Non-Docker source for PlutoTV m3u playlists and EPG
Have you just tried using another DNS? There are many alternatives that may perform better than your Internet provider's, for free.
I'm not sure if your math includes this, but FWIW, your Plan B still requires you to have a $65+ internet subscription. Seems obvious, but I'm just making sure you're comparing apples to apples before making a decision!
That is the $70 for GB fiber Internet mentioned at the start of the "Dropping U-Verse" paragraph which makes the maximum savings be $200 instead of $270.
All streaming has this issue including Channels DVR unless you only use OTA and the HRHD box can provide the channel guides from the OTA channels (I don't know if it can do this since I don't have one).
This topic should probably be split, I don't think it has to do with nocords in particular. It seems a DNS issue on your network/host.
In any case, 267 milliseconds to a localhost nameserver is quite high, even considering this answer not being from cache - and esp. considering your low latency ping. mine returns in 4ms uncached and 0ms cached. Obviously Channels shouldn't time out at <=267ms, but it points to a place to investigate.
Can you run this command again, at least twice, so that the 2nd answer should come from cache? is 267ms a rather constant response time? Does it get even higher?
assuming any firewalls are configured to allow dns responses from the internet:
After doing that, try dig +trace nocords.xyz | grep Received. The response times that the dig client gets from the name servers are interesting.
Then, try dig +norecurse @ingrid.ns.cloudflare.com nocords.xyz | grep time:. This will ignore your local stuff and get the answer straight from the source. If this answer is fast, the issue is likely how your local nameserver is configured/behaving. I would experiment with not using the localhost nameserver and using your ISP's or Cloudflare's* directly. I don't use Ubuntu (or any systemd) but I think this blog or this thread is a good place to start.
With my /etc/hosts hack I get:
~$ dig +trace nocords.xyz | grep Received
;; Received 28 bytes from 127.0.1.1#53(127.0.1.1) in 2 ms
;; Received 28 bytes from 127.0.1.1#53(127.0.1.1) in 1 ms
~$ dig +norecurse @ingrid.ns.cloudflare.com nocords.xyz | grep time:
;; Query time: 13 msec
This box was available to test Channels DVR. Ubuntu 16.04 is basically out of support, which is fine for what I keep it for -- running Windows virtual machines to support projects I'd worked on before I retired. I need it a couple of times a year to pick up a small side gig. I'm not spending anymore time trying to fix an old box, my /etc/hosts solution will let be use it enough during the free trial to see if it is a viable solution for us and worth $8/month. I'm close to considering $8 a month worth it for the automatic commercial skip, my wife however is confused by the whole thing and her eyes glaze over when I try to explain it.
On my i9 Ubuntu 22.04 box doing this gets:
;; Received 503 bytes from 127.0.0.53#53(127.0.0.53) in 8 ms
;; Received 667 bytes from 199.7.83.42#53(l.root-servers.net) in 24 ms
;; Received 609 bytes from 212.18.248.42#53(z.nic.xyz) in 88 ms
;; Received 72 bytes from 108.162.193.225#53(ram.ns.cloudflare.com) in 12 ms
So clearly something with the old 16.04 box is fubar. My point is if the Channels DVR DNS timeout was adjustable in the settings this issue would never come up. Who cares about a 5 second delay updating the program guide once a day?
Personally, I turned OFF automatic skip a long time ago, when it consistently skipped way too much show. Very few shows mark commercials properly and perfectly. Though, some do, but not enough to leave autoskip running for me.
The Britbox Mysteries channel guide data has had an issue since 1 Feb. Any ideas how I can resolve the following issue?
The Britbox Mysteries stopped displaying season/episode numbers and it will not tell me if I recorded the episode already. Also, some programs received a new Series ID, so now I have 3 Series IDs for the same program. One recorded OTA, and two from PlutoTV.
I'm sure that nocords is just pulling the data from PlutoTV, so is there some way I can tell ChannelsDVR to reassign the Series ID and look up the episode name to correlate to the season and episode number? Thanks.
As you found, the issue is the Pluto guide data (not great) and they have their own unique series ID's.
The only way to match them up with Channels DVR guide data and recordings is to move the Pluto recordings into local content import and import them. That won't help future recording from Pluto though.
I tried it once and gave up.
Thanks.
I guess this is a case of “you get what you pay for” LOL
This is why I map Pluto channels with the guide from Channels to avoid stuff like this. It is a cluster to deal with. Only other method is to use tmm or filebot to deal with the mess...
Understood, I was hoping one of the devs had a script to rectify the guide issue.
When I try to setup the custom source, I'm getting "invalid source url: no channels found in m3u" with https://nocords.xyz/stirr/playlist.m3u.
I don't have this problem pulling the Pluto list, only STIRR.
Any help is appreciated.
That's because there are no channels listed in that m3u. This is all that's in it.
#EXTM3U
Same with the epg.xml, no program listings in it
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE tv SYSTEM "xmltv.dtd">
<tv generator-info-name="stirr-for-channels" generator-info-url="https://github.com/robbiet480/stirr-for-channels"></tv>
His website https://nocords.xyz/ says there are 31 channels and 0 programs
@HankLloydRight
STIRR's live channels are currently dead, and it was recently acquired by a new company.
Sinclair Confirms Sale of Free Live Streaming Site STIRR to Startup | Cord Cutters News
Wow and that's 2 month old news.
I’ll look into this tomorrow but I suspect it’s what @mjitkop said
I never watched STIRR, but their website isn't showing any guide data, although a few channels stream there. https://stirr.com/live?channel_id=5288
Thanks, Everyone. Chrome Capture will do the job for Comet TV, I suppose.
Comet has its own free stream on channel 6751, assuming you have at least one TV Everywhere source.
Well, the STIRR code on nocords.xyz is based on this repository:
And it has links to the following which aren't really working anymore:
https://ott-stationselection.sinclairstoryline.com/stationAutoSelection
https://ott-gateway-stirr.sinclairstoryline.com/api/rest/v3/channels/stirr
So if @robbiet480 can figure out a way to fix it, I can incorporate those into nocords.xyz.
Just get a free SlingTV account and add it in to Channels and that will get you the free TVE stuff including Comet.
