Seems to die or get cut off mid stream. Sometimes it does look like it's during a commercial break but other times it's during the game so I'm not positive it's the ads.
Hello, I can't get any EPlusTV channels to show up in my automatic channels. I've searched for the issue in this thread and from what I can tell it was resolved a while ago, so probably something I'm doing wrong. I've tried this with both dedicated linear and non-linear. I've created the following automatic channels in Channels DVR
Collection Name: NFL
Genres: Football
Sources to exclude:[NONE]
Keywords: NFL
HD[checked]
Collection Name - MLB
Genres: Baseball
Keywords: MLB
HD[checked]
BTW, kudos for the great work, I've only recently gotten started with Channels DVR w/EPlusTV. I'm impressed. Any help on this would be appreciated. Thank you.
Nevermind, I unchecked the HD box and they appeared. :man_shrugging:
Thank you.
Can anyone get Gotham Sports to work at all anymore?
yes network on gotham sports works fine for me. make sure you are on the tonywagner docker.
Gotham Sports works for me. Occasionally I need to restart the docker and/or refresh my gotham sports credentials, but it seems kinda random on when I need to do that.
However, I almost always get "recording interrupted" when recording from Gotham Sports channels. Sometimes it's just minor glitches that are barely imperceptible when watching, other times a recording of a game that should be 3 hours long completely craps out after 20 minutes. No idea what is causing that. Curious if others have seen similar behavior?
Yeah, I got it working after forcing Gotham Sports to reauthorize my credentials. Clicking the Re-authenticate button didn't do anything other than ask me to log in with my Gotham login and password. But what I needed was that link that gets generated the first time you log in that allows you to select your TV provider after logging into Gotham Sports.
The steps I took to fix it was completely disabling Gotham Sports, then I restarted the Container, then re-enabled the setting, logged in, and the link was there. Now it's working. Hope this helps anyone else with the same issue!
Just signed up for fox one but don't see it in eplustv really looking forward to watching fx,fxx and fxm again
Anyone know if the FoxOne/ESPN bundle includes ESPN2, ESPN+, etc along with regular ESPN?
FX, FXX and FXM aren't on fox One.
FS1, FS2 Fox news and Fox business along with your local fox affiliate are on the app.
No Channels intigration as of yet.
Hopefully it's coming to EPlusTV soon
Yep, those are Disney-owned stations!
Confusion on this might be because Sling has the Select bundle which includes FX with FS1, Fox News, etc. You can then use TVE to access those. Unfortunately, no FS2 or FXX with the Sling bundle.
The subscription is ESPN Unlimited + Fox One, so it should have all of ESPN including the linear channels.
Direct subscriptions to ESPN probably will not work through EPlusTV right now as the ESPN integration is only through TVE or ISP login.
Whoops I assumed those were fox due to the "f" at the beginning I canceled fox one and went back to fubo.
I could get it to work if I got a login to test, but it wouldn't play nice with eplustv. It would have to be its own thing.
ESPN Deportes works on browser but not on the plugin, may need to sign back in. since abc is drm doesnt it need to be removed from the docker?
I don't have a login to test as I don't directly subscribe, but I would think at worst it could be added as a separate provider and at best could be integrated into the espn-handler where you could choose on the index page which way to login and the rest of the calls to espn would flow as is.
Is Deportes working for yall
Hey @tonywagner are we still implementing Fox one ?
