Hulu live and NFL network stopped working , {Playback Failed} seems this is happening with others too.. Must be a product of TVE
RE: NFL Network gone
I decided since I've had some wicked crashes to try to reinstall from latest stable version manually and then update to latest. Interestingly, I uploaded stable (MyCloudPR2100_OS5_ChannelsDVR_1.0.7.bin) and then went to re-add NFL Network. It spun for awhile but re-authenticated NFL Network without uploading to your fixed version and it worked as is.
EDIT: I updated to 2021.09.17.0006 and NFL Network didn't work after update. Did a rescan and it's now working again. Looks like I am good to go!
Latest logs:
f4cc599f-399a-4049-84ca-23135d555e87
150d90d0-4ec4-4b7f-9fc0-92e3ba13e700
I have the same problem with HULU Live login. Tried upgrading to the latest DVR Prerelease and rescanning the NFL channel. It gave me a "Content Deadline Exceeded" error. I am able to login (using my HULU login) and watch from the NFL website.
Fwiw, NFL Network is working for me with slingtv and v2021.09.17.0006, but I had to rescan for the channel in the lineup.
