL=
STREAMER_APP=scripts/osprey/directv
CHANNELSIP=10.0.1.65:7654
ALERT_SMTP_SERVER=
ALERT_AUTH_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_SCRIPTS=true
UPDATE_M3US=false
TZ=US/CENTRAL
SPEED_MODE=false
KEEP_WATCHING=4h
HOST_DIR=/volume1/data
The LinkPi Encoder URL should look like this (the way you're trying to do it uses a redirect -- which will fail):
http://10.0.1.34:8090/stream0
This should be just the IP address (or resolvable hostname) of your Channels DVR server. Like:
Will do when I get back later today.
Made those changes and then was getting a 503 error. But I did get it working like this.
On the LinkPi interface, I changed the overall config on the Stream page to http and saved. Changed the encoder url by coping the url from the LP interface.
There's probably a lot of settings that I need to tweak to perfect it. There sure are a lot of settings!!!!
The encoder is the "WayPonDev Link Pi Enc5-V2 5 Port NDI HDM........"
Any other things I can provide you to optimize before I add the 3rd tuner?
Environment Variables:
DOMAIN=local
ADBS_PORT=5037
HOST_PORT=7654
WSCR_PORT=7655
NUMBER_TUNERS=2
ENCODER1_URL=http://10.0.1.34/live/stream0
ENCODER2_URL=http://10.0.1.34/live/stream1
TUNER3_IP=
ENCODER3_URL=
TUNER4_IP=
ENCODER4_URL=
TUNER5_IP=
ENCODER5_URL=
ALERT_SMTP_SERVER=
ALERT_AUTH_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_SCRIPTS=true
UPDATE_M3US=false
TZ=US/CENTRAL
SPEED_MODE=false
KEEP_WATCHING=4h
Portainer Log:
2025-06-05T22:23:07.582577484Z 127.0.0.1 localhost
2025-06-05T22:23:07.583069110Z ::1 localhost ip6-localhost ip6-loopback
2025-06-05T22:23:07.583105418Z fe00::0 ip6-localnet
2025-06-05T22:23:07.583133896Z ff00::0 ip6-mcastprefix
2025-06-05T22:23:07.583162062Z ff02::1 ip6-allnodes
2025-06-05T22:23:07.583188147Z ff02::2 ip6-allrouters
2025-06-05T22:23:07.583215597Z 172.23.0.2 ah4c
2025-06-05T22:23:07.844437979Z * daemon not running; starting now at tcp:5037
2025-06-05T22:23:07.852961163Z List of devices attached
2025-06-05T22:23:07.853172183Z
2025-06-05T22:23:07.853241948Z * daemon started successfully
2025-06-05T22:23:07.883913861Z connected to 10.0.1.76:5555
2025-06-05T22:23:07.913572029Z connected to 10.0.1.29:5555
2025-06-05T22:23:07.917453795Z No existing ./scripts/firetv/directv/prebmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.918953359Z No existing ./scripts/osprey/directv/prebmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.920808959Z No existing ./scripts/firetv/directv/bmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.922364765Z No existing ./scripts/osprey/directv/bmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.923694076Z No existing ./scripts/firetv/directv/stopbmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.924923273Z No existing ./scripts/osprey/directv/stopbmitune.sh found or UPDATE_SCRIPTS set to true
2025-06-05T22:23:07.931191254Z Existing directv.m3u found, and will be preserved
2025-06-05T22:23:07.931377927Z Existing dtvdeeplinks.m3u found, and will be preserved
2025-06-05T22:23:07.931429442Z Existing dtvosprey.m3u found, and will be preserved
2025-06-05T22:23:07.931499249Z Existing dtvstream.m3u found, and will be preserved
2025-06-05T22:23:07.931534100Z Existing dtvstreamdeeplinks.m3u found, and will be preserved
2025-06-05T22:23:07.931600082Z Existing foo-fighters.m3u found, and will be preserved
2025-06-05T22:23:07.931632864Z Existing fubo.m3u found, and will be preserved
2025-06-05T22:23:07.931699942Z Existing hulu.m3u found, and will be preserved
2025-06-05T22:23:07.931731801Z Existing livetv.m3u found, and will be preserved
2025-06-05T22:23:07.931776190Z Existing nbc.m3u found, and will be preserved
2025-06-05T22:23:07.931846171Z Existing npo.m3u found, and will be preserved
2025-06-05T22:23:07.931878176Z Existing pbs-seatac.m3u found, and will be preserved
2025-06-05T22:23:07.931933105Z Existing pbs-worcester.m3u found, and will be preserved
2025-06-05T22:23:07.931972478Z Existing silicondust.m3u found, and will be preserved
2025-06-05T22:23:07.932027346Z Existing sling.m3u found, and will be preserved
2025-06-05T22:23:07.932054746Z Existing spectrum.m3u found, and will be preserved
2025-06-05T22:23:07.932107509Z Existing xfinity.m3u found, and will be preserved
2025-06-05T22:23:07.932136754Z Existing youtubetv_shield.m3u found, and will be preserved
2025-06-05T22:23:07.932165797Z Existing youtubetv.m3u found, and will be preserved
2025-06-05T22:23:08.051571486Z [START] ah4c is starting
2025-06-05T22:23:08.051773034Z [ENV] Not loading env
2025-06-05T22:23:08.051818307Z [ENV] IPADDRESS 10.0.1.65:7654
2025-06-05T22:23:08.051925311Z [ENV] ALERT_SMTP_SERVER
2025-06-05T22:23:08.051957600Z [ENV] ALERT_AUTH_SERVER
2025-06-05T22:23:08.051986268Z [ENV] ALERT_EMAIL_FROM
2025-06-05T22:23:08.052015356Z [ENV] ALERT_EMAIL_PASS
2025-06-05T22:23:08.052085980Z [ENV] ALERT_EMAIL_TO
2025-06-05T22:23:08.052111960Z [ENV] ALERT_WEBHOOK_URL
2025-06-05T22:23:08.052136502Z [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2025-06-05T22:23:08.052161208Z [ENV] Creating tuner 1
2025-06-05T22:23:08.052190113Z [ENV] ENCODER1_URL http://10.0.1.34/live/stream0
2025-06-05T22:23:08.052219983Z [ENV] TUNER1_IP 10.0.1.76:5555
2025-06-05T22:23:08.052245705Z [ENV] CMD1
2025-06-05T22:23:08.052269695Z [ENV] TEECMD1
2025-06-05T22:23:08.052295482Z [ENV] PRE SCRIPT ./scripts/osprey/directv/prebmitune.sh
2025-06-05T22:23:08.052324559Z [ENV] START SCRIPT ./scripts/osprey/directv/bmitune.sh
2025-06-05T22:23:08.052349157Z [ENV] STOP SCRIPT ./scripts/osprey/directv/stopbmitune.sh
2025-06-05T22:23:08.052374980Z [ENV] REBOOT SCRIPT ./scripts/osprey/directv/reboot.sh
2025-06-05T22:23:08.052417103Z [ENV] Creating tuner 2
2025-06-05T22:23:08.052443797Z [ENV] ENCODER2_URL http://10.0.1.34/live/stream1
2025-06-05T22:23:08.052469601Z [ENV] TUNER2_IP 10.0.1.29:5555
2025-06-05T22:23:08.052493265Z [ENV] CMD2
2025-06-05T22:23:08.052517256Z [ENV] TEECMD2
2025-06-05T22:23:08.052539458Z [ENV] PRE SCRIPT ./scripts/osprey/directv/prebmitune.sh
2025-06-05T22:23:08.052563804Z [ENV] START SCRIPT ./scripts/osprey/directv/bmitune.sh
2025-06-05T22:23:08.052588093Z [ENV] STOP SCRIPT ./scripts/osprey/directv/stopbmitune.sh
2025-06-05T22:23:08.052614947Z [ENV] REBOOT SCRIPT ./scripts/osprey/directv/reboot.sh
2025-06-05T22:23:08.052639050Z [GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
2025-06-05T22:23:08.052672029Z - using env: export GIN_MODE=release
2025-06-05T22:23:08.052703046Z - using code: gin.SetMode(gin.ReleaseMode)
2025-06-05T22:23:08.052760509Z
2025-06-05T22:23:08.052783904Z [GIN-debug] GET /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2025-06-05T22:23:08.052847998Z [GIN-debug] HEAD /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2025-06-05T22:23:08.072264264Z [GIN-debug] Loaded HTML Templates (11):
2025-06-05T22:23:08.072399362Z - config.html
2025-06-05T22:23:08.072431068Z - editm3u.html
2025-06-05T22:23:08.072458513Z - status_and_logs.html
2025-06-05T22:23:08.072488525Z - logs.html
2025-06-05T22:23:08.072518950Z - m3us.html
2025-06-05T22:23:08.072545464Z - routes.html
2025-06-05T22:23:08.072571155Z - status.html
2025-06-05T22:23:08.072595110Z - stream.html
2025-06-05T22:23:08.072618491Z -
2025-06-05T22:23:08.072639358Z - edit.html
2025-06-05T22:23:08.072662669Z - index.html
2025-06-05T22:23:08.072689411Z
2025-06-05T22:23:08.072711428Z [GIN-debug] GET /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2025-06-05T22:23:08.072747655Z [GIN-debug] HEAD /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2025-06-05T22:23:08.072778800Z [GIN-debug] GET / --> main.run.func1 (2 handlers)
2025-06-05T22:23:08.072807065Z [GIN-debug] GET /routes --> main.run.func2 (2 handlers)
2025-06-05T22:23:08.072849330Z [GIN-debug] GET /play/tuner:tuner/:channel --> main.run.func3 (2 handlers)
2025-06-05T22:23:08.072896953Z [GIN-debug] GET /m3u/:channel --> main.run.func4 (2 handlers)
2025-06-05T22:23:08.072923266Z [GIN-debug] GET /env --> main.run.func5 (2 handlers)
2025-06-05T22:23:08.072949888Z [GIN-debug] GET /logs/text --> main.run.func6 (2 handlers)
2025-06-05T22:23:08.072976581Z [GIN-debug] GET /logs --> main.run.func7 (2 handlers)
2025-06-05T22:23:08.073004847Z [GIN-debug] GET /status/andlogs --> main.run.func8 (2 handlers)
2025-06-05T22:23:08.073030889Z [GIN-debug] GET /logs/json --> main.run.func9 (2 handlers)
2025-06-05T22:23:08.073057022Z [GIN-debug] GET /video --> main.run.func10 (2 handlers)
2025-06-05T22:23:08.073085400Z [GIN-debug] GET /status --> main.statusPageHandler (2 handlers)
2025-06-05T22:23:08.073111800Z [GIN-debug] GET /api/status --> main.apiStatusHandler (2 handlers)
2025-06-05T22:23:08.073209136Z [GIN-debug] GET /stream --> main.run.func11 (2 handlers)
2025-06-05T22:23:08.073248041Z [GIN-debug] GET /test/webhook --> main.run.func12 (2 handlers)
2025-06-05T22:23:08.073276059Z [GIN-debug] GET /test/email --> main.run.func13 (2 handlers)
2025-06-05T22:23:08.073306069Z [GIN-debug] GET /status/channelsactivity --> main.run.func14 (2 handlers)
2025-06-05T22:23:08.073338266Z [GIN-debug] GET /edit --> main.run.func15 (2 handlers)
2025-06-05T22:23:08.073368462Z [GIN-debug] POST /save --> main.run.func16 (2 handlers)
2025-06-05T22:23:08.073395604Z [GIN-debug] POST /m3usave/:file --> main.run.func17 (2 handlers)
2025-06-05T22:23:08.073422586Z [GIN-debug] GET /m3us --> main.run.func18 (2 handlers)
2025-06-05T22:23:08.073448525Z [GIN-debug] GET /editm3u/:file --> main.run.func19 (2 handlers)
2025-06-05T22:23:08.073476185Z [GIN-debug] GET /config --> main.run.func20 (2 handlers)
2025-06-05T22:23:08.073504281Z [GIN-debug] POST /configsave --> main.run.func21 (2 handlers)
2025-06-05T22:23:08.073531248Z [START] ah4c is ready
2025-06-05T22:23:08.073556197Z [GIN-debug] Listening and serving HTTP on :7654
2025-06-05T22:23:09.155337763Z
2025-06-05T22:23:09.155721412Z > [email protected] start
2025-06-05T22:23:09.155769337Z > node ./index.js
2025-06-05T22:23:09.155804256Z
2025-06-05T22:23:09.981665336Z Listening on:
2025-06-05T22:23:09.981794450Z http://ah4c:8000 http://localhost:8000
2025-06-05T22:23:09.981940696Z http://127.0.0.1:8000 http://172.23.0.2:8000
2025-06-05T22:23:49.867040976Z Attempting network tune for device http://10.0.1.34/live/stream0 10.0.1.76:5555 273
2025-06-05T22:23:49.871916146Z [EXECUTE] Running [./scripts/osprey/directv/prebmitune.sh 10.0.1.76:5555 273]
2025-06-05T22:23:55.101232591Z [EXECUTE] Stdout: 'already connected to 10.0.1.76:5555
2025-06-05T22:23:55.103916120Z Waking 10.0.1.76:5555
2025-06-05T22:23:55.104200394Z prebmitune.sh is exiting for 10.0.1.76:5555 with exit code 0
2025-06-05T22:23:55.104280139Z '
2025-06-05T22:23:55.104320200Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.76:5555
2025-06-05T22:23:55.104358139Z + streamerNoPort=10.0.1.76
2025-06-05T22:23:55.104503244Z + adbTarget='adb -s 10.0.1.76:5555'
2025-06-05T22:23:55.104535321Z + mkdir -p 10.0.1.76
2025-06-05T22:23:55.104576462Z + trap finish EXIT
2025-06-05T22:23:55.104605286Z + main
2025-06-05T22:23:55.104629668Z + adbConnect
2025-06-05T22:23:55.104662167Z + adb connect 10.0.1.76:5555
2025-06-05T22:23:55.104687561Z + local -i adbMaxRetries=3
2025-06-05T22:23:55.104797644Z + local -i adbCounter=0
2025-06-05T22:23:55.104922505Z + true
2025-06-05T22:23:55.104950896Z + adb -s 10.0.1.76:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:23:55.104996023Z + local adbEventSuccess=0
2025-06-05T22:23:55.105022270Z + [[ 0 -eq 0 ]]
2025-06-05T22:23:55.105053582Z + break
2025-06-05T22:23:55.105078275Z + adbWake
2025-06-05T22:23:55.105101975Z + adb -s 10.0.1.76:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:23:55.105134732Z + sleep 2
2025-06-05T22:23:55.105160165Z + echo 'Waking 10.0.1.76:5555'
2025-06-05T22:23:55.105185738Z + touch 10.0.1.76/adbAppRunning
2025-06-05T22:23:55.105221640Z + finish
2025-06-05T22:23:55.105244592Z + echo 'prebmitune.sh is exiting for 10.0.1.76:5555 with exit code 0'
2025-06-05T22:23:55.105279615Z '
2025-06-05T22:23:55.105302449Z [EXECUTE] Finished running ./scripts/osprey/directv/prebmitune.sh in 5.229371464s
2025-06-05T22:23:55.105351138Z [EXECUTE] Running [./scripts/osprey/directv/bmitune.sh 273 10.0.1.76:5555]
2025-06-05T22:23:56.684450221Z [EXECUTE] Stdout: 'bmitune.sh is exiting for 10.0.1.76:5555 with exit code 0
2025-06-05T22:23:56.684592510Z '
2025-06-05T22:23:56.684622636Z [EXECUTE] Stderr: '+ channelID='"273"'
2025-06-05T22:23:56.684652116Z + specialID=273
2025-06-05T22:23:56.684677915Z + streamerIP=10.0.1.76:5555
2025-06-05T22:23:56.684702868Z + streamerNoPort=10.0.1.76
2025-06-05T22:23:56.684726619Z + adbTarget='adb -s 10.0.1.76:5555'
2025-06-05T22:23:56.684752123Z + m3uName=directv.m3u
2025-06-05T22:23:56.684778250Z + trap finish EXIT
2025-06-05T22:23:56.684802102Z + main
2025-06-05T22:23:56.684833183Z + matchEncoderURL
2025-06-05T22:23:56.684858052Z + case "$streamerIP" in
2025-06-05T22:23:56.684882874Z + encoderURL=http://10.0.1.34/live/stream0
2025-06-05T22:23:56.684919186Z + tuneChannel
2025-06-05T22:23:56.684942260Z + adb -s 10.0.1.76:5555 shell input text '"273"'
2025-06-05T22:23:56.684968093Z + finish
2025-06-05T22:23:56.684990051Z + echo 'bmitune.sh is exiting for 10.0.1.76:5555 with exit code 0'
2025-06-05T22:23:56.685015650Z '
2025-06-05T22:23:56.685124556Z [EXECUTE] Finished running ./scripts/osprey/directv/bmitune.sh in 1.583430117s
2025-06-05T22:24:23.250206143Z Tuner 0 is active - skipping
2025-06-05T22:24:23.250688611Z Attempting network tune for device http://10.0.1.34/live/stream1 10.0.1.29:5555 674
2025-06-05T22:24:23.255337915Z [EXECUTE] Running [./scripts/osprey/directv/prebmitune.sh 10.0.1.29:5555 674]
2025-06-05T22:24:23.389995872Z [IO] io.Copy: write tcp 172.23.0.2:7654->172.23.0.1:56326: write: broken pipe
2025-06-05T22:24:23.390159370Z [IOINFO] Successfully copied 15801024 bytes
2025-06-05T22:24:23.390236990Z [IOINFO] Transfer speed: 4.468502942877164 Mbits/second
2025-06-05T22:24:23.390286818Z Performing Close() for 10.0.1.76:5555
2025-06-05T22:24:23.390318661Z [EXECUTE] Running [./scripts/osprey/directv/stopbmitune.sh 10.0.1.76:5555 273]
2025-06-05T22:24:24.566099210Z [EXECUTE] Stdout: 'Sleep initiated for 10.0.1.76:5555
2025-06-05T22:24:24.566239347Z 10.0.1.76/stream_stopped written with epoch stop time
2025-06-05T22:24:24.566277472Z '
2025-06-05T22:24:24.566300680Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.76:5555
2025-06-05T22:24:24.566329239Z + streamerNoPort=10.0.1.76
2025-06-05T22:24:24.566353072Z + adbTarget='adb -s 10.0.1.76:5555'
2025-06-05T22:24:24.566389418Z + main
2025-06-05T22:24:24.566412070Z + adbSleep
2025-06-05T22:24:24.566436424Z + sleep='input keyevent KEYCODE_SLEEP'
2025-06-05T22:24:24.566463391Z + adb -s 10.0.1.76:5555 shell input keyevent KEYCODE_SLEEP
2025-06-05T22:24:24.566489591Z + echo 'Sleep initiated for 10.0.1.76:5555'
2025-06-05T22:24:24.566515412Z + date +%s
2025-06-05T22:24:24.566540612Z + echo '10.0.1.76/stream_stopped written with epoch stop time'
2025-06-05T22:24:24.566565910Z '
2025-06-05T22:24:24.566586901Z [EXECUTE] Finished running ./scripts/osprey/directv/stopbmitune.sh in 1.17600059s
2025-06-05T22:24:28.325664000Z [EXECUTE] Stdout: 'already connected to 10.0.1.29:5555
2025-06-05T22:24:28.326195297Z Waking 10.0.1.29:5555
2025-06-05T22:24:28.326405779Z prebmitune.sh is exiting for 10.0.1.29:5555 with exit code 0
2025-06-05T22:24:28.326463672Z '
2025-06-05T22:24:28.326493577Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.29:5555
2025-06-05T22:24:28.326537563Z + streamerNoPort=10.0.1.29
2025-06-05T22:24:28.326565483Z + adbTarget='adb -s 10.0.1.29:5555'
2025-06-05T22:24:28.326655192Z + mkdir -p 10.0.1.29
2025-06-05T22:24:28.326728653Z + trap finish EXIT
2025-06-05T22:24:28.326802967Z + main
2025-06-05T22:24:28.326850438Z + adbConnect
2025-06-05T22:24:28.326876240Z + adb connect 10.0.1.29:5555
2025-06-05T22:24:28.326917202Z + local -i adbMaxRetries=3
2025-06-05T22:24:28.327016212Z + local -i adbCounter=0
2025-06-05T22:24:28.327122478Z + true
2025-06-05T22:24:28.327149796Z + adb -s 10.0.1.29:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:24:28.327300709Z + local adbEventSuccess=0
2025-06-05T22:24:28.327340683Z + [[ 0 -eq 0 ]]
2025-06-05T22:24:28.327370521Z + break
2025-06-05T22:24:28.327394036Z + adbWake
2025-06-05T22:24:28.327429643Z + adb -s 10.0.1.29:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:24:28.327463298Z + sleep 2
2025-06-05T22:24:28.327498730Z + echo 'Waking 10.0.1.29:5555'
2025-06-05T22:24:28.327525964Z + touch 10.0.1.29/adbAppRunning
2025-06-05T22:24:28.327571251Z + finish
2025-06-05T22:24:28.327596046Z + echo 'prebmitune.sh is exiting for 10.0.1.29:5555 with exit code 0'
2025-06-05T22:24:28.327628560Z '
2025-06-05T22:24:28.327669287Z [EXECUTE] Finished running ./scripts/osprey/directv/prebmitune.sh in 5.068558135s
2025-06-05T22:24:28.327702255Z [EXECUTE] Running [./scripts/osprey/directv/bmitune.sh 674 10.0.1.29:5555]
2025-06-05T22:24:28.328479286Z [GIN-debug] Request: 172.23.0.1 GET /play/tuner/273, latency: 38.458764782s, status: 200
2025-06-05T22:24:30.085341627Z [EXECUTE] Stdout: 'bmitune.sh is exiting for 10.0.1.29:5555 with exit code 0
2025-06-05T22:24:30.085817828Z '
2025-06-05T22:24:30.085861988Z [EXECUTE] Stderr: '+ channelID='"674"'
2025-06-05T22:24:30.085896037Z + specialID=674
2025-06-05T22:24:30.085920937Z + streamerIP=10.0.1.29:5555
2025-06-05T22:24:30.085987564Z + streamerNoPort=10.0.1.29
2025-06-05T22:24:30.086013138Z + adbTarget='adb -s 10.0.1.29:5555'
2025-06-05T22:24:30.086041923Z + m3uName=directv.m3u
2025-06-05T22:24:30.086069006Z + trap finish EXIT
2025-06-05T22:24:30.086092411Z + main
2025-06-05T22:24:30.086114620Z + matchEncoderURL
2025-06-05T22:24:30.086138236Z + case "$streamerIP" in
2025-06-05T22:24:30.086167749Z + encoderURL=http://10.0.1.34/live/stream1
2025-06-05T22:24:30.086196249Z + tuneChannel
2025-06-05T22:24:30.086219007Z + adb -s 10.0.1.29:5555 shell input text '"674"'
2025-06-05T22:24:30.086245994Z + finish
2025-06-05T22:24:30.086274671Z + echo 'bmitune.sh is exiting for 10.0.1.29:5555 with exit code 0'
2025-06-05T22:24:30.086301474Z '
2025-06-05T22:24:30.086324279Z [EXECUTE] Finished running ./scripts/osprey/directv/bmitune.sh in 1.760837636s
2025-06-05T22:25:54.699642620Z Attempting network tune for device http://10.0.1.34/live/stream0 10.0.1.76:5555 273
2025-06-05T22:25:54.703753873Z [EXECUTE] Running [./scripts/osprey/directv/prebmitune.sh 10.0.1.76:5555 273]
2025-06-05T22:25:54.848141682Z [IO] io.Copy: write tcp 172.23.0.2:7654->172.23.0.1:56338: write: broken pipe
2025-06-05T22:25:54.848315042Z [IOINFO] Successfully copied 44793408 bytes
2025-06-05T22:25:54.848357379Z [IOINFO] Transfer speed: 4.141590672012914 Mbits/second
2025-06-05T22:25:54.848396531Z Performing Close() for 10.0.1.29:5555
2025-06-05T22:25:54.848425698Z [EXECUTE] Running [./scripts/osprey/directv/stopbmitune.sh 10.0.1.29:5555 674]
2025-06-05T22:25:55.931659517Z [EXECUTE] Stdout: 'Sleep initiated for 10.0.1.29:5555
2025-06-05T22:25:55.932047782Z 10.0.1.29/stream_stopped written with epoch stop time
2025-06-05T22:25:55.932087258Z '
2025-06-05T22:25:55.932189904Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.29:5555
2025-06-05T22:25:55.932315874Z + streamerNoPort=10.0.1.29
2025-06-05T22:25:55.932351021Z + adbTarget='adb -s 10.0.1.29:5555'
2025-06-05T22:25:55.932379133Z + main
2025-06-05T22:25:55.932404009Z + adbSleep
2025-06-05T22:25:55.932436409Z + sleep='input keyevent KEYCODE_SLEEP'
2025-06-05T22:25:55.932468462Z + adb -s 10.0.1.29:5555 shell input keyevent KEYCODE_SLEEP
2025-06-05T22:25:55.932495907Z + echo 'Sleep initiated for 10.0.1.29:5555'
2025-06-05T22:25:55.932525838Z + date +%s
2025-06-05T22:25:55.932549947Z + echo '10.0.1.29/stream_stopped written with epoch stop time'
2025-06-05T22:25:55.932575350Z '
2025-06-05T22:25:55.932596484Z [EXECUTE] Finished running ./scripts/osprey/directv/stopbmitune.sh in 1.084099602s
2025-06-05T22:25:59.090726430Z [EXECUTE] Stdout: 'already connected to 10.0.1.76:5555
2025-06-05T22:25:59.091258553Z Waking 10.0.1.76:5555
2025-06-05T22:25:59.091315353Z prebmitune.sh is exiting for 10.0.1.76:5555 with exit code 0
2025-06-05T22:25:59.091352482Z '
2025-06-05T22:25:59.091387106Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.76:5555
2025-06-05T22:25:59.091419783Z + streamerNoPort=10.0.1.76
2025-06-05T22:25:59.091444081Z + adbTarget='adb -s 10.0.1.76:5555'
2025-06-05T22:25:59.091481300Z + mkdir -p 10.0.1.76
2025-06-05T22:25:59.091512979Z + trap finish EXIT
2025-06-05T22:25:59.091545049Z + main
2025-06-05T22:25:59.091573064Z + adbConnect
2025-06-05T22:25:59.091596072Z + adb connect 10.0.1.76:5555
2025-06-05T22:25:59.091627281Z + local -i adbMaxRetries=3
2025-06-05T22:25:59.091709177Z + local -i adbCounter=0
2025-06-05T22:25:59.091743457Z + true
2025-06-05T22:25:59.091775013Z + adb -s 10.0.1.76:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:25:59.091805385Z + local adbEventSuccess=0
2025-06-05T22:25:59.091841770Z + [[ 0 -eq 0 ]]
2025-06-05T22:25:59.091865776Z + break
2025-06-05T22:25:59.091888857Z + adbWake
2025-06-05T22:25:59.091921881Z + adb -s 10.0.1.76:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:25:59.091948092Z + sleep 2
2025-06-05T22:25:59.091971897Z + echo 'Waking 10.0.1.76:5555'
2025-06-05T22:25:59.092004001Z + touch 10.0.1.76/adbAppRunning
2025-06-05T22:25:59.092030737Z + finish
2025-06-05T22:25:59.092059904Z + echo 'prebmitune.sh is exiting for 10.0.1.76:5555 with exit code 0'
2025-06-05T22:25:59.092087673Z '
2025-06-05T22:25:59.092108939Z [EXECUTE] Finished running ./scripts/osprey/directv/prebmitune.sh in 4.385922632s
2025-06-05T22:25:59.092146695Z [GIN-debug] Request: 172.23.0.1 GET /play/tuner/674, latency: 1m35.84004924s, status: 200
2025-06-05T22:25:59.092189969Z [EXECUTE] Running [./scripts/osprey/directv/bmitune.sh 273 10.0.1.76:5555]
2025-06-05T22:26:00.211690836Z [EXECUTE] Stdout: 'bmitune.sh is exiting for 10.0.1.76:5555 with exit code 0
2025-06-05T22:26:00.211837407Z '
2025-06-05T22:26:00.211863195Z [EXECUTE] Stderr: '+ channelID='"273"'
2025-06-05T22:26:00.211895783Z + specialID=273
2025-06-05T22:26:00.211920677Z + streamerIP=10.0.1.76:5555
2025-06-05T22:26:00.211944790Z + streamerNoPort=10.0.1.76
2025-06-05T22:26:00.211971872Z + adbTarget='adb -s 10.0.1.76:5555'
2025-06-05T22:26:00.211997115Z + m3uName=directv.m3u
2025-06-05T22:26:00.212022249Z + trap finish EXIT
2025-06-05T22:26:00.212045860Z + main
2025-06-05T22:26:00.212068922Z + matchEncoderURL
2025-06-05T22:26:00.212093460Z + case "$streamerIP" in
2025-06-05T22:26:00.212117973Z + encoderURL=http://10.0.1.34/live/stream0
2025-06-05T22:26:00.212147071Z + tuneChannel
2025-06-05T22:26:00.212171398Z + adb -s 10.0.1.76:5555 shell input text '"273"'
2025-06-05T22:26:00.212197653Z + finish
2025-06-05T22:26:00.212219440Z + echo 'bmitune.sh is exiting for 10.0.1.76:5555 with exit code 0'
2025-06-05T22:26:00.212245587Z '
2025-06-05T22:26:00.212266534Z [EXECUTE] Finished running ./scripts/osprey/directv/bmitune.sh in 1.121409276s
2025-06-05T22:29:30.002928924Z Tuner 0 is active - skipping
2025-06-05T22:29:30.003402004Z Attempting network tune for device http://10.0.1.34/live/stream1 10.0.1.29:5555 674
2025-06-05T22:29:30.008055093Z [EXECUTE] Running [./scripts/osprey/directv/prebmitune.sh 10.0.1.29:5555 674]
2025-06-05T22:29:34.347947157Z [EXECUTE] Stdout: 'already connected to 10.0.1.29:5555
2025-06-05T22:29:34.348313046Z Waking 10.0.1.29:5555
2025-06-05T22:29:34.348350978Z prebmitune.sh is exiting for 10.0.1.29:5555 with exit code 0
2025-06-05T22:29:34.348386656Z '
2025-06-05T22:29:34.348409690Z [EXECUTE] Stderr: '+ streamerIP=10.0.1.29:5555
2025-06-05T22:29:34.348438252Z + streamerNoPort=10.0.1.29
2025-06-05T22:29:34.348463816Z + adbTarget='adb -s 10.0.1.29:5555'
2025-06-05T22:29:34.348491584Z + mkdir -p 10.0.1.29
2025-06-05T22:29:34.348516462Z + trap finish EXIT
2025-06-05T22:29:34.348541218Z + main
2025-06-05T22:29:34.348567373Z + adbConnect
2025-06-05T22:29:34.348591122Z + adb connect 10.0.1.29:5555
2025-06-05T22:29:34.348662274Z + local -i adbMaxRetries=3
2025-06-05T22:29:34.348693561Z + local -i adbCounter=0
2025-06-05T22:29:34.348718964Z + true
2025-06-05T22:29:34.348745492Z + adb -s 10.0.1.29:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:29:34.348773938Z + local adbEventSuccess=0
2025-06-05T22:29:34.348798420Z + [[ 0 -eq 0 ]]
2025-06-05T22:29:34.348821672Z + break
2025-06-05T22:29:34.349791519Z + adbWake
2025-06-05T22:29:34.349819063Z + adb -s 10.0.1.29:5555 shell input keyevent KEYCODE_WAKEUP
2025-06-05T22:29:34.349860399Z + sleep 2
2025-06-05T22:29:34.349885115Z + echo 'Waking 10.0.1.29:5555'
2025-06-05T22:29:34.349911482Z + touch 10.0.1.29/adbAppRunning
2025-06-05T22:29:34.349942649Z + finish
2025-06-05T22:29:34.349965748Z + echo 'prebmitune.sh is exiting for 10.0.1.29:5555 with exit code 0'
2025-06-05T22:29:34.349994340Z '
2025-06-05T22:29:34.350019381Z [EXECUTE] Finished running ./scripts/osprey/directv/prebmitune.sh in 4.340065435s
2025-06-05T22:29:34.350053701Z [EXECUTE] Running [./scripts/osprey/directv/bmitune.sh 674 10.0.1.29:5555]
2025-06-05T22:29:35.439706798Z [EXECUTE] Stdout: 'bmitune.sh is exiting for 10.0.1.29:5555 with exit code 0
2025-06-05T22:29:35.440226280Z '
2025-06-05T22:29:35.440260567Z [EXECUTE] Stderr: '+ channelID='"674"'
2025-06-05T22:29:35.440294776Z + specialID=674
2025-06-05T22:29:35.440321391Z + streamerIP=10.0.1.29:5555
2025-06-05T22:29:35.440347683Z + streamerNoPort=10.0.1.29
2025-06-05T22:29:35.440377077Z + adbTarget='adb -s 10.0.1.29:5555'
2025-06-05T22:29:35.440403902Z + m3uName=directv.m3u
2025-06-05T22:29:35.440431901Z + trap finish EXIT
2025-06-05T22:29:35.440456506Z + main
2025-06-05T22:29:35.440479416Z + matchEncoderURL
2025-06-05T22:29:35.440502716Z + case "$streamerIP" in
2025-06-05T22:29:35.440528217Z + encoderURL=http://10.0.1.34/live/stream1
2025-06-05T22:29:35.440557800Z + tuneChannel
2025-06-05T22:29:35.440582135Z + adb -s 10.0.1.29:5555 shell input text '"674"'
2025-06-05T22:29:35.440609688Z + finish
2025-06-05T22:29:35.440632777Z + echo 'bmitune.sh is exiting for 10.0.1.29:5555 with exit code 0'
2025-06-05T22:29:35.440664948Z '
2025-06-05T22:29:35.440686878Z [EXECUTE] Finished running ./scripts/osprey/directv/bmitune.sh in 1.091285193s
That's interesting. This is not the way I have my ENC5-V2 set up, but maybe they've changed something in the firmware along the way:
Otherwise, it looks like you're on track.
Wanted to share a quick thing I discovered about the DirecTV Osprey Boxes. You can now use a MyFree DTV account to log into them. You don’t need a paid DirecTV account. This puts them in an App Only mode.
I would not necessarily recommend buying them as an Android / Google TV streamer as they are pretty old at this point. But if you have some already or can find them dirt cheap on eBay, the hardware is still nice. Still getting updates, have Ethernet and Optical audio and an amazing remote.
I have one dedicated to just running Channels App on a secondary TV. I changed the default launcher The backlight remote with channel number buttons works well. I have also tested and they do allow Apps which can be targeted for deep links, such as YTTV.
Happy Streaming!
I can get the following to work in a terminal perfectly and capture video and audio:
magewell2ts -i 1 -c h264_qsv -m | ffmpeg -i - -ss 5 -c:v copy -c:a copy -f mpegts test.ts
The same goes for this:
magewell2ts -i 1 -c h264_qsv -m | ffmpeg -i - -ss 5 -c:v copy -c:a copy -f mpegts -
The first part of the command calls a linux application for the magewell card I am experimenting with and the second takes the feed into ffmpeg for processing.
I cant seem to get it to work when I use this second one as a command in the ah4c env file.
CMD1="magewell2ts -i 1 -c h264_qsv -m | ffmpeg -i - -ss 5 -c:v copy -c:a copy -f mpegts -"
ENCODER1_URL=""
TUNER1_IP="192.168.1.12:5555"
I am doing this so I can control when the recording of the video feed by the card actually begins (-ss 5 gives a five second delay before capture starts). Any insight ?
