Experimental: Stream Links from the Guide via Custom Channels
should I substitute MSNow for MSNBC?
The url thats being used is old now
This is the new url to get MSNOW
Has anybody figured out the streamlinks for the 4K channels on Sling TV? I'm trying to look in the android logs and I can't find any channel ids
I know this is an older thread. But dropping this here in case it might help someone else.
I was able to get this sort of working by using the NBCSports app on my AppleTV. It doesn't launch the program. But it drops me in the channel guide at the correct place so all I need to do it click the remote control to start the program. If anyone can tweak this to make it launch the program, please advise. This is what I did:
#EXTINF:-1 channel-id="nbcsn-philly” tvg-chno="6061" tvc-guide-stationid="96232",NBCSN PHILADELPHIA
nbcsportstve://live/rsn-philadelphia
You may have more luck with
nbctve://live/rsn-philadelphia
thanks, I tried that. But the nbc app seems really buggy and never gave me good results. Ideally, I could just launch the channel in my Hulu Live app. But I haven't been able to get that working either.
I wonder if it's just that particular RSN, because I use deeplinks with the NBC app all the time and it always works. Android TV onn box sending to an HDMI encoder.
Well, until I have to reauthenticate every few months that is. But I have a daily news recording set to check that.
Anyone know the Deep Link for the DAZN app? I'd like to add this to my guide for MSG and YES
dazn:// does not work
Update- found the link. For those that are interested (MSG and YES):
#EXTINF:-1 channel-id="msg-sportsnet" tvg-chno="6050" tvc-guide-stationid="14449",MSG Sportsnet
open.dazn.com://
#EXTINF:-1 channel-id="yes-network" tvg-chno="6205" tvc-guide-stationid="32420",YES Network
open.dazn.com://
Anyone know the links to get to the live ESPN channels using the Disney+ app?
