Yes, it happens after a fresh restart of the app, even before PIP is engaged for the first time.
After using PIP no channel surfing on the Beta
@Fofer Can you reproduce with 5.4.2338 and resubmit diagnostics. There's more logging that will help us hopefully see what's going on.
Done.
It is now August 2023. I am considering installing Channels and found this old thread. Can someone give me (or point me to) the latest info r.e. surfing with Channels and a) bandwidth management; and b) channel change response time?
Surfing:
ONN box.
On the ONN streaming box there is a Channel UP/DOWN toggle button which surfs(changes channel) without going back to the Guide.
Firestick.
The normal Firestick remote does not seem to be able to Channel surf without going back to the Guide,
the Up/Down buttons on the D-Pad do things in the Channels app like Down brings up Quick Guide/Options.
If you buy the Firestick PRO remote from Best Buy it does have the Channel UP/DOWN toggle button which does work in Channels for surfing.
