Fubo TV project
I appreciate the work.
I'm a happy Fubo Customer. Very nice.
In case anyone wasn't aware, the CBS 4k channel is now in place on Fubo.
Reload the m3u and you will find it lumped with the rest of the available 4k channels.
I was able to play the feed. The channel presently has the Fubo TV logo.
I should probably pull that repo down so that it's not confusing to anyone else
Nothing airing until Super Bowl Sunday
How do you have guide data for that channel?
Use Gracenote built into channels.
Look for CBS 4k. After you map the channel make sure to re-download guide data on the Fubo TV source used for the container.
I updated the fubo-gracenote.json file with the correct gracenote station ID
    "1239200001": {"StationID": "152581", "name": "CBS 4K"},
I wonder if we will get 4K HDR. But this is sick, thanks for the update Paul.
I do not think Nick will have it in 4K though, only Fubo and yttv
What!?!
No SpongeBob SquarePants in 4K?
awe man!!
I just started using this solution today and I have to give major kudos at how easy it was to setup and get running... and with TVE in the mix, I got my local ABC affiliate too. I'm still a Spectrum CableCARD user for now, until they get around to rolling out high-split in my area... but I'm wondering if anyone has found a solution like this one that can run DirecTV Stream from within Docker too?
Nope because DRM.
You need to use either CC4C or HDMI or adbtuner or ah4c for that
I switched from YTTV after they blocked my Synology from setting up TVE plus the ADB Tuner solution is good but i'm always in favor of docker and direct streams first.
The picture is smoother plus Baseball season is starting soon.
i keep ADB Tuner setup just in case it is needed.
if i can get a non-tve source, it is a much better experience. I'm kind of tired of AMC and Sundance playing filler stuff in the commercial breaks.
Ahhh okay - I didn't realize DirecTV had everything DRM'd.
anyone else able to watch NBC Sports 4K on Fubo Currently? there is a Soccer game on it, but does not play.
Working for me 9 am eastern on NBC Sports 4k using an ATV 4k. I have my ATV settings under video / match content set for Match Dynamic Range On, Match Frame Rate off. And Video Format to 4k SDR. Not sure what device you use, but that seems to work well for me with Apple hardward...
I am using docker version
I run the fubotv project docker on windows 11, and watch using an apple tv. I did not have to make any changes to the win 11 docker to see the 4k. But I did have to change the ATV settings to get be able to see any 4k content from channels, had an error message until I made the changes mentioned in the prior post...
Yea I even tried it with VLC player as well, and it starts to play and then stops. the Rest of the None 4k channels from Fubo docker works fine.
