Best DVR NAS Option?
Thanks for the speedy chime in! Yes, I’m replacing my current Terra-Master (I think it’s the F4-422). I was planning on having to put Channels on a mini PC but am now open to adding Channels to the NAS. I typically do not run other software on it. I’m hoping that the creators or other users can weigh in on which of the supported NAS providers are most likely to have continued support.
So, is the idea that the NAS can run Channels DVR but mainly to store recordings? If I am running the player app on my phone or other device (like the Nvidia Shield), is that considered remote streaming?
I used to run ChannelsDVR standalone on a Raspberry Pi, but I sold the Pi and moved to a Synology NAS (DS220+) that I use for media storage, backups, and it runs my ChannelsDVR and also Plex. All my viewing is in the house, and it performs well enough - no issues with recording or playback. Commercial detection is a little slow with only 1 thread available for that. If you don't need a NAS, there are better options as others have stated.
No, remote streaming = out-of-home streaming, like in a hotel or in a Tesla. My Channels DVR installation on an NAS works great with the apps for phone, tablet, Fire TV, etc. It only chokes while transcoding when I use the web UI for playback. I don't do remote streaming.
It seems to me Synology is the most popular here. (Get a unit with a "+" at the end of the model number.) For 2025 all the NAS types listed halfway down this page are still supported. If support ever goes away, you can still install the Docker image on most. I'm using the custom Synology install, but would be happy to switch to Docker anytime. In fact my Lyrion music server lives in Docker on another Synology NAS.
Channels — Hardware
Do any of the single bay synology NAS boxes have sufficient power to record directly to the NAS?
You wil need a more powerful NAS either Qnap or U-green.
Synology DS224plus is good with memory upd=grade.
Thanks for the quick reply. I may also look at a mini PC with backup on my NAS or a USB drive. That sound doable? My problem is that Channels will only record programs the day they are set to record. The next day, nothing. Perhaps there is a secret in keeping the Dell PC from auto upgrading, but I haven't found it yet.
A quiet mini pc with a good solid state drive will work great for Channels and any other addon applications you may use with the application.
I'm running Channels on my Synology s220plus with a memory upgrade.
The system has been working great.
Thanks again. I realized that I have a seldom used laptop that also might serve. Having battery backup and dedicated screen would also be pluses. Do these specs look adequete? I would strip all other programs from the PC. Lew
