Drobo package debugging
Drobo5N:~/Shares/DroboApps/ChannelsDVR_1.0.0/channels-dvr/data # ls -ltr
-rw------- 1 root root 131072 Apr 7 13:55 settings.db
-rw-r–r-- 1 root root 520 Apr 7 13:55 channels-dvr.log
Okay, there’s an issue with SSL. I wonder how wget worked earlier… Could you post the rest of the output from wget --version?
See if there’s an /etc/ssl directory
No /etc/ssl dir
Drobo5N:~/Shares/DroboApps/ChannelsDVR_1.0.0/channels-dvr/data # wget --version
GNU Wget 1.16.3 built on linux-gnueabi.
+digest +https +ipv6 -iri +large-file +nls +ntlm +opie -psl +ssl/openssl
Wgetrc:
/etc/wgetrc (system)
Locale:
/usr/share/locale
Compile:
/home/drobo/xtools/toolchain/5n/bin/arm-marvell-linux-gnueabi-gcc
-DHAVE_CONFIG_H -DSYSTEM_WGETRC="/etc/wgetrc"
-DLOCALEDIR="/usr/share/locale" -I. -I…/lib -I…/lib
-I/home/drobo/build/wget/target/install/include -DNDEBUG
-march=armv7-a -mcpu=marvell-pj4 -mfpu=vfpv3-d16 -mfloat-abi=softfp
-Os -fPIC -ffunction-sections -fdata-sections
Link:
-DNDEBUG -march=armv7-a -mcpu=marvell-pj4 -mfpu=vfpv3-d16
-mfloat-abi=softfp -Os -fPIC -ffunction-sections -fdata-sections
-Wl,-rpath,/mnt/DroboFS/Shares/DroboApps/wget/lib
-L/mnt/DroboFS/Shares/DroboApps/wget/lib
-L/home/drobo/build/wget/target/install/lib -Wl,–gc-sections
/home/drobo/build/wget/target/install/lib/libssl.a
/home/drobo/build/wget/target/install/lib/libcrypto.a -ldl -lz -lrt
ftp-opie.o openssl.o http-ntlm.o …/lib/libgnu.a
Copyright © 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
http://www.gnu.org/licenses/gpl.html.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Originally written by Hrvoje Niksic [email protected].
Please send bug reports and questions to [email protected].
which wget
I guess maybe its installed under /mnt/DroboFS/Shares/DroboApps/wget ?
Try ls -Ralh /mnt/DroboFS/Shares/DroboApps/wget | grep ssl
Drobo5N:~/Shares/DroboApps # which wget
/usr/bin/wget
Is there an /etc/pki ?
nope
Okay, well, lets just set it up:
mkdir -p /etc/ssl/
wget -O /etc/ssl/cacert.pem https://curl.haxx.se/ca/cacert.pem
Then stop and start the DVR, see if it works.
same issue
2017/04/07 14:30:51 [SYS] Starting Channels DVR v2017.04.06.0200 (linux-armv7l) in /mnt/DroboFS/Shares/DroboApps/ChannelsDVR_1.0.0/channels-dvr/data
2017/04/07 14:30:52 [HDR] Found 1 devices
2017/04/07 14:30:52 [SYS] Started HTTP Server
2017/04/07 14:30:52 [SYS] Bonjour service running for dvr-drobo5n.local. [10.0.1.2]
2017/04/07 14:30:52 [SYS] Error checking for update: Get https://channels-dvr.s3.amazonaws.com/latest.json: x509: failed to load system roots and no roots provided
couldn’t open settings.db: timeout
2017/04/07 14:31:30 [AUTH] Error during oauth: Post https://community.getchannels.com/oauth/token: x509: failed to load system roots and no roots provided
My bad:
mkdir -p /etc/ssl/certs
mv /etc/ssl/cacert.pem /etc/ssl/certs/cacert.pem
looks like it is working. got past login screen. setting up and testing recording now
Recordings are working. Thanks for your help
If you don’t mind, can you stop the DVR and delete the app from the drobo?
Then try installing this new package, which should contain all the fixes we found today:
https://channels-dvr.s3.amazonaws.com/drobo/ChannelsDVR.tgz
sure. do you need me to blackout the SSL items too?
Yea an rm -rf /etc/ssl wouldn’t hurt. The new package should put them back.
