Please also upgrade your DVR to latest prerelease using the check for update dropdown
Thank you for pointing out the NTFS issue--I was unaware of it; can easily re-format. Which FS do you suggest?
I am still not sure I follow the root cause, however--is it a filesystem issue or is it a networking issue?
It's not clear because I still haven't seen the relevant logs. I think its a network issue, but it possible that resource exhaustion in terms of disk i/o or CPU would present itself in the same way and cause the network threads to be unable to drain data.
If you can check the filesystem that will be a great first step. exFAT is preferred for the SHIELD.
Please update to the latest prerelease and resubmit diagnostics immediately after the upgrade completes.
OK, thanks--reformatting the usb drive now. Got antsy so spun up a t4g.micro in us-west-1 and so far it definitely feels more responsive than my old setup; CPU accumulating enough that I may bump it down to a nano if that continues. Only real cost risk appears to be with storage, so giving it a whirl with cold HDD (sc1) EBS. If this ends up working and I can keep the storage costs down I may just continue running it there.
Was it definitely ntfs before? Were you able to upgrade and submit diagnostics first?
Definitely NTFS. Have not upgraded yet. I thought diagnostics were short-lived and irrelevant at this point unless it was just after a failure?
Given that the shield is so flaky, and I'm also learning that CPU usage appears to be minimal (with the possible exception of commercial detection), if I do decide to run one "on prem" I'm wondering if a raspberry pi would be more stable as well as allow for better storage options (e.g. xfs on sata)?
It's fine. I was trying to collect some more diagnostics to see if we can identify NTFS drives and warn users during setup.
