Thanks, appears to be up and running at the moment.! I'll check in tomorrow and see how it's doing...
Also, heads up, it's still scheduling NFL+ games even for those of us without:
Thanks to @joagomez I added NFL Sunday Ticket on 3.2.8
It'll show as NFL+ because that's the integration they are from.
Yeah, I just go off of what is in the API
Sorry, I forgot to clear out and reload my guide after the rebuilt. Those do play, actually. I was just confused because they say NFL+ even though I don't have that. Weirdly, though, the one showing the local station...
... fails to play.
Channel #90002 was setup improperly... Removing.
Yes I don't have a great distinction about it coming from NFL+ even if it's coming from your TV provider.
I'm guessing that other game is coming from FOX?
So if I picked up the NFL Sunday Ticket at the halfway mark or the season, this would allow all games to be accessed in Channels without having to do CC or HDMI Capture? If so, that's great.....
Yes!
Peacock sign on seems to be working for the game tonight. Time will tell for Amazon Prime
You nailed it!
Also, just FYI, NFL Network is still up almost 24 hours since I last launched it. So far, so good!
Hi. I added: -e NFL_PRIME=true -e NFL_PEACOCK=true to my existing entries but when I run it, I am not getting asked for my credentials like Paramount and ESPN. Am I doing something wrong? Thanks.
You need to use NFLPLUS=true even if you don't subscribe. Just having an NFL account is good enough
Okay. I guess I'll figure it out but if you see this message first, you're saying to create a NFL account and add the providers/logins there? So there won't be a docker prompt to enter for Peacock and Prime but rather a prompt for the newly created NFL account? Is that about right? Thx.
edit: I got it. I had to create the NFL account and then authenticate all of them again in docker. Understand now.
Crap. I did it both on the NFL account and through the container prompts. Do I need to remove the providers I added in the NFL account? Or doesn't matter?
As long as you did it in the container you're good
Wow you added peacock? Can CBS Sports (not just CBS) be added or is it drm?
Also, if you don't have paramount will it work with CBS games like CBS.com?
Also, will peacock work with other sporting events including college?
This was just integrating Peacock auth from the NFL app. So we're not getting any other Peacock events - but since the stream comes from NFL it's DRM free.
If you don't have Paramount+ you can use your TVE login to get CBS NFL games.
I would like to get CBS Sports added but I need to figure out one thing on that
Will it work with other CBS sporting events besides NFL?
If I can figure out CBS sports, yeah it'll have everything they broadcast
Ok have to say watching both the standard broadcast and Prime Vision broadcast at the same time is cool
Thanks again @m0ngr31
