Anything for Apple users?
Thanks, that works great. And super fast tuning as well. Alot better than going through channels for OTA this way. But TVE channels work great and load super fast from the channels server this way.
I'm using the CCTV Viewer app for Apple TV and it's working great now. I can have a feed with up to 16 channels at a time
This works for iPadOS and tvOS. PiP on iOS is masochism.
The interface to make this work isn't that great, but if you need regular 4-way channel sets, it's "good enough"
Fyi. Dont know if youve used the web interface on CCTV. A lot easier to do edits and create groups if channels. Also - you can import and export the groups into a .plist file. If you want to copy your groups to your ipad from apple tv, makes it a breeze.
On AppleTV there are a few options: Surveil Stream, QuadStream, and CCTV Viewer, all work with streams from Channels DVR. Each has their own various interface quirks.
