Run this in Terminal to update to test build:
curl -XPUT http://127.0.0.1:8089/updater/check/2017.05.24.1552
Oh man, it worked! but…
https://www.dropbox.com/s/u6vv05n5kizsr0f/ScreenShot2017-05-24at2.15.03PM.png?dl=0
it gets better if I set it to blend on the deinterlacer but even it has some issues.
2017/05/24 16:34:16 [HLS] Starting transcoder for file-395 at 18m0s (encoder=h264_vaapi, resolution=720, deinterlacer=hardware, bitrate=2000)
libva info: VA-API version 0.40.0
libva info: va_getDriverName() returns 0
libva info: va_openDriver() returns 0
2017/05/24 16:34:18 [HLS] Stopping transcoder for file-395 after seek to 18m0s (out=0s, finished=false)
2017/05/24 16:34:18 [HLS] Starting transcoder for file-395 at 18m0s (encoder=h264_vaapi, resolution=720, deinterlacer=hardware, bitrate=2000)
Unrepairable underflow!
2017/05/24 16:35:31 [HLS] Stopping transcoder session file-395 @ 20m39.459311s
2017/05/24 16:35:42 [HLS] Starting transcoder for file-395 at 18m0s (encoder=h264_vaapi, resolution=720, deinterlacer=blend, bitrate=2000)
2017/05/24 16:36:14 [HLS] Stopping transcoder session file-395 @ 19m40.133378s
That might be normal for 2mbps. Try a higher bitrate?
Check your BIOS settings again and see if there are options for selecting the primary GPU. Seems like your machine maybe has two of them.
Will do. Thanks again for all of your help. I’ll let you know what I find out tonight.
