Sorry I didn’t see this until now. Restarting the container or rebuilding the EPG would have been troubleshooting steps, although if you were 2+ hours past the event start time, those steps may not have helped.
Man...bots are running wild :rofl::joy:
The version check mismatch is fixed in v4.14.11, along with a new channel logo (thanks @maddox) and fixed PWHL video playback.
Just dropping back in here Gotham Sports wont finish authentication After clicking on enable gotham it shows my email login then gives me limk to website all that seems to work BUT when looking at Eplustv page it just spins at the Trying to refresh Adobe auth ... line
Clean latest install of container BUT still no love
No rush as baseball is a ways away
I cannot get Eplus to update anymore. I was updating with Wathctower in Docker but that doesn't work. I even deleted and re-added the watchtower container and that did not help. How is everyone else updating? I'm 4.14.9.
Portainer stack
Screenshot 2026-02-01 at 13-43-49 Portainer local Screenshot 2026-02-01 at 13-44-10 Portainer local
Thanks. That worked!
Usually watchtower does the trick so...yeah
Looks like the ESPN family has been DRMed and doesn't work anywhere now.
I ran into an issue today where EplusTV was in a cycle of constant crashes, about once a minute. To access the interface I had to stop the container, delete the configuration files, and restart it. I thought maybe it was ESPN since they recently added DRM so I started setting it up again without ESPN enabled but ran into the same problem. Tried again and started with PWHL since that's free and was recently updated and it started crashing again. Right now it's working with only Big Ten Plus enabled so I'm not sure it it's only PWHL being enabled that will cause it to crash or if other services do the same.
Here's what shows up in the log each time it crashed:
at processTicksAndRejections (node:internal/process/task_queues:103:5)
at b (https://static.klaviyo.com/onsite/js/atlas.edd2d5e271f10186d9d0.js?cb=2:1:24959)
at Yc (https://static.klaviyo.com/onsite/js/customerHubRoot.7bbd02908fef2a58020c.js:1:276291) ReferenceError: fetch is not defined
I am seeing the same crash with PWHL enabled. I wonder if it is somehow related to their Olympic break. Leave the provider disabled for now (next game isn’t until Feb. 26 anyway) and I’ll try to push an update to fix it soon.
Another user reported the same on GitHub: ESPN Streams · Issue #241 · tonywagner/EPlusTV · GitHub
I will plan to disable the ESPN provider in the next update.
I still run this container, but with the loss of ESPN and ESPN+ channels and the ability to grab Fox networks elsewhere (TVE, ADBTuner), is there much benefit to this container pulling in channels anymore? I guess one is the NFL Prime Thursday night games still. Anything I'm missing?
I currently use for BTN+ games. I would also use for Fox networks as the quality is better than TVE if it wasn't for the consistent steam failures :confused:
I use it for Paramount+, lots of soccer games coming through
Works well for NFL+ Premium which includes RedZone in-season.
I use it for PWHL and KBO, as well as Hudl for small college conferences.
I pretty much only use it for TNF on Prime now. In 2024 we would get a bonus NFL+ game every Sunday but that didn't happen last year.
It did a pretty good job for me with NFL Sunday Ticket, and I use it regularly for Paramount+ games
I use it for paramount+ sports on the FOX networks occasionally.
