I agree with almost everything [racameron] stated in his post. COMSKIP is for the most part mostly accurate. Sure, sometimes it does not get the commercials of a particular show. I have had that happen. It is not a big deal to use the fast forward button once in a while. But for the most part COMSKIP works pretty well. CHANNELS is a fabulous solution for cord cutters. For a cost of $80 a year (less than $7 a month) it is a great service. It gives you a two week guide with TVE and great DVR recording options. If you have a problem with paying the minimal cost of $80, the I suggest you find another option for your TV programming and good luck with that. CHANNEL's developer are working very hard to improve the software and respond to customer problems most of which are customer created errors. I should know, because I did it and it was my mistake.
