I had the same issue. I deleted the Docker and deleted E+ as a source in Channels and then reinstalled the Docker and created a new source. I was good after that.
Can confirm! completely deleting the Docker and specifying a different volume (i just added a 2), then re-adding to Channels worked.
Thanks @Rufus_Arizona !!
any one confirm that the cowboys game be in 4K on fox today?
Yes, getting 4k SDR on EPlusTV. Still getting 404 errors if I have it set for UHD/HDR.
I don't have the HDR setting and I'm getting 404 error
Getting 4k here. I don’t use any environmental variable for resolution.
I pushed up an update to fix the issue with FOX 4K streams. Should be able to update docker in a few minutes
thanks
Is anyone seeing the NFL game in the guide today on Fox? I see the pregame and that's it, the game is not there.
I'm wondering if FOX is re-using event ids or something. It wasn't there for me, but after clearing the DB it worked. I might have to put some logic in there for that...
What's the quick way to clear the DB? Do you have to reauthenticate afterwards?
Just delete the entries.db and schedule.db files in the config directory. You don't have to re-authenticate. The tokens are saved elsewhere. You will have to re-build your schedule in Channels though
Thanks, I figured it out before you posted but I I knew you'd follow up because you're good like that.
This may be the reason why we have seen NFL games missing through the season.
I had to do that as well, to see new stuff come down. far as delete the .db files
Thanks, I'm getting the 4K feed now.
Nice
Any update on how to make channel recognize eplus entries for league or team passes? Maybe the entries just don’t have enough info in their title. NFL games only say team names, not even cities. I don’t want to just record anything that has “eagles” in the title
