when are you going to try SLM? it'll fix this for you...
If you want help from this community, you have to show your custom m3u source settings and the contents of your m3u file. If your playlist m3u file changes everyday, show the one from yesterday and the one from today.
Without these details, it's impossible to see what's going on.
Also, if you make changes to your custom m3u source settings, there's a long standing bug where some changes you make don't "stick", so you have to create a new customer m3u source using a different name.
At this point, I'm accepting that this is a bug I'll just have to deal with...
...much like you're doing with that one.
Only I don't have an issue with my source channel numbers changing every day.
I have three sources I set to ignore channel numbers from the m3u and chose a starting channel number.
The channel numbers for these sources stay the same every day.
Plex starts at channel 1000 and here's one of the channels from the m3u (Heartland 1224)
#EXTINF:-1 channel-id="plex-heartland" tvg-id="5e20b730f2f8d5003d739db7-6449369eb3ff17382cae5806",Heartland
Samsung starts at channel 2100 and here's one of the channels from the m3u (Heartland 2157)
#EXTINF:-1 channel-id="samsung-USBB2900003O3" tvg-id="USBB2900003O3",Heartland
Tubi starts at channel 3000 and here's one of the channels from the m3u (Heartland 3077)
#EXTINF:-1 channel-id="tubi-671821" tvg-id="671821",Heartland
