Provider - AT&T U-verse
Does it work on nbc.com/live in chrome incognito
I'm getting the same error message when I sign-in on nbc.com/live when connected to my home AT&T Fiber connection (which is a separate account/subscription from the U-verse subscription.)
The U-verse logon works for nbc.com/live when I connect through a cellular connection on my mobile device.
Sounds like an auto authentication issue. Nothing we can do about it. You can try contacting ATT support.
Actually, I was able to get it to work. The issue does seem to be related to auto-authentication. When presented with the following screen, I had to click the "Not you? Use a different ID" link.
After putting my logon info into the next screen,
I was able to authenticate.
@tmm1 Is there any chance Channels TVE can be updated to work with the "use different ID" sign-in screen to bypass AT&T auto-authentication?
I agree with this. Unfortunately I can't add my U-Verse credentials due to this issue
I think I've discovered the solution for ATT U-Verse. If the PC that Channels is installed on is connected to the internet through ATT, U-verse will automatically try to authenticate the login based on your network. If you use a different network connection that is not ATT (such as a hotspot from your phone) it will authenticate just fine.
Is anyone receiving this error when trying to authenticate for the first time?
Did you update to the latest prerelease version of Channels DVR?
:man_facepalming:t3:Just did working fine now. Thanks!
34 posts were merged into an existing topic: Experimental: Local Networks (NBC, ABC, FOX) in some major metros via TVE
I'm having the no login form found error for ATT U-verse. Was working fine until last night. I deleted and I am trying to add it again and I'm getting the no login form found issue. I updated to latest pre release and still nothing. I tried going to TV Everywhere to check through U Verse and it works fine. I don't know what else to try.
I'm on U-verse here in Florida and TVE still working.
I just upgraded to the 5/18 pre release and now I get cable provider authentication failed instead of no login form found.
Please submit diagnostics from the new prerelease (Support > Troubleshooting > Submit)
Submitted. 45f7a575-fc70-410f-987a-077fabfa5170
Are you able to login and watch on nbc.com/live ?
Seems like there may be a password issue
I just changed password again and now I was able to login and get my U Verse channels back. So that was it thank you.!
