I’d love to know which version you were using before your upgrade to 4.15.
My fox one hasn’t worked in weeks. If I rebuild the container it will usually work for a couple hours but then it’s back to chunklist errors and 404’s. Sometimes it won’t even work after a rebuild. No ip changes here.
I’m wondering if it is broken for more people than they realize because it fails but channels just tunes to the TVE equivalent behind the scenes.
Nope.
I don't get Fox via TVE and I have my HDHR tuner disabled on this server.
No, don't think so. I have it working via another source, just curious as to why it doesn't work with eplus.
I think the issue is the same I've seen with that other source, if it doesn't get the cloudflare URL (starts with cf.edge...) it doesn't work reliably, i.e. fa.edge... is unreliable.
For those wondering, when you authenticate with Fox One you can use the videodownloadhelper chrome extension to find the cloudflare URL for each channel, or just inspect the channel. You have to go into the live section of Fox One and then select a channel to see those. If you don't get the cloudflare URL you have to keep reloading until you get it. But from that point if you're authenticated you're good to go, it works for months.
No, it's not a location change issue.
Surfing through the Fox One linear channels I have from E+TV
2026/03/13 17:17:43.384002 [TNR] Opened connection to M3U-ePlusLineargracenote for ch1 FOX
2026/03/13 17:17:43.384066 [HLS] Starting live stream for channel 1 from 192.168.1.8 (bitrate=8588kbps)
2026/03/13 17:17:44.219335 [HLS] Probed live stream in 834.975635ms: h264 1280x720 progressive 3541771bps
2026/03/13 17:17:47.607593 [HLS] Stopping transcoder session ch1-dANY-ip192.168.1.8 (out=5.984867s finished=false first_seq=1 last_seq=4)
2026/03/13 17:17:47.628377 [TNR] Closed connection to M3U-ePlusLineargracenote for ch1 FOX
2026/03/13 17:17:58.527087 [TNR] Opened connection to M3U-ePlusLineargracenote for ch2 FS1
2026/03/13 17:17:58.527138 [HLS] Starting live stream for channel 2 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:17:59.406040 [HLS] Probed live stream in 878.563245ms: h264 1920x1080 progressive 6874407bps
2026/03/13 17:18:03.035096 [HLS] Stopping transcoder session ch2-dANY-ip192.168.1.8 (out=5.997267s finished=false first_seq=1 last_seq=5)
2026/03/13 17:18:03.051484 [TNR] Closed connection to M3U-ePlusLineargracenote for ch2 FS1
2026/03/13 17:18:08.889118 [TNR] Opened connection to M3U-ePlusLineargracenote for ch3 FS2
2026/03/13 17:18:08.889183 [HLS] Starting live stream for channel 3 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:18:09.737531 [HLS] Probed live stream in 847.919606ms: h264 1920x1080 progressive 2221697bps
2026/03/13 17:18:12.482366 [HLS] Stopping transcoder session ch3-dANY-ip192.168.1.8 (out=0s finished=false first_seq=1 last_seq=2)
2026/03/13 17:18:12.502458 [TNR] Closed connection to M3U-ePlusLineargracenote for ch3 FS2
2026/03/13 17:18:19.381611 [TNR] Opened connection to M3U-ePlusLineargracenote for ch4 B1G Network
2026/03/13 17:18:19.381708 [HLS] Starting live stream for channel 4 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:18:20.442249 [HLS] Probed live stream in 1.060226135s: h264 1920x1080 progressive 8379443bps
2026/03/13 17:18:23.165625 [HLS] Stopping transcoder session ch4-dANY-ip192.168.1.8 (out=5.994s finished=false first_seq=1 last_seq=2)
2026/03/13 17:18:23.202411 [TNR] Closed connection to M3U-ePlusLineargracenote for ch4 B1G Network
2026/03/13 17:18:32.575210 [TNR] Opened connection to M3U-ePlusLineargracenote for ch5 FOX News Channel
2026/03/13 17:18:32.575268 [HLS] Starting live stream for channel 5 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:18:33.425076 [HLS] Probed live stream in 849.533989ms: h264 1920x1080 progressive 3239891bps
2026/03/13 17:18:38.471607 [HLS] Stopping transcoder session ch5-dANY-ip192.168.1.8 (out=10.006667s finished=false first_seq=1 last_seq=6)
2026/03/13 17:18:38.491423 [TNR] Closed connection to M3U-ePlusLineargracenote for ch5 FOX News Channel
2026/03/13 17:18:45.428390 [TNR] Opened connection to M3U-ePlusLineargracenote for ch6 FOX Business Network
2026/03/13 17:18:45.428459 [HLS] Starting live stream for channel 6 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:18:46.486113 [HLS] Probed live stream in 1.057289659s: h264 1920x1080 progressive 3992644bps
2026/03/13 17:18:48.750688 [HLS] Stopping transcoder session ch6-dANY-ip192.168.1.8 (out=0s finished=false first_seq=1 last_seq=2)
2026/03/13 17:18:48.767735 [TNR] Closed connection to M3U-ePlusLineargracenote for ch6 FOX Business Network
2026/03/13 17:18:55.598084 [TNR] Opened connection to M3U-ePlusLineargracenote for ch7 TMZ
2026/03/13 17:18:55.598134 [HLS] Starting live stream for channel 7 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:18:56.653986 [HLS] Probed live stream in 1.055513038s: h264 1920x1080 progressive 5364176bps
2026/03/13 17:18:59.692321 [HLS] Stopping transcoder session ch7-dANY-ip192.168.1.8 (out=5.993133s finished=false first_seq=1 last_seq=3)
2026/03/13 17:18:59.712912 [TNR] Closed connection to M3U-ePlusLineargracenote for ch7 TMZ
2026/03/13 17:19:04.263840 [TNR] Opened connection to M3U-ePlusLineargracenote for ch9 Fox Soul
2026/03/13 17:19:04.263903 [HLS] Starting live stream for channel 9 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:19:05.718916 [HLS] Probed live stream in 1.454724793s: h264 1920x1080 progressive 6259666bps
2026/03/13 17:19:08.382243 [HLS] Stopping transcoder session ch9-dANY-ip192.168.1.8 (out=5.990433s finished=false first_seq=1 last_seq=2)
2026/03/13 17:19:08.399909 [TNR] Closed connection to M3U-ePlusLineargracenote for ch9 Fox Soul
2026/03/13 17:19:17.141761 [TNR] Opened connection to M3U-ePlusLineargracenote for ch10 Fox Weather
2026/03/13 17:19:17.141831 [HLS] Starting live stream for channel 10 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:19:18.013860 [HLS] Probed live stream in 871.712964ms: h264 1920x1080 progressive 3436972bps
2026/03/13 17:19:20.139132 [HLS] Stopping transcoder session ch10-dANY-ip192.168.1.8 (out=0s finished=false first_seq=1 last_seq=2)
2026/03/13 17:19:20.158243 [TNR] Closed connection to M3U-ePlusLineargracenote for ch10 Fox Weather
2026/03/13 17:19:28.808807 [TNR] Opened connection to M3U-ePlusLineargracenote for ch11 Fox Live Now
2026/03/13 17:19:28.808867 [HLS] Starting live stream for channel 11 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 17:19:29.871738 [HLS] Probed live stream in 1.062602947s: h264 1920x1080 progressive 7348227bps
2026/03/13 17:19:33.019688 [HLS] Stopping transcoder session ch11-dANY-ip192.168.1.8 (out=5.984667s finished=false first_seq=1 last_seq=3)
2026/03/13 17:19:33.027094 [TNR] Closed connection to M3U-ePlusLineargracenote for ch11 Fox Live Now
Yeah, nothing works.
What is your container using for DNS servers?
exec into container and cat /etc/resolv.conf
Mine is using my ISP's DNS Server
/app # cat /etc/resolv.conf
nameserver      75.75.75.75
I changed mine about 4 months ago since I was having issues.
nameserver 192.168.1.254
search attlocal.net taila8redacted.ts.net
I’ll try to change the dns inside the container.
Ok changed the dns and it is currently working. Fingers crossed it will last longer than a few hours.
I think Fox has wised up to us, I'm getting 403 forbidden on all of the cloudflare URLs even with provider authentication.
As I said, these used to work for months.
Nothing works here either.
Has anyone been able to find any announcement that that Disney/ESPN has stated TVE streams are now DRM? As far as I can tell, Disney has not officially announced TVE feeds are intentionally removed or DRM-restricted. Could this be caused by a change in their API or token validation? Most of what I've read on this topic seems to be conjecture.
It just doesn’t work for more than a few hours.
2026/03/13 23:18:40.169004 [ERR] Failed to start stream for ch5950: M3U: Could not fetch playlist from 192.168.1.152:8000: GET: http://192.168.1.152:8000/chunklist/216/bpm4D1aA.m3u8: 404 Not Found
2026/03/13 23:18:40.246460 [HLS] Couldn't generate stream playlist for ch5950-dANY-d35b2a32664b: M3U: Could not fetch playlist from 192.168.1.152:8000: GET: http://192.168.1.152:8000/chunklist/216/bpm4D1aA.m3u8: 404 Not Found
2026/03/13 23:18:40.246488 [HLS] Stopping transcoder session ch5950-dANY-d35b2a32664b (out=0s finished=false first_seq=0 last_seq=-1)
2026/03/13 23:18:42.267067 [TVE] stream timestamps: fnc: start_at=2026-03-13T23:17:42-05:00 end_at=2026-03-13T23:18:10-05:00 live_delay=27.301066127s
2026/03/13 23:18:42.267122 [TNR] Opened connection to TVE-Spectrum for ch6073 FNC
2026/03/13 23:18:42.267137 [HLS] Starting live stream for channel 6073 from 174.210.4.63 (bitrate=7716kbps
Using the att dns servers
nameserver 68.94.156.1
nameserver 68.94.157.1
I think the channel is his own person numbering.
What is channel 5950
It's like when PBS added DRM to their website TVE streams.
They didn't have to announce it because using a web browser you can still play the streams.
The web browser player supports the DRM used. Channels DVR does not.
That simple.
That’s Fox News from the eplus container. As you can see it failed and falls back to TVE Fox News. Keep in mind 5950 worked just a few hours ago after a new container build using custom dns and fresh authentication in the eplus container web page.
OK. Same here. But trying to play the channel in the DVR web UI player caused CDVR to retry and succeed.
2026/03/13 21:59:07.179304 [ERR] Failed to start stream for ch5: M3U: Could not fetch playlist from 192.168.1.4:8185: GET: http://192.168.1.4:8185/chunklist/216/CmB1MMYR.m3u8: 404 Not Found
2026/03/13 21:59:07.192139 [HLS] Couldn't generate stream playlist for ch5-dANY-ip192.168.1.8: M3U: Could not fetch playlist from 192.168.1.4:8185: GET: http://192.168.1.4:8185/chunklist/216/CmB1MMYR.m3u8: 404 Not Found
2026/03/13 21:59:07.192286 [HLS] Stopping transcoder session ch5-dANY-ip192.168.1.8 (out=0s finished=false first_seq=0 last_seq=-1)
2026/03/13 21:59:08.982100 [ERR] Failed to start stream for ch5: M3U: Could not fetch playlist from 192.168.1.4:8185: GET: http://192.168.1.4:8185/chunklist/216/IQkpcmha.m3u8: 404 Not Found
2026/03/13 21:59:08.989221 [HLS] Couldn't generate stream playlist for ch5-dANY-ip192.168.1.8: M3U: Could not fetch playlist from 192.168.1.4:8185: GET: http://192.168.1.4:8185/chunklist/216/IQkpcmha.m3u8: 404 Not Found
2026/03/13 21:59:08.989374 [HLS] Stopping transcoder session ch5-dANY-ip192.168.1.8 (out=0s finished=false first_seq=0 last_seq=-1)
2026/03/13 21:59:10.894579 [M3U] stream timestamps: foxone.FOX News Channel: start_at=2026-03-13T21:43:42-07:00 end_at=2026-03-13T21:58:47-07:00 live_delay=21.11957805s
2026/03/13 21:59:10.894774 [TNR] Opened connection to M3U-ePlusLineargracenote for ch5 FOX News Channel
2026/03/13 21:59:10.894828 [HLS] Starting live stream for channel 5 from 192.168.1.8 (bitrate=12108kbps)
2026/03/13 21:59:11.696371 [HLS] ffmpeg: ch5-dANY-ip192.168.1.8-remux:  [hls @ 0xba22a40] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2026/03/13 21:59:11.746551 [HLS] Session ch5-dANY-ip192.168.1.8 started in 851.677834ms
2026/03/13 21:59:11.773125 [HLS] Probed live stream in 877.987009ms: h264 1920x1080 progressive 5695477bps
2026/03/13 21:59:17.693061 [HLS] Stopping transcoder session ch5-dANY-ip192.168.1.8 (out=9.99s finished=false first_seq=1 last_seq=4)
2026/03/13 21:59:17.702153 [TNR] Closed connection to M3U-ePlusLineargracenote for ch5 FOX News Channel
2026/03/13 21:59:17.702355 [SNR] Buffer statistics for ch5 FOX News Channel: buf=0% drop=0%
2026/03/13 21:59:17.702472 [SNR] Streaming statistics for ch5 FOX News Channel: timeouts=0 segment_timeouts=0 playlist_timeouts=0
3rd attempt by CDVR worked
I sometimes get that as well but successive retries doesn’t always work.
Don't know if container log will help. I can't make sense of it as it's too verbose.
Starting from the 2nd failure, then success (container log)
2026-03-14T04:59:07.795936493Z Channel #216 has an active event (The Five). Going to start the stream.
2026-03-14T04:59:08.962634580Z Could not parse chunklist properly!
2026-03-14T04:59:08.965762721Z AxiosError: Request failed with status code 406
2026-03-14T04:59:08.965923534Z     at settle (/app/node_modules/axios/lib/core/settle.js:19:12)
2026-03-14T04:59:08.965976776Z     at IncomingMessage.handleStreamEnd (/app/node_modules/axios/lib/adapters/http.js:512:11)
2026-03-14T04:59:08.966029085Z     at IncomingMessage.emit (node:events:520:35)
2026-03-14T04:59:08.966072698Z     at IncomingMessage.emit (node:domain:489:12)
2026-03-14T04:59:08.966114720Z     at endReadableNT (node:internal/streams/readable:1701:12)
2026-03-14T04:59:08.966160106Z     at processTicksAndRejections (node:internal/process/task_queues:89:21) {
2026-03-14T04:59:08.966208267Z   code: 'ERR_BAD_REQUEST',
2026-03-14T04:59:08.966247809Z   config: {
2026-03-14T04:59:08.966286876Z     transitional: {
2026-03-14T04:59:08.966325384Z       silentJSONParsing: true,
2026-03-14T04:59:08.966365347Z       forcedJSONParsing: true,
2026-03-14T04:59:08.966405684Z       clarifyTimeoutError: false
2026-03-14T04:59:08.966446140Z     },
2026-03-14T04:59:08.966483315Z     adapter: [ 'xhr', 'http' ],
2026-03-14T04:59:08.966523055Z     transformRequest: [ [Function: transformRequest] ],
2026-03-14T04:59:08.966564605Z     transformResponse: [ [Function: transformResponse] ],
2026-03-14T04:59:08.966605045Z     timeout: 60000,
2026-03-14T04:59:08.966665294Z     xsrfCookieName: 'XSRF-TOKEN',
2026-03-14T04:59:08.966708106Z     xsrfHeaderName: 'X-XSRF-TOKEN',
2026-03-14T04:59:08.966749024Z     maxContentLength: -1,
2026-03-14T04:59:08.966791498Z     maxBodyLength: -1,
2026-03-14T04:59:08.966834110Z     env: { FormData: [Function [FormData]], Blob: [class Blob] },
2026-03-14T04:59:08.966881092Z     validateStatus: [Function: validateStatus],
2026-03-14T04:59:08.966932404Z     headers: AxiosHeaders {
2026-03-14T04:59:08.966972540Z       Accept: 'application/json, text/plain, */*',
2026-03-14T04:59:08.967015888Z       'Accept-Encoding': 'identity',
2026-03-14T04:59:08.967057582Z       'User-Agent': 'foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)'
2026-03-14T04:59:08.967115893Z     },
2026-03-14T04:59:08.967153520Z     method: 'get',
2026-03-14T04:59:08.967205174Z     url: 'https://cf.edge.foxdtc.digitalvideoplatform.com/<REDACTED>',
2026-03-14T04:59:08.967341802Z     data: undefined
2026-03-14T04:59:08.967388809Z   },
2026-03-14T04:59:08.967427292Z   request: <ref *1> ClientRequest {
2026-03-14T04:59:08.967470264Z     _events: [Object: null prototype] {
2026-03-14T04:59:08.967520642Z       abort: [Function (anonymous)],
2026-03-14T04:59:08.967568691Z       aborted: [Function (anonymous)],
2026-03-14T04:59:08.967609577Z       connect: [Function (anonymous)],
2026-03-14T04:59:08.967670325Z       error: [Function (anonymous)],
2026-03-14T04:59:08.967712124Z       socket: [Function (anonymous)],
2026-03-14T04:59:08.967756642Z       timeout: [Function (anonymous)],
2026-03-14T04:59:08.967797729Z       finish: [Function: requestOnFinish]
2026-03-14T04:59:08.967838573Z     },
2026-03-14T04:59:08.967875291Z     _eventsCount: 7,
2026-03-14T04:59:08.967914378Z     _maxListeners: undefined,
2026-03-14T04:59:08.967956449Z     outputData: [],
2026-03-14T04:59:08.967995325Z     outputSize: 0,
2026-03-14T04:59:08.968034877Z     writable: true,
2026-03-14T04:59:08.968076135Z     destroyed: true,
2026-03-14T04:59:08.968116039Z     _last: true,
2026-03-14T04:59:08.968155960Z     chunkedEncoding: false,
2026-03-14T04:59:08.968196471Z     shouldKeepAlive: true,
2026-03-14T04:59:08.968235855Z     maxRequestsOnConnectionReached: false,
2026-03-14T04:59:08.968276094Z     _defaultKeepAlive: true,
2026-03-14T04:59:08.968318503Z     useChunkedEncodingByDefault: false,
2026-03-14T04:59:08.968368142Z     sendDate: false,
2026-03-14T04:59:08.968417590Z     _removedConnection: false,
2026-03-14T04:59:08.968457831Z     _removedContLen: false,
2026-03-14T04:59:08.968497509Z     _removedTE: false,
2026-03-14T04:59:08.968546093Z     strictContentLength: false,
2026-03-14T04:59:08.968593750Z     _contentLength: 0,
2026-03-14T04:59:08.968633753Z     _hasBody: true,
2026-03-14T04:59:08.968702153Z     _trailer: '',
2026-03-14T04:59:08.968743011Z     finished: true,
2026-03-14T04:59:08.968790696Z     _headerSent: true,
2026-03-14T04:59:08.968830294Z     _closed: true,
2026-03-14T04:59:08.968878561Z     _header: 'GET <REDACTED> HTTP/1.1\r\n' +
2026-03-14T04:59:08.969012194Z       'Accept: application/json, text/plain, */*\r\n' +
2026-03-14T04:59:08.969060796Z       'Accept-Encoding: identity\r\n' +
2026-03-14T04:59:08.969110777Z       'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2026-03-14T04:59:08.969164676Z       'Host: cf.edge.foxdtc.digitalvideoplatform.com\r\n' +
2026-03-14T04:59:08.969216496Z       'Connection: keep-alive\r\n' +
2026-03-14T04:59:08.969259134Z       '\r\n',
2026-03-14T04:59:08.969305225Z     _keepAliveTimeout: 0,
2026-03-14T04:59:08.969345356Z     _onPendingData: [Function: nop],
2026-03-14T04:59:08.969393499Z     agent: Agent {
2026-03-14T04:59:08.969440667Z       _events: [Object: null prototype],
2026-03-14T04:59:08.969489971Z       _eventsCount: 2,
2026-03-14T04:59:08.969530566Z       _maxListeners: undefined,
2026-03-14T04:59:08.968504067Z Could not get chunklist for channel #216.
2026-03-14T04:59:08.969586675Z       options: [Object: null prototype],
2026-03-14T04:59:08.969685711Z       defaultPort: 443,
2026-03-14T04:59:08.969724334Z       protocol: 'https:',
2026-03-14T04:59:08.969762925Z       requests: [Object: null prototype] {},
2026-03-14T04:59:08.969803841Z       sockets: [Object: null prototype] {},
2026-03-14T04:59:08.969848004Z       freeSockets: [Object: null prototype],
2026-03-14T04:59:08.969888162Z       keepAliveMsecs: 1000,
2026-03-14T04:59:08.969929267Z       keepAlive: true,
2026-03-14T04:59:08.969970801Z       maxSockets: Infinity,
2026-03-14T04:59:08.970010820Z       maxFreeSockets: 256,
2026-03-14T04:59:08.970049155Z       scheduling: 'lifo',
2026-03-14T04:59:08.970087736Z       maxTotalSockets: Infinity,
2026-03-14T04:59:08.970127104Z       totalSocketCount: 2,
2026-03-14T04:59:08.970165951Z       agentKeepAliveTimeoutBuffer: 1000,
2026-03-14T04:59:08.970204255Z       maxCachedSessions: 100,
2026-03-14T04:59:08.970243065Z       _sessionCache: [Object],
2026-03-14T04:59:08.970286325Z       Symbol(shapeMode): false,
2026-03-14T04:59:08.970327030Z       Symbol(kCapture): false
2026-03-14T04:59:08.970366300Z     },
2026-03-14T04:59:08.970402163Z     socketPath: undefined,
2026-03-14T04:59:08.970440872Z     method: 'GET',
2026-03-14T04:59:08.970478715Z     maxHeaderSize: undefined,
2026-03-14T04:59:08.970518165Z     insecureHTTPParser: undefined,
2026-03-14T04:59:08.970557519Z     joinDuplicateHeaders: undefined,
2026-03-14T04:59:08.970605533Z     path: '<REDACTED>',
2026-03-14T04:59:08.970724509Z     _ended: true,
2026-03-14T04:59:08.970764849Z     res: IncomingMessage {
2026-03-14T04:59:08.970804975Z       _events: [Object],
2026-03-14T04:59:08.970843613Z       _readableState: [ReadableState],
2026-03-14T04:59:08.970886536Z       _maxListeners: undefined,
2026-03-14T04:59:08.970925550Z       socket: null,
2026-03-14T04:59:08.970963400Z       httpVersionMajor: 1,
2026-03-14T04:59:08.971001881Z       httpVersionMinor: 1,
2026-03-14T04:59:08.971039572Z       httpVersion: '1.1',
2026-03-14T04:59:08.971079375Z       complete: true,
2026-03-14T04:59:08.971118006Z       rawHeaders: [Array],
2026-03-14T04:59:08.971156565Z       rawTrailers: [],
2026-03-14T04:59:08.971194018Z       joinDuplicateHeaders: undefined,
2026-03-14T04:59:08.971240415Z       aborted: false,
2026-03-14T04:59:08.971279064Z       upgrade: false,
2026-03-14T04:59:08.971321367Z       url: '',
2026-03-14T04:59:08.971358900Z       method: null,
2026-03-14T04:59:08.971396371Z       statusCode: 406,
2026-03-14T04:59:08.971434172Z       statusMessage: 'Not Acceptable',
2026-03-14T04:59:08.971473736Z       client: [TLSSocket],
2026-03-14T04:59:08.971512683Z       _consuming: false,
2026-03-14T04:59:08.971554365Z       _dumped: false,
2026-03-14T04:59:08.971592467Z       req: [Circular *1],
2026-03-14T04:59:08.971634684Z       _eventsCount: 4,
2026-03-14T04:59:08.971685235Z       responseUrl: 'https://cf.edge.foxdtc.digitalvideoplatform.com/<REDACTED>',
2026-03-14T04:59:08.971798176Z       redirects: [],
2026-03-14T04:59:08.971838505Z       Symbol(shapeMode): true,
2026-03-14T04:59:08.971877964Z       Symbol(kCapture): false,
2026-03-14T04:59:08.971920061Z       Symbol(kHeaders): [Object],
2026-03-14T04:59:08.971960010Z       Symbol(kHeadersCount): 22,
2026-03-14T04:59:08.971999686Z       Symbol(kTrailers): null,
2026-03-14T04:59:08.972044234Z       Symbol(kTrailersCount): 0
2026-03-14T04:59:08.972084313Z     },
2026-03-14T04:59:08.972120735Z     aborted: false,
2026-03-14T04:59:08.972159794Z     timeoutCb: null,
2026-03-14T04:59:08.972198241Z     upgradeOrConnect: false,
2026-03-14T04:59:08.972240204Z     parser: null,
2026-03-14T04:59:08.972278990Z     maxHeadersCount: null,
2026-03-14T04:59:08.972318501Z     reusedSocket: true,
2026-03-14T04:59:08.972357896Z     host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2026-03-14T04:59:08.972401337Z     protocol: 'https:',
2026-03-14T04:59:08.972444121Z     _redirectable: Writable {
2026-03-14T04:59:08.972487019Z       _events: [Object],
2026-03-14T04:59:08.972525677Z       _writableState: [WritableState],
2026-03-14T04:59:08.972564979Z       _maxListeners: undefined,
2026-03-14T04:59:08.972605055Z       _options: [Object],
2026-03-14T04:59:08.972663448Z       _ended: true,
2026-03-14T04:59:08.972711028Z       _ending: true,
2026-03-14T04:59:08.972751504Z       _redirectCount: 0,
2026-03-14T04:59:08.972789508Z       _redirects: [],
2026-03-14T04:59:08.972827481Z       _requestBodyLength: 0,
2026-03-14T04:59:08.972865636Z       _requestBodyBuffers: [],
2026-03-14T04:59:08.972903469Z       _eventsCount: 3,
2026-03-14T04:59:08.972941089Z       _onNativeResponse: [Function (anonymous)],
2026-03-14T04:59:08.972981669Z       _currentRequest: [Circular *1],
2026-03-14T04:59:08.973025707Z       _currentUrl: 'https://cf.edge.foxdtc.digitalvideoplatform.com/<REDACTED>',
2026-03-14T04:59:08.973146611Z       _timeout: null,
2026-03-14T04:59:08.973186743Z       Symbol(shapeMode): true,
2026-03-14T04:59:08.973226444Z       Symbol(kCapture): false
2026-03-14T04:59:08.973269877Z     },
2026-03-14T04:59:08.973306236Z     Symbol(shapeMode): false,
2026-03-14T04:59:08.973345384Z     Symbol(kCapture): false,
2026-03-14T04:59:08.973384326Z     Symbol(kBytesWritten): 0,
2026-03-14T04:59:08.973423278Z     Symbol(kNeedDrain): false,
2026-03-14T04:59:08.973462510Z     Symbol(corked): 0,
2026-03-14T04:59:08.973501360Z     Symbol(kChunkedBuffer): [],
2026-03-14T04:59:08.973539737Z     Symbol(kChunkedLength): 0,
2026-03-14T04:59:08.973580389Z     Symbol(kSocket): TLSSocket {
2026-03-14T04:59:08.973622027Z       _tlsOptions: [Object],
2026-03-14T04:59:08.973670957Z       _secureEstablished: true,
2026-03-14T04:59:08.973709631Z       _securePending: false,
2026-03-14T04:59:08.973747921Z       _newSessionPending: false,
2026-03-14T04:59:08.973786450Z       _controlReleased: true,
2026-03-14T04:59:08.973824651Z       secureConnecting: false,
2026-03-14T04:59:08.973863800Z       _SNICallback: null,
2026-03-14T04:59:08.973901612Z       servername: 'cf.edge.foxdtc.digitalvideoplatform.com',
2026-03-14T04:59:08.973942831Z       alpnProtocol: false,
2026-03-14T04:59:08.973981090Z       authorized: true,
2026-03-14T04:59:08.974019770Z       authorizationError: null,
2026-03-14T04:59:08.974061197Z       encrypted: true,
2026-03-14T04:59:08.974103513Z       _events: [Object: null prototype],
2026-03-14T04:59:08.974143956Z       _eventsCount: 9,
2026-03-14T04:59:08.974181436Z       connecting: false,
2026-03-14T04:59:08.974220197Z       _hadError: false,
2026-03-14T04:59:08.974257948Z       _parent: null,
2026-03-14T04:59:08.974295622Z       _host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2026-03-14T04:59:08.974336595Z       _closeAfterHandlingError: false,
2026-03-14T04:59:08.974382533Z       _readableState: [ReadableState],
2026-03-14T04:59:08.974422516Z       _writableState: [WritableState],
2026-03-14T04:59:08.974460961Z       allowHalfOpen: false,
2026-03-14T04:59:08.974499504Z       _maxListeners: undefined,
2026-03-14T04:59:08.974540244Z       _sockname: null,
2026-03-14T04:59:08.974578240Z       _pendingData: null,
2026-03-14T04:59:08.974616790Z       _pendingEncoding: '',
2026-03-14T04:59:08.974663537Z       server: undefined,
2026-03-14T04:59:08.974702790Z       _server: null,
2026-03-14T04:59:08.974740805Z       ssl: [TLSWrap],
2026-03-14T04:59:08.974780779Z       _requestCert: true,
2026-03-14T04:59:08.974825522Z       _rejectUnauthorized: true,
2026-03-14T04:59:08.974864219Z       timeout: 5000,
2026-03-14T04:59:08.974902790Z       parser: null,
2026-03-14T04:59:08.974940836Z       _httpMessage: null,
2026-03-14T04:59:08.974979078Z       autoSelectFamilyAttemptedAddresses: [Array],
2026-03-14T04:59:08.975018135Z       Symbol(alpncallback): null,
2026-03-14T04:59:08.975061508Z       Symbol(res): [TLSWrap],
2026-03-14T04:59:08.975101024Z       Symbol(verified): true,
2026-03-14T04:59:08.975139809Z       Symbol(pendingSession): null,
2026-03-14T04:59:08.975203501Z       Symbol(async_id_symbol): -1,
2026-03-14T04:59:08.975242424Z       Symbol(kHandle): [TLSWrap],
2026-03-14T04:59:08.975284642Z       Symbol(lastWriteQueueSize): 0,
2026-03-14T04:59:08.975323447Z       Symbol(timeout): Timeout {
2026-03-14T04:59:08.975365209Z         _idleTimeout: 5000,
2026-03-14T04:59:08.975403171Z         _idlePrev: [TimersList],
2026-03-14T04:59:08.975441669Z         _idleNext: [Timeout],
2026-03-14T04:59:08.975482229Z         _idleStart: 446084473,
2026-03-14T04:59:08.975521574Z         _onTimeout: [Function: bound ],
2026-03-14T04:59:08.975561063Z         _timerArgs: undefined,
2026-03-14T04:59:08.975599426Z         _repeat: null,
2026-03-14T04:59:08.975637453Z         _destroyed: false,
2026-03-14T04:59:08.975688451Z         Symbol(refed): false,
2026-03-14T04:59:08.975728819Z         Symbol(kHasPrimitive): false,
2026-03-14T04:59:08.975767589Z         Symbol(asyncId): 1030673,
2026-03-14T04:59:08.975809379Z         Symbol(triggerId): 1030671,
2026-03-14T04:59:08.975849844Z         Symbol(kAsyncContextFrame): undefined
2026-03-14T04:59:08.975890108Z       },
2026-03-14T04:59:08.975925986Z       Symbol(kBuffer): null,
2026-03-14T04:59:08.975966359Z       Symbol(kBufferCb): null,
2026-03-14T04:59:08.976005387Z       Symbol(kBufferGen): null,
2026-03-14T04:59:08.976046591Z       Symbol(shapeMode): true,
2026-03-14T04:59:08.976085033Z       Symbol(kCapture): false,
2026-03-14T04:59:08.976125910Z       Symbol(kSetNoDelay): false,
2026-03-14T04:59:08.976165121Z       Symbol(kSetKeepAlive): true,
2026-03-14T04:59:08.976203883Z       Symbol(kSetKeepAliveInitialDelay): 1,
2026-03-14T04:59:08.976242833Z       Symbol(kBytesRead): 0,
2026-03-14T04:59:08.976280628Z       Symbol(kBytesWritten): 0,
2026-03-14T04:59:08.976318639Z       Symbol(connect-options): [Object]
2026-03-14T04:59:08.976358329Z     },
2026-03-14T04:59:08.976394194Z     Symbol(kOutHeaders): [Object: null prototype] {
2026-03-14T04:59:08.976435051Z       accept: [Array],
2026-03-14T04:59:08.976473113Z       'accept-encoding': [Array],
2026-03-14T04:59:08.976512536Z       'user-agent': [Array],
2026-03-14T04:59:08.976551981Z       host: [Array]
2026-03-14T04:59:08.976589846Z     },
2026-03-14T04:59:08.976638574Z     Symbol(errored): null,
2026-03-14T04:59:08.976687542Z     Symbol(kHighWaterMark): 65536,
2026-03-14T04:59:08.976726790Z     Symbol(kRejectNonStandardBodyWrites): false,
2026-03-14T04:59:08.976769564Z     Symbol(kUniqueHeaders): null
2026-03-14T04:59:08.976808753Z   },
2026-03-14T04:59:08.976844490Z   response: {
2026-03-14T04:59:08.976882330Z     status: 406,
2026-03-14T04:59:08.976920998Z     statusText: 'Not Acceptable',
2026-03-14T04:59:08.976966426Z     headers: AxiosHeaders {
2026-03-14T04:59:08.977006546Z       'content-length': '30',
2026-03-14T04:59:08.977045452Z       connection: 'keep-alive',
2026-03-14T04:59:08.977085295Z       server: 'nginx',
2026-03-14T04:59:08.977126071Z       date: 'Sat, 14 Mar 2026 04:59:08 GMT',
2026-03-14T04:59:08.977168776Z       'x-yospace-hostname': 'csm-e-cefoxdtcprdause1live-07b5d91adf7eaa54f.bln1.yospace.com',
2026-03-14T04:59:08.977213358Z       'x-cache': 'Error from cloudfront',
2026-03-14T04:59:08.977254319Z       via: '1.1 eac5ff8c8951bc7fa5bbf706c830ab88.cloudfront.net (CloudFront)',
2026-03-14T04:59:08.977298858Z       'x-amz-cf-pop': 'SFO5-P1',
2026-03-14T04:59:08.977338447Z       'x-amz-cf-id': 'p2JWp5i_xLLw3aQpJFwlgcvoxDECQI_RyygU4mp4PohAAuW70-eoxQ==',
2026-03-14T04:59:08.977385093Z       'x-cdn': 'cloudfront',
2026-03-14T04:59:08.977424270Z       vary: 'Origin'
2026-03-14T04:59:08.977463982Z     },
2026-03-14T04:59:08.977500147Z     config: {
2026-03-14T04:59:08.977540416Z       transitional: [Object],
2026-03-14T04:59:08.977579340Z       adapter: [Array],
2026-03-14T04:59:08.977617634Z       transformRequest: [Array],
2026-03-14T04:59:08.977667520Z       transformResponse: [Array],
2026-03-14T04:59:08.977709216Z       timeout: 60000,
2026-03-14T04:59:08.977747143Z       xsrfCookieName: 'XSRF-TOKEN',
2026-03-14T04:59:08.977786903Z       xsrfHeaderName: 'X-XSRF-TOKEN',
2026-03-14T04:59:08.977826277Z       maxContentLength: -1,
2026-03-14T04:59:08.977868896Z       maxBodyLength: -1,
2026-03-14T04:59:08.977906969Z       env: [Object],
2026-03-14T04:59:08.977948461Z       validateStatus: [Function: validateStatus],
2026-03-14T04:59:08.977989632Z       headers: [AxiosHeaders],
2026-03-14T04:59:08.978028509Z       method: 'get',
2026-03-14T04:59:08.978068035Z       url: 'https://cf.edge.foxdtc.digitalvideoplatform.com/<REDACTED>',
2026-03-14T04:59:08.978176193Z       data: undefined
2026-03-14T04:59:08.978216078Z     },
2026-03-14T04:59:08.978252363Z     request: <ref *1> ClientRequest {
2026-03-14T04:59:08.978297305Z       _events: [Object: null prototype],
2026-03-14T04:59:08.978339862Z       _eventsCount: 7,
2026-03-14T04:59:08.978378176Z       _maxListeners: undefined,
2026-03-14T04:59:08.978416555Z       outputData: [],
2026-03-14T04:59:08.978453755Z       outputSize: 0,
2026-03-14T04:59:08.978491456Z       writable: true,
2026-03-14T04:59:08.978530045Z       destroyed: true,
2026-03-14T04:59:08.978568253Z       _last: true,
2026-03-14T04:59:08.978606439Z       chunkedEncoding: false,
2026-03-14T04:59:08.978660648Z       shouldKeepAlive: true,
2026-03-14T04:59:08.978700795Z       maxRequestsOnConnectionReached: false,
2026-03-14T04:59:08.978740242Z       _defaultKeepAlive: true,
2026-03-14T04:59:08.978778529Z       useChunkedEncodingByDefault: false,
2026-03-14T04:59:08.978817253Z       sendDate: false,
2026-03-14T04:59:08.978855943Z       _removedConnection: false,
2026-03-14T04:59:08.978894448Z       _removedContLen: false,
2026-03-14T04:59:08.978932475Z       _removedTE: false,
2026-03-14T04:59:08.978970511Z       strictContentLength: false,
2026-03-14T04:59:08.979009083Z       _contentLength: 0,
2026-03-14T04:59:08.979046188Z       _hasBody: true,
2026-03-14T04:59:08.979099730Z       _trailer: '',
2026-03-14T04:59:08.979141905Z       finished: true,
2026-03-14T04:59:08.979182401Z       _headerSent: true,
2026-03-14T04:59:08.979220513Z       _closed: true,
2026-03-14T04:59:08.979261863Z       _header: 'GET <REDACTED> HTTP/1.1\r\n' +
2026-03-14T04:59:08.979367485Z         'Accept: application/json, text/plain, */*\r\n' +
2026-03-14T04:59:08.979412717Z         'Accept-Encoding: identity\r\n' +
2026-03-14T04:59:08.979453985Z         'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2026-03-14T04:59:08.979508782Z         'Host: cf.edge.foxdtc.digitalvideoplatform.com\r\n' +
2026-03-14T04:59:08.979553267Z         'Connection: keep-alive\r\n' +
2026-03-14T04:59:08.979594276Z         '\r\n',
2026-03-14T04:59:08.979632168Z       _keepAliveTimeout: 0,
2026-03-14T04:59:08.979684308Z       _onPendingData: [Function: nop],
2026-03-14T04:59:08.979734852Z       agent: [Agent],
2026-03-14T04:59:08.979775277Z       socketPath: undefined,
2026-03-14T04:59:08.979815378Z       method: 'GET',
2026-03-14T04:59:08.979858297Z       maxHeaderSize: undefined,
2026-03-14T04:59:08.979898124Z       insecureHTTPParser: undefined,
2026-03-14T04:59:08.979944344Z       joinDuplicateHeaders: undefined,
2026-03-14T04:59:08.979987201Z       path: '<REDACTED>',
2026-03-14T04:59:08.980117722Z       _ended: true,
2026-03-14T04:59:08.980162561Z       res: [IncomingMessage],
2026-03-14T04:59:08.980203325Z       aborted: false,
2026-03-14T04:59:08.980243710Z       timeoutCb: null,
2026-03-14T04:59:08.980282611Z       upgradeOrConnect: false,
2026-03-14T04:59:08.980321917Z       parser: null,
2026-03-14T04:59:08.980360539Z       maxHeadersCount: null,
2026-03-14T04:59:08.980399483Z       reusedSocket: true,
2026-03-14T04:59:08.980438673Z       host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2026-03-14T04:59:08.980486356Z       protocol: 'https:',
2026-03-14T04:59:08.980526807Z       _redirectable: [Writable],
2026-03-14T04:59:08.980573225Z       Symbol(shapeMode): false,
2026-03-14T04:59:08.980615250Z       Symbol(kCapture): false,
2026-03-14T04:59:08.980703394Z       Symbol(kBytesWritten): 0,
2026-03-14T04:59:08.980751201Z       Symbol(kNeedDrain): false,
2026-03-14T04:59:08.980790703Z       Symbol(corked): 0,
2026-03-14T04:59:08.980830356Z       Symbol(kChunkedBuffer): [],
2026-03-14T04:59:08.980878587Z       Symbol(kChunkedLength): 0,
2026-03-14T04:59:08.980922214Z       Symbol(kSocket): [TLSSocket],
2026-03-14T04:59:08.980961628Z       Symbol(kOutHeaders): [Object: null prototype],
2026-03-14T04:59:08.981005518Z       Symbol(errored): null,
2026-03-14T04:59:08.981045278Z       Symbol(kHighWaterMark): 65536,
2026-03-14T04:59:08.981084349Z       Symbol(kRejectNonStandardBodyWrites): false,
2026-03-14T04:59:08.981128347Z       Symbol(kUniqueHeaders): null
2026-03-14T04:59:08.981171204Z     },
2026-03-14T04:59:08.981212963Z     data: 'Non-Gzip client not supported\n'
2026-03-14T04:59:08.981261337Z   }
2026-03-14T04:59:08.981297560Z }
2026-03-14T04:59:09.825538859Z Channel #216 has an active event (The Five). Going to start the stream.
2026-03-14T05:05:29.454156375Z Channel #216 has been idle for more than 5 minutes. Removing playlist info.
