Here is the output:
OliveTin Post-Install Healthcheck
Standard Output
Checking your OliveTin installation...
(extended_check=false)
Checking that your selected Channels DVR server (local-server:8089) is reachable by URL:
HTTP Status: 200 indicates success...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0curl: (6) Could not resolve host: local-server
HTTP Status: 000
Effective URL: http://local-server:8089/
Checking that your selected Channels DVR server's data files (/mnt/local-server-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
total 8
drwxr-xr-x 2 root root 4096 Jul 10 18:59 .
drwxr-xr-x 1 root root 4096 Jul 10 19:53 ..
Checking that your selected Channels DVR server's log files (/mnt/local-server-8089_logs) are accessible:
Folders with the names data and latest should be visible...
total 8
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=local-server:8089
CHANNELS_DVR_ALTERNATES=
CHANNELS_CLIENTS=appletv4k-den firestick-bedroom
ALERT_EMAIL_FROM=[Redacted]@gmail.com
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@[Redacted]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=docker-host
Here's the contents of /etc/resolv.conf from inside the container:
Generated by Docker Engine.
This file can be edited; Docker Engine will not make further changes once it
has been modified.
nameserver 127.0.0.11
search
options ndots:0
Based on host file: '/etc/resolv.conf' (internal resolver)
ExtServers: [192.168.65.7]
Overrides: [search]
Option ndots from: internal
Here's the contents of /etc/hosts from inside the container:
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
172.18.0.3 olivetin
Standard Error
