Strangely enough, no. My portainer networks now have that gateway.
Are you able to ping and curl to your DVR Server IP address 192.168.4.20 now from the Olivetin bash prompt?
Interestingly, I just rebooted my DSM VM (for the first time), and now the docker bridge gateway address has appeared:
If docker gets installed with Container Manager, perhaps a reboot after installation is recommended?
Perhaps. I installed the package Docker way back on DSM v6
and have just kept updating it. It's now called Container Manager on DSM v7.
I never restart my NAS except when I do a DSM update.
I would think that simply stopping and starting the Container Manager package would be enough.
What would you think about changing the title of this topic split to:
Project One-Click: Need help installing on Synology
This thread has become pretty platform specific.
I think the title of the topic should just be "that @dea321 guy must be some kind of moron".
In other news, I still can't curl or ping the DVR server from olivetin console.
Also, now that it was mentioned, I did reboot my NAS for the first time in months today and that must be when the gateway showed up.
If you have other containers installed, try the same from those containers.
From pluto for channels using /bin/sh
Nope. Can't see it using the pluto for channels console either.
Try this command in that console
netstat -r
I had completely given up on Project-One-Click due to not being able to figure out my communication issue between the container and my host NAS until recently when struggling with a similar issue on a different docker container. Just for posterity, I thought I would mention it here. I found this reddit thread which had the answer in the first response. Basically I just needed to uncheck the option for "Enable Multiple Gateways" on my NAS.
Can someone explain how to get the PORTAINER_TOKEN when running portainer as an extension in windows docker desktop? THX
Pretty sure you have to install the standalone Portainer CE instead of using the extension.
