Whoa, that's cool.
So you can have your own, totally custom comskip.ini (by placing said .ini file in your "data" directory), or, if you only want to add new settings (and not override any that are set by default by Channels, since comskip uses "first match wins" instead of "last match wins"), you can PUT them to the comskip/ini/{setting}/{value} API endpoint. Very cool.
Thanks for the pointer!
