The message from nc is bogus. Just restart the CDVR. The HDHR tuners will be gone.
They certainly have. Thanks so much for the pointer.
Last time I deleted them manually with the curl commands after the first iptables command, and they then came back.
But as you said, after using your iptables command a restart was enough to get rid of them this time. Hopefully they will stay away!
I blocked the Port 65001 on Windows but it also blocked the discovery of the DVR ... had to type the IP ... What I proceeded to do was block the channelsDVR program only from using that port.
Just an FYI
Blocking the full port on windows also killed my HDHR DVR and other programs that use that port.
This is one of my major annoyances now with Channels DVR since my servers have to run host mode networking in docker containers. Wasn't an issue when they ran with bridge mode network.
I do not want my HDHR Prime showing up in all my containers and my Synology package install.
I only have one server using it as a source. I do not want to create firewall rules for each docker container and another for the Synology Package install.
Please create a Channels DVR option to ignore/block, un-ignore/un-block HDHR tuners.
Is that why when I created a Docker Container in bridge mode when I try to connect to it using 192.168.50.68:8085 it would not connect ?
The clients all still find the tuners, but directly rather than via the Channels server and it doesn't seem to effect the channel numbers like they do on the server. I'd still prefer an option to ignore them completely on the clients too.
Yeah and the Clients do not tuner Share they just use up tuners. They also seem to ignore tuner priority ...I am going to restore access to 65001 ... causes too many issues.
I have all channels disabled on all tuners and all tuners disabled on all clients. The clients all just use the Custom Sources I created that link directly to the tuners, in my preferred channel numbering, via M3U. As far as I can tell the tuners themselves also being on the source list for every client isn't causing a problem other than a slight annoyance of having them always there unnecessarily.
You are right since I have the M3U already setup disabling the HDHomeRun Channels does not affect being able to tune them. But of course, disabling them in ChannelsDVR also disables them from the webpage and no other apps can us the tuners.
