Sorry. You may want to double check the address, and make sure it works in VLC or similar—I'm typing this from memory, and the address might be different. Also, check the syntax of your playlist text; make sure it has both the preamble (#EXTM3U), as well as each entry having its info line (#EXTINF).
As far as guide info, you can use the tvc-guide-stationid tag.
For more information, check the support docs:
