Best not to mess with it. You will make it worse 99.9% of the time.
The default max_commercialbreak in comskip.inI is 660 seconds (10 min). The long break in Jimmy Kimmel (and Cobert and Fallon) is 11 minutes, so change to: max_commercialbreak=720 in comskip.inI
Thanks @tonyt57 . There was no entry for max_commercialbreak in comskip.ini, only min_commercialbreak. I added a line to set it to 720 for the latest edition of comskip.ini (as I said before, there are multiple versions in the log folder). Let's see what that does!
Might be helpful for those not familiar
There are many settings in comskip that have default values if not set in comskip.ini. If you were to be able to see the log file when comskip runs you would see all the settings comskip used. If not in the ini file, max_commercialbreak=600
See the previous post by @ChDVRuser regarding how Channels handles the ini file
