Failed to get series info for tms/28851859 that Channels DVR recorded (gracenote issue?)
I was curious about this error that appears everyday in my log.
[ERR] Failed to get series info for tms/28851859: record not found: tms/28851859: invalid TMS ID
I have a pass to record the 6 episodes of Inside the Enchanted Forests that aired on NatGeo Wild
The first two episodes recorded on their OAD in December, 2024 under SeriesID 28851859
Then 4 more episodes were recorded later in December, 2024 under SeriesID 25914371
According to /groups
SeriesID 28851859 lists the Release date as December, 2024 (correct)
SeriesID 25914371 lists the Release date as November, 2023 (incorrect)
So CDVR is unable to get IMDB and TMDB ID's because the Release Year for SeriesID 25914371 is wrong.
/groups/28851859
  "ID": "28851859",
  "Name": "Inside the Enchanted Forests",
  "SeriesID": "28851859",
  "Summary": "Traverse the planet's richest, most diverse woodlands, from the tropics to the poles and everywhere in between; get to know the wild residents of these magical ecosystems and learn how forests connect and nurture the lives of countless species.",
  "Image": "https://tmsimg.fancybits.co/assets/p28851859_b_h9_ab.jpg?w=720&h=540",
  "Categories": [
    "Show",
    "Series"
  "Genres": [
    "Nature"
  "FileID": [
    "8250",
    "8251"
  "CreatedAt": 1733536800,
  "RecordedAt": 1733540400124,
  "UpdatedAt": 1733597613524,
  "RefreshedAt": 1733536800897,
  "ReleaseDate": "2024-12-07",
  "ReleaseYear": 2024,
  "Version": 2,
  "NumUnwatched": 1,
  "WatchedAt": 1733597612676,
  "UpNextCursor": {
    "SeasonNumber": 1,
    "EpisodeNumber": 2,
    "OriginalDate": "2024-12-06",
    "Time": 1733540400,
    "PlayedAt": 1733597594786
/groups/25914371
  "ID": "25914371",
  "SeriesID": "25914371",
  "Summary": "The presenter showcases a diverse group of species inhabiting the rainforests, including a solitary sloth cultivating a mini-forest, lemurs sharing equally, elephants tending their forests and more.",
  "Image": "https://tmsimg.fancybits.co/assets/p25914371_st_h9_ac.jpg?w=720&h=540",
  "Categories": [
    "Show",
    "Series"
  "Genres": [
    "Documentary",
    "Nature",
    "Animals"
  "FileID": [
    "8284",
    "8285",
    "8286",
    "8287"
  "CreatedAt": 1734746400,
  "RecordedAt": 1734757200237,
  "UpdatedAt": 1751260404415,
  "RefreshedAt": 1734746400800,
  "ReleaseDate": "2023-11-11",
  "ReleaseYear": 2023,
  "Cast": [
    "Fenella Fudge"
  "SeriesInfo": {
    "Title": "Inside the Enchanted Forests",
    "Year": 2023,
    "IMDB": {
      "ID": "",
      "MatchReason": "failed_year_mismatch"
    "TMS": {
      "ID": "25914371",
      "Year": 2023,
      "MatchReason": "success_id_lookup"
    "TMDB": {
      "ID": "",
    "UpdatedAt": 1751219831
  "Version": 2,
  "NumUnwatched": 4
My original series pass was for SeriesID == 28851859, which was in the guide when I created the pass.
On December 6th, it recorded the first two episodes, EP054251850001 & EP054251850002
After digging through the old logs, it appears that Gracenote changed the Series ID for this show around December 12th, from 28851859 to 25914371. At that time, the scheduled jobs for the remaining 4 episodes were deleted by CDVR.
After I noticed they weren't recording, on December 14th I changed the pass from SeriesID == 28851859 to Title CONTAINS Inside the Enchanted Forests. It then recorded episodes 1, 2, 5 and 6 on December 20th under SeriesID 25914371
2024/11/30 14:21:37.703039 [DVR] Rule '--1time-Inside the Enchanted Forests #eps?' (839) found 2 new airings
2024/11/30 14:21:37.740633 [DVR]   queued recording job for EP054251850001 @ Fri Dec 6 6:00:00PM on ch=[806] (1733536800-839)
2024/12/06 18:00:00.672616 [DVR] Recording for job 1733536800-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E01 Tropical 2024-12-06-1800.mpg" for 1h0m59.995818149s
2024/11/30 14:21:37.778679 [DVR]   queued recording job for EP054251850002 @ Fri Dec 6 7:00:00PM on ch=[806] (1733540400-839)
2024/12/06 19:00:00.030667 [DVR] Recording for job 1733540400-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E02 Seasonal 2024-12-06-1900.mpg" for 1h0m59.997884287s
2024/12/04 09:58:45.663104 [DVR] Rule '--1time-Inside the Enchanted Forests #eps?' (839) found 2 new airings
2024/12/04 09:58:45.686087 [DVR]   queued recording job for EP054251850003 @ Fri Dec 13 6:00:00PM on ch=[806] (1734141600-839)
2024/12/12 09:34:38.210983 [DVR] Deleting job no longer in the guide: 'Inside the Enchanted Forests' EP054251850003 @ Fri Dec 13 6:00:00PM on ch=[806] (1734141600-839)
2024/12/04 09:58:45.713601 [DVR]   queued recording job for EP054251850004 @ Fri Dec 13 7:00:00PM on ch=[806] (1734145200-839)
2024/12/12 09:34:38.432729 [DVR] Deleting job no longer in the guide: 'Inside the Enchanted Forests' EP054251850004 @ Fri Dec 13 7:00:00PM on ch=[806] (1734145200-839)
2024/12/11 09:26:33.353300 [DVR] Rule '--1time-Inside the Enchanted Forests #eps?' (839) found 2 new airings
2024/12/11 09:26:33.385578 [DVR]   queued recording job for EP054251850005 @ Fri Dec 20 6:00:00PM on ch=[806] (1734746400-839)
2024/12/12 09:34:38.597919 [DVR] Deleting job no longer in the guide: 'Inside the Enchanted Forests' EP054251850005 @ Fri Dec 20 6:00:00PM on ch=[806] (1734746400-839)
2024/12/11 09:26:33.407550 [DVR]   queued recording job for EP054251850006 @ Fri Dec 20 7:00:00PM on ch=[806] (1734750000-839)
2024/12/12 09:34:38.747673 [DVR] Deleting job no longer in the guide: 'Inside the Enchanted Forests' EP054251850006 @ Fri Dec 20 7:00:00PM on ch=[806] (1734750000-839)
2024/12/14 19:57:52.674829 [DVR] Rule '--1time-Inside the Enchanted Forests 6episodes' (839) found 4 new airings
2024/12/14 19:57:52.690547 [DVR]   queued recording job for EP054620180009 @ Fri Dec 20 6:00:00PM on ch=[806] (1734746400-839)
2024/12/20 18:00:00.633703 [DVR] Recording for job 1734746400-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E05 Boreal 2024-12-20-1800.mpg" for 1h0m59.997713265s
2024/12/14 19:57:52.729432 [DVR]   queued recording job for EP054620180012 @ Fri Dec 20 7:00:00PM on ch=[806] (1734750000-839)
2024/12/20 19:00:00.002560 [DVR] Recording for job 1734750000-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E06 Extreme 2024-12-20-1900.mpg" for 1h0m59.997820221s
2024/12/14 19:57:52.756533 [DVR]   queued recording job for EP054620180001 @ Fri Dec 20 8:00:00PM on ch=[806] (1734753600-839)
2024/12/20 20:00:00.002051 [DVR] Recording for job 1734753600-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E01 2023-11-11 Tropical 2024-12-20-2000.mpg" for 1h0m59.998506911s
2024/12/14 19:57:52.784888 [DVR]   queued recording job for EP054620180003 @ Fri Dec 20 9:00:00PM on ch=[806] (1734757200-839)
2024/12/20 21:00:00.030119 [DVR] Recording for job 1734757200-839 from 1323AADB ch806 into "TV/Inside the Enchanted Forests/Inside the Enchanted Forests S01E02 2023-11-18 Seasonal 2024-12-20-2100.mpg" for 1h0m59.997505977s
Appears it was produced in the U.K. in 2023 under the Title Secrets of the Enchanted Forest Secrets of the Enchanted Forests (TV Series 2023– ) - IMDb
and premiered on NatGeo Wild in 2024 under the Title Inside the Enchanted Forests Inside the Enchanted Forests (TV Series 2024– ) - IMDb
Not sure what I can do aside from trying to import those episodes that were already recorded.
This is causing a problem with trying to change the metadata summary and artwork.
The poster picker is failing because the series 28851859 has no artwork.
Console errors show
XHR GET http://192.168.1.4:8189/dvr/groups/28851859/posters [HTTP/1.1 503 Service Unavailable 349ms]
GET /dvr/groups/28851859/posters Service Unavailable [globals.jsx:172:13](http://192.168.1.4:8189/admin/globals.jsx)
TypeError: s.map is not a function [react-dom.production.min.js:216:200](http://192.168.1.4:8189/node_modules/react-dom/cjs/react-dom.production.min.js)
Te PosterPickerModal.jsx:685
React 8
unstable_runWithPriority scheduler.production.min.js:18
React 5
g2 PosterPickerModal.jsx:226
Te PosterPickerModal.jsx:273
Re2 React
React 3
hP scheduler.production.min.js:16
onmessage scheduler.production.min.js:12
M91 scheduler.production.min.js:12
C bundle.js:1
z91 index.js:4
C bundle.js:1
oo1 React
C bundle.js:1
S3 React
C bundle.js:1
<anonymous> app.jsx:4
<anonymous> app.jsx:87
Uncaught (in promise) TypeError: s.map is not a function [PosterPickerModal.jsx:685:32](http://192.168.1.4:8189/admin/components/PosterPickerModal.jsx)
React 8
React 5
Re2 React
React 3
C bundle.js:1
z91 index.js:4
C bundle.js:1
oo1 React
C bundle.js:1
S3 React
C bundle.js:1
Response to the poster picker GET http://192.168.1.4:8189/dvr/groups/28851859/posters
is {"error fetching series images":"invalid TMS ID"}
Is there another way to edit the artwork?
