I have an HDHR Prime in PA at my house that my daughter lives in connected to Comcast using a cablecard. Then I have an HDHR Extend (it has the built in transcoder to convert MPEG2 to MP4 so the stream is smaller, ~12Mbps vs ~ 2-4Mbps) setup here in HI on my OTA antenna picking up my locals, mainly so my wife can watch local news and as a backup for the HDHR prime.
This goes through an OpenVPN setup with two Asus routers, one at each location. The PA one is the server and the HI one is the client. They use TAP, not TUN mode. I created two networks, 192.168.1.1 (HI) and 192.168.3.1 (PA). I connected the HDHR Extend to an old Apple Airport Express setup so it extends my ".3" PA network to here, so the Extend gets a ".3" IP address and talks to the server router and the Channels DVR Server that is setup to it in PA via an nVidia Shield w/ an external USB HDD.
Here in HI I connect my AppleTV boxes, one at each TV, as DVR clients and they are on the ".1" network, so they're connected via "Out of Home" to the Channels DVR Server in PA. In this configuration I have both tuners in the guide, watchable and recordable, with the Prime being in PA using Xfinity and the Extend using a HI antenna signal. I did have to set the Extend's transcoder to "Mobile" for it to work seamlessly without buffering and the quality is surprisingly good considering it's really being compressed from the original. It's only for news and the occasional backup that the Prime or TVE can't do, so it is worth the advantage of having it.
When Channels uses the Extend tuner, the signal is received by the antenna here in HI, transcoded to its "Mobile" setting, sent through the VPN to the Shield's DVR Server in PA, recorded if needed, sent back out through the VPN in PA, received back here in HI and played back on my AppleTV Clients and I can't believe it goes through ALL that and still looks pretty damned great, especially converted to Dolby Vision/LLDV on an ATV 4K to my LG C8 OLED or BenQ LK990 projector!
