I see you replied with a new version while I was typing. I'll check it out.
Thank you for the update about the MPV.dll issue. I will look at that and see what options we can do.
I'm going to test the previous mvp today and will have an update pushed as soon as I have time to make sure I have not made any changes that will impact rolling it back. It will probably be after work unless I get things wrapped up early.
I think I accidentally updated to the v3 libmpv-2.dll during my 1.5.3 update. I have verified the file is now the v2 and pushed it as 1.5.8. Let me know if it works. Thanks.
That has solved it! Thank you for taking the time to fix this so quickly!
Awesome.. Sorry I used the v3. I need to write that down somewhere so I don't forget to use the v2 when updating.
