Chrome Capture for Channels
can we have it pull from gpu?
yep. It's definitely working on MacOS. BETA: Chrome Capture for Channels - #8 by tmm1
Linux I am not entirely sure of just yet.
do you have to configure it differently? I am using a pc.
Try the latest changes (git pull then node main.js again)
This could be added easily I think. Do you have a web page in mind that would need it?
Still same error, and trying to tune an NBC network generates this error, which wasn't present before:
failed to stream undefined ProtocolError: Protocol error (Page.navigate): Invalid parameters Failed to deserialize params.url - BINDINGS: mandatory field missing at position 50
    at new Callback (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Connection.js:62:35)
    at CallbackRegistry.create (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Connection.js:108:26)
    at Connection._rawSend (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Connection.js:224:26)
    at CDPSessionImpl.send (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Connection.js:433:78)
    at navigate (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Frame.js:100:47)
    at Frame.goto (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Frame.js:78:13)
    at CDPPage.goto (/home/david/chrome-capture-for-channels/node_modules/puppeteer-core/lib/cjs/puppeteer/common/Page.js:444:39)
    at /home/david/chrome-capture-for-channels/main.js:170:18
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
What version of chrome? sounds like its incompatible, I'm guessing its too old.
It was Chrome 114. I tried 115 and I don't get that error anymore, and am able to login to Google. I will continue testing to see if I can get it fully working.
FYI, on my Windows 11, I was running these commands in a PowerShell terminal. Everything was working fine until "npm install":
PS C:\Users\mjitk\chrome-capture-for-channels> npm install
npm : The term 'npm' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ npm install
    + CategoryInfo          : ObjectNotFound: (npm:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
Then I opened a regular cmd terminal window and it worked there:
C:\Users\mjitk>cd chrome-capture-for-channels
C:\Users\mjitk\chrome-capture-for-channels>npm install
added 264 packages, and audited 265 packages in 14s
30 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
npm notice
npm notice New minor version of npm available! 9.6.7 -> 9.7.1
npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.7.1
npm notice Run npm install -g [email protected] to update!
npm notice
I'm posting this in case it happens to somebody else.
Probably you need to open a new powershell window after the winget commands.
FYI I am also working on building exe files which can be downloaded and used directly for simplicity.
isn't cnbc the new channel
Thanks for adding this great feature. Unfortunately I must have something set up incorrectly. The channel keeps trying to reconnect and then says it lost connection to the tuner. This is my setting:
#EXTM3U
#EXTINF:-1 channel-id="weatherscan", Weatherscan
chrome://127.0.0.1:5589/stream/weatherscan
This is great! Appreciate the work here!
I too am getting some issues with window sizing:
First one is from NBC - lot of black around plus vertical scroll bar
Second is one I added for Boomerang via Hulu (and occurring on any Hulu URL I've added):
EDIT: As far as NBC goes - looks like this may be related to the display resolution of the VM I was using - adjusted to a higher resolution and that eliminated most (not all) of the black border, but still have the vertical scroll bar. Hulu however still appears the same
Yes. It was spelled “cBNC” in the code instead of “cNBC”
I've published a Docker that uses Xvfb:
docker run -d --name chrome-capture -p 5589:5589 fancybits/chrome-capture-for-channels
Note that there's no way to interact with the browser right now so you won't be able to login. It works with weatherscan though
Ok, got everything setup, but what do I put in the field for the epg guide data when setting this up in the channels interface?
Nothing. There's no EPG
You have to map it after it is setup in channels.
Can you screenshot what the source chrome window looks like?
