Problem with adding those kinds of things to a pass is that passes can record more than one show or movie depending on how they're setup.
Title CONTAINS something
Channel CONTAINS major networks
Time CONTAINS 8pm, 9pm, 10pm
I suppose but the ones I have setup only record one show. Still would be nice to have the ability to get to these settings more easily, especially when I donât currently have a show recorded and canât access âshow options.â
Passes and shows are completely separate data items. The setting is for a show. Passes create recordings.
I understand the frustration, but this isnât something that is going to change.
Okay thanks. I just come from TiVo where everything was more user friendly. Channels is great but TiVo had some of those little niceties.
So there is no way to set this globally for a show then? Is it something that will need to be changed for every recording?
TiVo was different than a modern media center. TiVo was 100% about recordings and didnât care about a library of content like modern software like Channels.
That made sense because storage was limited and no one archived anything. 20 years later we have the ability to build up large libraries of local content, and thatâs how Channels is designed.
With the means we have today, weâre able to record and import so much content, presenting them as a library instead of a running list of a few recordings is important (even if we still do provide that facility)
DVR in Channels is less about 10 or so recordings available at a time, and is more of a means to build out that library. So comparing the two arenât exactly apples to apples.
Itâs a setting per show. You set it in the Showâs options, along with the other options it has. Itâs not per recording. Once you set it for the show, itâs respected for all of its recordings.
Okay great. Is there a way to get to a showâs options when there is no copy of that show currently recorded?
Only way I can think of would be to import an episode of the show and match it using Gracenote data.
Of course you can't import something you don't have, but that's the only way I know of to do it.
Okay thanks. Iâll just wait until they get recorded and make the change then.
No, it has to exist to set its options.
You can do it directly in the client though and web admin.
Got it. Thanks for all your help and for adding this option. You have a great product here.
