It works again with FuboTV. All channels came back.
All Hallmark channels now work with latest beta. Thank you to the Devs. Curious as to why that one channel would not work on the last beta?
Hahaha... I can't tell you the number of times my wife has said "I AM NOT watching another one of these Christmas movies..." (she still does and loves them)
Can confirm, latest pre-release 2024.03.22.1726 solved it for me.
The 3 missing Hallmark channels are back.
Thank you for getting these channels up and running again.
I tried to ask for some information and found someone had marked the problem as solved. I wish it were.
I am running 2023.0104.2027. It says this is the latest. Maybe official release and not BETA. I don't know where to get the Beta v2024.03.22.1726.I found it mentioned, but I can't find a download page.
Where can I get Beta v2024.03.22.1726.? I have hunted but no luck.
You need to update your Channels DVR Server version
Updating to prerelease
On the DVR web UI, select Status > Version > Check For Update > Check for Pre-Release
Prerelease upgrades happen manually, only when you click the button above. The next time a stable release happens, your DVR will switch back to the newer stable build automatically.
I was able to get V 2024.02.11.0311. Do I need to update the Channels DVR software Ver ChannelsDVRServer_PI4.img.xz?
I try to solve problems myself. But, this Raspberry stuff is a little unique.
Pretty sure it's like any other server when it comes to updating DVR pre-release.
Do you not see a drop down to select Check for Pre-Release?
If not, hold down SHIFT and click Check For Update
Thankfully, Fubo has a lot of the stuff on TVE.
I stopped using the TVE stuff and replaced it with Fubo stuff.
My ADBTuner works and I have YTTV all configured just in case.
My subscription has long since gone away but no need to put it back when I have a valid plan.
We are cofred.
If you haven't figured it out yet, that's the Channels for RPi Operating System version
There should be 2 Check For Update buttons. One for the OS and the other for the DVR software.
Thank You. All is well in Raspberry Pi land. This thread can be closed.
