thanks for the reply back, but I do not have Fubo service. I thought it maybe played on the foxsports.com in 4K
You don't need Fubo. It's just an easy list to see what events FOX will have 4K for
Ok, I added fox sports to my Eplustv docker with TV provider that gets fox sports,however the best quality I can get from it is 1080P 60FPS and not 4k.
update
I figured it out, so my Fox channel is streaming at 4K
What did you do to fix. I cannot get it to stream 4k
I had to adjust it on my app client.
Which settings did you adjust?
Ok you just change the docker config file and it now streams 4k correct?
Yea when there is 4K content being broadcasting on Fox, that was early today when the Packers was playing.
Ok thanks
Speaking of the NFL games, dev is there any way to add the event type to the listings? I have a pass set up to record all NFL games but it won't get the ones on E+ because all they have is title of team vs. team, there's no category (EventTitle?) of NFL Football like regular guide data.
This would be super nice since I lost my Fox channel and E+ is the only way I can get Fox games.
Try this. Just set an advanced pass
Categories == Sports
Title contains NFL
Then check the matches it gives to fine tune.
I don’t use the Fox fork but it works thru sec+ and espn+ games that I desire.
I use this to record college games on Channels thru eplustv. It works really good but it could give you a couple of games you don’t want.
It's kinda hard. FOX doesn't always include all the same data that ESPN does
I'm working on an update that'll auto fallback to a lower resolution for FOX events so it won't just error out.
EDIT: This should be live in a few minutes...
But you're doing it for college football at least in the title, is there no way to do it for NFL football? I could make the pass work if it has NFL Football somewhere in the event.
Use title contains NFL Football , not event title.
I tested it for NHL and it shows matches with all the upcoming NHL games on the espn+ schedule.
I don’t use for fox so no fox games show up. Could you post a snippet of you guide showing a game.
The problem is the fox feed does not have NFL anywhere in it...
Is there a way to separate events to different channel ranges? IE: ESPN3 have its own section ESPN + etc or too hard? For channel logos
Also, could Bally sports be added as well?
Not able to add Bally because of DRM. Only way to get Bally into Channels is through the Fubo Docker. Have to have a Fubo subscription.
