Thanks. The fix will be available later today
Perfect! Thank you for looking into this!
Try new build
That fixed it! All four of the channels that were having issues are now working!
TVE FOX is back thankyou!
I have had an on-going similar problem for almost a year. My source id Vidgo. Almost every month my Channels Client tells me I'm not authorized to watch FOX News, FOX Business and as many as 50 other channels. The only solution I have found is to go to Channels Settings, remove Vidgo from my sources, then after it has been removed, add it as a new source. Walla, All vidgo channels are accessible again. Obviously, the channels server looses or corrupts the login credentials to some channels within a given source.
This won't fix the problem as it will reoccur, but it does allow you to fairly quickly reset channels so you can watch what you want.
Hope this helps.
Next time this happens can you try going into the rescan menu and click rescan next to fox?
