The Mac Studio sounds a bit overkill, but it would be fun if the Channels Server had some benchmarking features. Perhaps a com skip performance score, or transcoding score so we could all compare apples to apples.
I’m using all external drives to try to help Mac mini last as long as it can, but I do wish it had 10000 Base-T 10 Gigabit Ethernet.
How badly do you wish it had 10G ethernet? Badly enough to spend 200 bucks?
(Edit: ...and I now just saw your earlier post where you said you were considering a Thunderbolt 10G adapter...)
I did exactly that based on your post alone, grabbed 2 licenses on Ebay (hopefully it's legit). I had never heard of this license type before, but it's golden for people who know OS's don't need weekly updates, so thanks for posting that info. I plan to update my Channels DVR server to this as soon as I have time, unless the developers here see it as a problem with the Channels DVR server software (now and in the future).
Got the 2019 version, good for 10 years.
I use Google Fiber (Webpass) and await their 2 Gig service. While it probably won't help my upload speed, I assume faster Ethernet might be useful for download and presume I could get by with a USB-C / Thunderbolt 3 2.5Gbps Ethernet adapter (like this one https://www.amazon.com/Plugable-Ethernet-Adapter-Compatible-Thunderbolt/dp/B084L4JL9K).
Hm. Marco Arment on ATP recommends a 2.5Gbps adapter with an RTL8156 Chipset instead of an 8153 478: No Bum Cores — Accidental Tech Podcast — Overcast per this week’s Episode / Hacker News At least with respect to macOS, the Realtek 8153 chipsets in these docks suffer ... | Hacker News.
As a follow up on that 2-license Ebay purchase, I installed the first license about 2 years ago, everything went fine. Went to install the 2nd license about a month ago and Microsoft cried about it already being activated on another computer, so no good on machine #2. When I went to Ebay, the seller had magically disappeared, there was literally no trace of the user. I contacted Ebay, and the seller's email that I had received a couple years ago and within a few days they forwarded me a 2nd install key and it activated on the 2nd machine.
I guess I'm calling that a win. For now.
That is what I am running on my main .... found it easier to add shares than Linux. Linux is just a pain in the ass when adding shared storage with mounting etc.
OS
ASUSTeK COMPUTER INC. VC66
Windows Microsoft Windows 10 IoT Enterprise LTSC 2021
10.0.19044.3208 Build 19044.3208 (kernel: 10.0.19044.3208 Build 19044.3208)
I have a HP
|Model|ProDesk 800 G3 Desktop Mini PC
|Processor|Intel Core i5-8500T CPU @ 2.10GHz (6-Core)
|Storage|256 GB SSD could upgrade to a TB
|RAM|16 GB
|Internal Graphics|Intel HD Graphics 530
|Operating System|Windows 11 Pro
Would this be ok for a channels dvr only server?
I need to stream to my other home also. Not just local.
That should be fine. Many people use lesser computers that do a fine job
If you plan on using the same machine to store your recordings, you may want to upgrade your Storage to 1TB or more...Everything else is more than ok.
You don't have to replace the OS drive, you can add a second drive for storage and point Channels DVR to it.
Ok perfect. Will add a tb external.
