OTA Interference issues / HDHomeRun support not helpful
The new Flex 4K tuner, it still glitches out signal wise same as the Connect Q did before it died...so at least i know it was not the tuner hardware.
I had a problem with my receptacle where the power plugs in and SD replaced it right away under warranty.
Got replacement Connect Quatro...It came in a Scribe box that was markered out and had stickers on it to say Connect Quatro.
It is quite beat up, scratched etc. For sure well used :frowning_face:
The new, direct from the HDHR store site, Flex 4K came in a plain unmarked white box and i did get that a week sooner.
The i guess "refurbished" Connect i got, i only powered it up and verified I can access its GUI config, then put i back in its box and tossed it in my closet for backup.
I do NOT like getting such poor condition/re-furbished devices back when i have to do an RMA for a mint condition bought brand new device.
Kinda surprised, since they sent me a brand new Prime back when i had one that failed and did RMA for that.
That's disappointing the new Flex didn't solve your problems. I just emailed Silicondust asking if the ATSC 1.0 tuners in the Flex were the same as the Quatro. I have two Quatros and they both work "poorly". I've tried attenuating the strong signals, filtering through an Avant-X, changing cables, etc. yet some tuners on both of them flake out on certain channels after a few minutes. They are NOT overheating - it's about 71 in here at the moment.
I suppose I can get a Flex on Amazon and return it if it, too, is junque.
EDIT: I heard back from a non-techie at Silicondust. They said the LAST batch of Connects used Sony tuners, while earlier versions used MaxLinear. The Flex uses Sony tuners.
I suspect it's more the overall design of the device that matters most.
