FYI, I'm working on a V2 that should eliminate a lot of the quality and control over desktop issues, and also make things a little easier for Mac/Linux transition. It is based on something Aman sent over to me, so I'm going to get it clean and documented before releasing.
I wonder why their code is private. Has anyone reached out to them and tried to see if they would be willing to help? It would be such a game changer for all of us, especially since it appears that the DRM trend will continue.
In any case, thank you so much for all of your hard work, and I look forward to following your progressâŚ
Yeah the big question is if any browser can play this DRM content, it shouldn't be impossible there has to be a way for code to be able to do it with libraries.
Solved all my (self-inflicted permission) issues and now working like a champ on my physical machine! Got Hulu working to feed my additional subscription stations that do not have TVE. Thanks @babsonnexus for all the work on this solution.
In my experience, CC4C does remember logins after the first time.
You could say this uses "normal" Chrome, but this method as I last worked on it completely took over Chrome, so you couldn't use Chrome for anything else. CC4C is much more elegant. That said, there may be an upgraded use for this in the future, we'll see........
You all are referring to the DRM that makes the tve feed go black when you use any type of screen recorder right? If so, the fix is to disable hardware acceleration.
Just noticed someone suggested this. I'll leave this here anyway in case it helps someone. Disabling hardware acceleration fixed DRM issues for me.
