Anyone have any ideas on how to fix this? Chrome capture is working fantastic with Spectrum on my 5800H Beelink using Windows 10 and exe file, but I have to wait over 5 minutes to watch a 4th channel after viewing 3 prior channels within a 5 minute timeframe (can't channel surf). It would be perfect if not for this issue. @tmm1, any ideas? Is CC4C built to retain the prior http session for an extended time for some reason? Thanks
I started out adding station id to my M3U but found that was unnecessary. I found it easiest and most reliable to:
- Manage lineup
- Click + to the right to assign the proper guide data
- Within the search box, type the station 'id letters', for example for Starz Classic, type SZECLHD. Sometimes it helps to select from dropdown 'search all lineups'. I found these 'id letters' or whatever they are called on my Spectrum guide at watch.spectrum.net
I hope that helps.
This. I don't know..not trying to record everything but put all the channels in one spot. Does anyone know all the networks?
Peacock NBC Networks
Disney Networks
Viacom
Etc is there a master list?
Trying to really find the channels that are useful here.
Channels that are unique to channels and not on tve:
Fox
Myxx(mine is my68)
CW(or is this online?)
NBC channels (I hear they glitch out or do weird ads on tve) better to use cable login
FOX (used to have tve, but a lot of people can't get any more)
PAC12 Network
Spectrum Sportsnet
I am also adding a script to make The Mountain West network work. (Available online)
Using the "Find Gracenote Station IDs" tool I have built-in to OliveTin-for-Channels, which queries your Channels DVR server for the info, here's what was returned:
Thx, I figured it out. I just had to select "all sources."
Isn't nbc very buggy? (all streams)?
yes
I assume you used ffmpeg for the remux. Did you peform the remux in the main.js file? If so can you share the code you used? It is beyond my coding skills
You can use FAST channels to bring it in, but I am using Sling, which is stable.
@fjh3, here is the post from earlier in this thread with commands I use to make a recording editable. I'm not running these in the main.js file, but after the recording is done by Channels. I use ffmpeg command lines to remux, then change the audio to aac. Obviously, the "input.mpg" should be the file you want to convert, this can also include the path to the file, if you don't have the recording in the same directory as ffmpeg. Meaning the command could also be something like:
ffmpeg -i "D:\folder\input.mpg" -c copy "D:\folder\output.ts"
I have not had any luck to trying to Install Chrome Capture For Channels I have a Apple Imac is there anyone here who can help me with step by step instructions to install it on Apple Operating system only it would greatly appreciated.
Mac directions are already in the step-by-step simplified installation instructions above. Just ignore anything that says "Windows" or "Docker".
If you are held up at a specific step, you can tell us which one and what you've tried. Only then will we be able to help.
@sheepy, thanks. I tried to change the format specifications in the main.js file. It appears that only the WebM format will work with CC4C, which limits the audio codecs to due vorbis or opus. When tried vorbis it slows down the transcoding. Luckily, the developer of the Sparkle TV apps, is very responsive and is going to add opus as a supported codec in the near future.
If you're having problems running npm run build on Windows, I learned the problem is when NPM attempts to compile for Mac x64 (it is set up to compile for multiple OSs at same time). This results in the Error: spawn UNKNOWN error several other users have posted about. The solution is to open package.json, look under targets, and remove everything besides latest-win-x64.
PS My son helped me figure this out thankfully so I can't really take the credit!
I also tried to modify the main.js file to change the audio format, but ran into the same issues. The opus codec isn't a big deal for me, because I'm generally watching in Channels, and then deleting the file. But, occasionally, there is a show I want to archive and have to run the ffmpeg commands to be able to edit out the commercials. Hopefully the developer of Sparkle can support opus for you.
With special thanks to @bnhf for helping me work through my own testing issues, I have now updated the Simplified Installation Instructions above with detailed steps and screen shots for deploying via a Portainer Stack in Docker. As noted, this completely replaces the default Docker installation method and alleviates all issues like login problems and being able to modify specific settings on a variable basis.
I also made some other quality of life and general cleanup adjustments, too, so enjoy!
fjh3,
I did not remux in the main.js, I tried it on the completed recording. BTW, it did not clear up the issue, but the problem has not reoccurred,
When I first evaluated CC4C a while back, I experienced mild stuttering. That was while running Windows in a VM under Proxmox. I'm now trying a quick re-evaluation before deciding if I want to buy a GPU capable of hardware encoding and trying again. I would still be running Windows in a VM but with GPU pass through this time.
I don't currently have a supported streaming service to try but that will be changing very soon. For now, I'm trying various sources I know of by passing them in the url parameter passed to CC4C. Unfortunately, Chrome always tries to download the content instead of playing it. If Chrome downloads it, there's nothing for CC4C to capture. Does anyone know how Chrome decides whether to play content or download it?
Same. But I did see that in the puppeteer-stream repository there is an example of piping through ffmpeg that looks like it might work. ffmpeg.js Unfortunately I do not have the skills to translate that into main.js. It is not obvious to me how to create a pipe "chain" in that context. It is on my list of fun projects to attempt when I get some time.
Anyone look at this?
other than the funky web/opus codec, this has been every bit as solid as TVE for me.
Turn bitrate to 5.65mbit, (thats what spectrum uses) - not many others go higher.
Enable hardware encoding, should reduce most stutter issues.
