Should work with Friday Night Baseball on Appletv too when that restarts, yes?
Yes, but I'll need to add that separately since it scrapes as another provider code. I'll do that shortly...
Done:
There's now Apple TV (MLB) and Apple TV (MLS).
Thank you @bnhf!! :raised_hands: I’ll test out the Apple MLS FDL events later this week on my fire tv sticks to see how it goes!
New bnhf/olivetin:latest (aka bnhf/olivetin:2026.03.20) pushed this morning with an important name change to apple_mlb and apple_mls based ADBTuner sources. Be sure to update before deploying sources based on these FruitDeepLinks providers:
I just discovered this and I plan to set this up. Sounds exactly what I want. Thanks so much! I still personally like channels as the single window to live events and this seems perfect
I am still having issues connecting to the Prime Video channels. I can get everything in ADBTuner connected, I just cannot get the preview to play. Here are some screen shots from ADBTuner. Any assistance is appreaciated.
And the configurations I am using where those provided by @nateg
And I am using a Tivo Stream 4K to as the ADBTuner.
That's not what your screenshot shows.
Also, please don't obscure LAN IPs -- it's not necessary, and can hide issues.
What's up with your Streaming Endpoint being on port 8089? Also, why are you doing Keep Alive on the Channels App? What streaming sticks are you using?
*New screenshot. This one has the IP address visibile, and shows I am using the FDP configurations from @nateg.
*I also turned off the Keep Aliver setting.
*I am using TS4K for the ADBTuner and playing on Shield and Google Streamers.
*should the streaming endpoint be the endcoder?
Yes.
@KineticMan
It looks to me like today's Valspar Open coverage may be revealing an issue. ESPN+ has the early coverage, and then Peacock has the afternoon, yet FDL is showing both in the same time slot:
In the Peacock app, and looking at the NBC coverage it's not on until later:
I'm guessing that the Peacock deeplink is correct, but it's getting rolled into the ESPN+ timeslot as that's considered the "best" deeplink. Is that possible?
If you are using the most recent ones I shared, make sure you are using the development version of ADBTuner, as they are leveraging a specific capability only available in that version as of now. Hopefully you are getting to the splash screen for the event at least, if not you probably have some other problems.
Will look into
Hi @bnhf I tested your OliveTin Apple MLS ADB updates this morning.
The FDL "apple_mls" adb lanes are now working and showing the games in channels DVR.
But there is two Apple TV prompts you need to get by to start the stream on FireTv.
#1 - Watch
1
#2 - Watch Live
I made a custom Apple MLS ADB configuration to add the below to "post_playback_start_commands"
    "sleep 1",
    "input keyevent KEYCODE_DPAD_CENTER",
    "sleep 1",
This presses enter twice with a second pause in between to get past those two Apple TV prompts.
Seems to be working good now :raised_hands:
Thanks for the OliveTin updates this morning!
I use a channel collection with the sports dropdown and none of the games from the stream are showing up there. DO you know if there is a way to get these into that sports category?
That’s what I do and it works. Make sure you are not excluding the source would be my only suggestion. They don’t show up that way until they are active on the current timeline.
Weird. Mine is not excluded just not showing up. I also filter only live. Maybe that’s it
Thats what it was. I had "new" checkmarked
