Man, I appreciate this effort but I have read every post here and followed the Simplified Instructions and I still can't get this @#$@# to work. I set up a Windows VM, installed Chrome, tested the local IP:port link on the VM to see it's running, yada yada yada, and still can't get NBC to tune on CDVR. I understand this isn't Easy Button level stuff, but man it's tough to follow between the client, server, "tuning" instances.
Understand. I had an old Dell I7. I tried it but it just kept failing. Let us know what you find. I might try one and retire my I7 and use the other for daily PC use. Tnx.
I'm trying to do this with docker, and I get to the point with the debug interface where I can login to Fubo, but I can't type a period when logging in...and that whole ".com" part of my email address is kinda important to docker.
I'm guessing others have solved this, but I can't find a post here with it. The logs for a successful character (like 'c' in this example) say:
[2023/06/30 03:54:27.589] GET /debug/keypress/c from ::ffff:172.17.0.1 responded 304 in 14.626 ms
But when I type a period it doesn't even show up in the logs as a period, just blank.
[2023/06/30 03:54:26.551] GET /debug/keypress/ from ::ffff:172.17.0.1 responded 404 in 0.494 ms
Thanks for any thoughts you might have!
Here are some performance screenshots of my i7-8700, running 1 stream and 4 streams. This 8700 is about half as powerful, in multi-threading, as the 5800H.
1 Stream
4 streams
For some reason the latest .exe Version 10 file is not honoring the url I have setup in my custom channel For NBC networks.
my url:https://www.nbc.com/live?brand=syfy&callsign=syfy_east
Channels sends me to
my url:https://www.nbc.com/live?brand=syfy&callsign=syfy_west
This occurs with all NBC brands with east and west feeds. This was not the case with earlier versions.
Why? That's just another layer of complication where things could go wrong. My guess based on what you said is the VM is not exposing its ports to the outside world, plus it may be being confused with the physical machine it is on. Just install it directly on a physical machine and make sure it can works that way first, even if it is not an ideal situation or has performance issues.
Which headless adapter are you using?
Along with this:
I did some more testing, and could also not get / \ # % ? DEL
I'm on Windows running 4K res and am still getting black borders around NBC News Now, for example.
I haven't figured out how to automatically put the chrome window in full screen, but at 1080, if I manually put it in full screen after the recording starts, I get no boarders.
I don't have any Windows always-on PCs. I do have 3 Linux servers with dozens of containers and VMs working great. I did double-check the external port access several times and it's fine. On a container I was getting a auth screen I couldn't interact with, and on the VM I have gotten different outcomes but none authorized for NBC.
Well yeah that works for anyone but the hope is that you shouldn't have to do that.
So far I have just been using it for news, so borders aren't a big deal to me. I was just trying to help you. Too bad there isn't a way to automatically go full screen after the chrome tab opens.
Does this not work with you?
- If you are running a Docker, open a new Chromium-based browser and go to http://localhost:5589/debug?url=https://nbc.com/live , replacing "localhost" with your IP address if they are different servers. This will give you a slow but partially interactive window to work in to do the login steps the same as Windows or Mac below.
NOTE: This can be used for logging in or interacting with any any service.
- Go through the login process as normal. After this, your credentials will be remembered.
Don't get me wrong, it is painfully slow, and I often found I needed to launch it about two to three times in a row before it responded to me. Then there is the issue of certain characters not being able to be typed as shown above...
Some people have also noted that they can't seem to get the built-in station to work, but when they use the manual links it works fine.
Also, although it is undocumented, you can also do a test in VLC. Just do something like this:
Thanks for this additional info. I'd tried that, and I was unusually patient, but I abandoned it as a failed attempt when it seemed to just sit there. I'll try again this weekend.
Disregard, it does work fully. Just forgot to set pull channel from M3U option in admin settings for this source
Is it possible to pull in portions of the Stream Channel Functionality into this capability. Specifically, I can pull in Station ID to feed the guide and assign a specific channel under my stream source. Example:
#EXTINF:-1 channel-id="bravo" tvg-chno="6058" tvc-guide-stationid="58625",BRAVOHD
nbctve://live/bravo
But when I tried to use that same format for Chrome Capture for Channels (separate source as the Stream within channels), no guide data and it mapped it to 10000+ channel number:
#EXTINF:-1 channel-id="NBC Local"tvg-chno="10.1" tvc-guide-stationid="79329",WGAL-DT
chrome://192.168.0.4:5589/stream/nbc
Or is my lack of coding experience screaming out to everyone on the above?
TIA.
Tried recording Project Runway on Bravo last night. It worked great for the first minute, then the picture is frozen for the rest of the show, but the audio kept going just fine.
Log from CDVR
2023/06/29 20:59:20.745291 [DVR] Starting job 1688086740-77 Project Runway on ch=[4003]
2023/06/29 20:59:20.770708 [TNR] Opened connection to M3U-ChromeCapture for ch4003 Bravo (East)
2023/06/29 20:59:20.844686 [DVR] Recording for job 1688086740-77 from M3U-ChromeCapture ch4003 into "TV/Project Runway/Project Runway S20E04 Coronation Day 2023-06-29-2059.mpg" for 1h33m39.254443s
2023/06/29 20:59:20.844848 [DVR] Starting job 1688086740-104 Alone on ch=[6044]
2023/06/29 20:59:20.845867 [DVR] Waiting 1h0m39.15414s until next job 1688090400-214 Booked: First Day In
2023/06/29 20:59:21.241260 [IDX] Generating video index for job 1688086740-64
2023/06/29 20:59:21.330376 [IDX] Generating video index for job 1688086740-77
2023/06/29 20:59:22.031685 [TVE] stream timestamps: history: start_at=2023-06-29T20:58:19-04:00 end_at=2023-06-29T20:59:13-04:00 live_delay=2.92068s
2023/06/29 20:59:22.031876 [TNR] Opened connection to TVE-Spectrum for ch6044 HISTORY
2023/06/29 20:59:22.033507 [DVR] Recording for job 1688086740-104 from TVE-Spectrum ch6044 into "TV/Alone/Alone S10E04 Lake of Thieves 2023-06-29-2059.mpg" for 1h37m39.153982s
2023/06/29 20:59:22.314352 [IDX] Generating video index for job 1688086740-104
2023/06/29 21:00:21.278909 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 7AA3 at pos. 0x1f82f5e with length 0x1810c4080ff considered as invalid data. Last known good position 0x1f7f053, 1 unknown elements in a row
2023/06/29 21:00:21.278956 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 21:26:21.661630 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element B5 at pos. 0x9054a27 with length 0xfb67501 considered as invalid data. Last known good position 0x90541a2, 1 unknown elements in a row
2023/06/29 21:37:49.322726 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 6 indicated by an EBML number's first byte 0x05 at pos 205726281 (0xc432249) exceeds max length 4.
2023/06/29 21:37:49.323922 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 21:40:09.741912 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 5753 at pos. 0xcdf9e1b with length 0x17c10d considered as invalid data. Last known good position 0xcdefac4, 3 unknown elements in a row
2023/06/29 21:40:09.743348 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 21:45:25.121292 [DVR] Fetched guide data for XMLTV-PlutoTV in 0s
2023/06/29 21:45:33.670604 [DVR] Indexed 3985 airings into XMLTV-PlutoTV (232 channels over 27h0m0s) + 119 skipped [8s index]
2023/06/29 21:45:33.754593 [DVR] pruned 1122 replaced airings in 0s.
2023/06/29 21:45:34.255014 [DVR] Fetched guide data for XMLTV-EPlusTV in 0s
2023/06/29 21:45:35.392857 [DVR] Indexed 363 airings into XMLTV-EPlusTV (29 channels over 222h20m0s) + 0 skipped [1s index]
2023/06/29 21:45:35.555064 [DVR] pruned 15 replaced airings in 0s.
2023/06/29 21:45:38.876314 [DVR] Waiting 14m21.123705s until next job 1688090400-214 Booked: First Day In
2023/06/29 21:47:32.409279 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 5 indicated by an EBML number's first byte 0x08 at pos 250501640 (0xeee5a08) exceeds max length 4.
2023/06/29 21:52:41.996514 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 5 indicated by an EBML number's first byte 0x0c at pos 272259768 (0x103a5ab8) exceeds max length 4.
2023/06/29 21:52:41.996582 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 21:52:56.086294 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 5 indicated by an EBML number's first byte 0x09 at pos 284814786 (0x10f9edc2) exceeds max length 4.
2023/06/29 21:52:56.086376 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 21:55:30.055866 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element C4 at pos. 0x18b3bf36 with length 0x61f9ce019 considered as invalid data. Last known good position 0x18a98226, 4 unknown elements in a row
2023/06/29 21:55:30.055960 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:00:00.040620 [DVR] Starting job 1688090400-214 Booked: First Day In on ch=[6043]
2023/06/29 22:00:00.040939 [DVR] Waiting 22h58m59.959068s until next job 1688173140-89 The Real Murders of Orange County
2023/06/29 22:00:00.055151 [TNR] Sharing existing connection to TVE-Spectrum for ch6043 AETV (clients=2, len=0)
2023/06/29 22:00:00.056463 [DVR] Recording for job 1688090400-214 from TVE-Spectrum ch6043 into "TV/Booked First Day In/Booked First Day In S01E04 Hooked Booked 2023-06-29-2200.mpg" for 1h6m59.950807s
2023/06/29 22:00:00.436108 [IDX] Generating video index for job 1688090400-214
2023/06/29 22:01:50.301630 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Found unknown-length element with ID 0x6669 at pos. 0x290fe7bb for which no syntax for parsing is available.
2023/06/29 22:01:50.301749 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:03:29.176285 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 1E904265 at pos. 0x2db53958 with length 0x9aa5cb0 considered as invalid data. Last known good position 0x2db281df, 1 unknown elements in a row
2023/06/29 22:03:29.176346 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:04:11.582345 [SNR] Buffer statistics for "TV/60 Days In/60 Days In S08E03 Welcome to Gen Pop 2023-06-29-2059.mpg": buf=0% drop=0%
2023/06/29 22:04:11.592921 [ADS] Detected 12 commercial markers in file-10960: TV/60 Days In/60 Days In S08E03 Welcome to Gen Pop 2023-06-29-2059.mpg
2023/06/29 22:04:11.670668 [DVR] Finished job 1688086740-64 60 Days In
2023/06/29 22:04:11.781501 [DVR] Waiting 22h54m48.218507s until next job 1688173140-89 The Real Murders of Orange County
2023/06/29 22:04:11.784201 [DVR] Processing file-10960: TV/60 Days In/60 Days In S08E03 Welcome to Gen Pop 2023-06-29-2059.mpg
2023/06/29 22:08:17.637556 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 5 indicated by an EBML number's first byte 0x08 at pos 982166975 (0x3a8aadbf) exceeds max length 4.
2023/06/29 22:08:17.637616 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:09:17.213473 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 607E at pos. 0x3c956701 with length 0xeb5ef8 considered as invalid data. Last known good position 0x3c94f95e, 1 unknown elements in a row
2023/06/29 22:09:17.213558 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:09:21.653160 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Invalid length 0x81007880ff83fc > 0x10000000 for element with ID 0xA3 at 0x3cbdf0b1
2023/06/29 22:09:21.653265 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:09:30.126103 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 7 indicated by an EBML number's first byte 0x02 at pos 1025501615 (0x3d1fe9af) exceeds max length 4.
2023/06/29 22:09:30.126158 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:12:24.084744 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] 0x00 at pos 1153539259 (0x44c19cbb) invalid as first byte of an EBML number
2023/06/29 22:12:24.085234 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:14:46.310997 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 80 at pos. 0x4b02b4bc with length 0xfb67501 considered as invalid data. Last known good position 0x4b020748, 1 unknown elements in a row
2023/06/29 22:14:46.311505 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:17:23.528448 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 6 indicated by an EBML number's first byte 0x05 at pos 1368202004 (0x518d1b14) exceeds max length 4.
2023/06/29 22:17:23.528990 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:17:25.476664 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 6 indicated by an EBML number's first byte 0x04 at pos 1369227785 (0x519cc209) exceeds max length 4.
2023/06/29 22:17:34.169473 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 5926 at pos. 0x51da1dd6 with length 0x98de788 considered as invalid data. Last known good position 0x51d9c5e7, 2 unknown elements in a row
2023/06/29 22:18:07.710234 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 2B7856 at pos. 0x532a1aaa with length 0x8c43c considered as invalid data. Last known good position 0x53204582, 4 unknown elements in a row
2023/06/29 22:18:07.710330 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:18:10.628912 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 7E51 at pos. 0x5350a44d with length 0x1bf7be considered as invalid data. Last known good position 0x535052fe, 1 unknown elements in a row
2023/06/29 22:18:10.628983 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:18:14.798502 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Found unknown-length element with ID 0x1FB67501 at pos. 0x5366fd2e for which no syntax for parsing is available.
2023/06/29 22:18:14.798580 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:19:13.705221 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 51DF at pos. 0x55fd99db with length 0x3acf043 considered as invalid data. Last known good position 0x55fcf5f8, 1 unknown elements in a row
2023/06/29 22:19:13.705283 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:22:44.295450 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 5 indicated by an EBML number's first byte 0x08 at pos 1609277683 (0x5feba0f3) exceeds max length 4.
2023/06/29 22:22:44.296431 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:23:18.580331 [HLS] ffmpeg: chrome-Bravo (East): [NULL @ 0x7f77b0204740] Error parsing Opus packet header.
2023/06/29 22:23:18.580387 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Length 7 indicated by an EBML number's first byte 0x03 at pos 1636268676 (0x61877a84) exceeds max length 4.
2023/06/29 22:23:27.072650 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Invalid track number 46303731099979519
2023/06/29 22:23:47.355000 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element FE at pos. 0x630bebbe with length 0x7a395787 considered as invalid data. Last known good position 0x630b6128, 1 unknown elements in a row
2023/06/29 22:23:47.355487 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:23:57.857537 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element F0 at pos. 0x639d8c4b with length 0x403408bbd considered as invalid data. Last known good position 0x639bfb94, 2 unknown elements in a row
2023/06/29 22:23:57.857603 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:24:40.396366 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 5D76 at pos. 0x6508a07f with length 0x1eb5d7 considered as invalid data. Last known good position 0x6507f785, 7 unknown elements in a row
2023/06/29 22:24:40.396450 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:25:21.375188 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 5509 at pos. 0x665a918f with length 0x13f023 considered as invalid data. Last known good position 0x6659f9f4, 4 unknown elements in a row
2023/06/29 22:25:21.375248 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:26:48.123060 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 73E9 at pos. 0x6a6b233b with length 0xf5f5de0 considered as invalid data. Last known good position 0x6a69f1d3, 1 unknown elements in a row
2023/06/29 22:26:48.123651 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:26:58.429824 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 5DEA at pos. 0x6acb0fda with length 0x1c50de5 considered as invalid data. Last known good position 0x6acae91a, 1 unknown elements in a row
2023/06/29 22:26:58.429891 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:28:46.508308 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element E2 at pos. 0x6eddec2f with length 0xcb5fb65 considered as invalid data. Last known good position 0x6edd5002, 5 unknown elements in a row
2023/06/29 22:28:46.508566 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:30:37.229006 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element F0 at pos. 0x736f63f5 with length 0x11fad9 considered as invalid data. Last known good position 0x736ebd93, 1 unknown elements in a row
2023/06/29 22:30:37.229087 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:31:08.092895 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 12A23E1A at pos. 0x74cec5d5 with length 0x14ed7e considered as invalid data. Last known good position 0x74ce41db, 3 unknown elements in a row
2023/06/29 22:31:29.359853 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Unknown element 97 at pos. 0x758594d9 with length 0x2f6fef3 considered as invalid data. Last known good position 0x7584aa7c, 3 unknown elements in a row
2023/06/29 22:31:29.359895 [HLS] ffmpeg: chrome-Bravo (East): [matroska,webm @ 0x7f77ae704a00] Seek to desired resync point failed. Seeking to earliest point available instead.
2023/06/29 22:33:00.152434 [ERR] Error during stream M3U-ChromeCapture ch4003 Bravo (East): read |0: file already closed
2023/06/29 22:33:00.152478 [TNR] Closed connection to M3U-ChromeCapture for ch4003 Bravo (East)
2023/06/29 22:33:00.194750 [HLS] ffmpeg: chrome-Bravo (East): av_interleaved_write_frame(): Broken pipe
2023/06/29 22:33:00.195017 [HLS] ffmpeg: chrome-Bravo (East): Error writing trailer of pipe:: Broken pipe
2023/06/29 22:33:00.195049 [HLS] ffmpeg: chrome-Bravo (East): Error closing file pipe:: Broken pipe
2023/06/29 22:33:00.228206 [SNR] Buffer statistics for "TV/Project Runway/Project Runway S20E04 Coronation Day 2023-06-29-2059.mpg": buf=0% drop=0%
2023/06/29 22:33:00.244242 [DVR] Finished job 1688086740-77 Project Runway
Chrome Capture log:
[2023/06/29 20:59:21.738] streaming https://www.nbc.com/live?brand=bravo&callsign=bravo_east
[2023/06/29 22:33:00.236] GET /stream/bravo from ::ffff:192.168.4.13 responded 200 in 796.389 ms
[2023/06/29 22:33:00.349] finished https://www.nbc.com/live?brand=bravo&callsign=bravo_east
Any idea why? I reran regenerate video index and fix timestamps, but the image stayed stuck.
Im considering updating my old 2010 mac mini to an M1 machine with 512gb internal drive.
Are there any issues running Ventura? Ive heard good things and bad, especially with some core audio issues on Ventura.
For those that have tested the beta chrome capture on an M1 mac mini, what versions of OS have you used?
Thanks
I've successfully gotten the NBC channels to load into this. Does this also allow you to do the same from CBS, Fox or ABC live streams on their websites?
Not as of yet I tried all the suggestions BUT i cant find the "button" in the code to add a "click" to.
