math 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-331-143839759 at 331 (543.211568) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 000000000101e140] SPS unavailable in decode_picture_timing
Last message repeated 65 times
[h264 @ 000000000101e140] Increasing reorder buffer to 2
[mpegts @ 000000000061c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000061c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000061c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000061c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000061c140] Dropped corrupted packet (stream = 2)
Last message repeated 1 times
2019/09/16 17:02:00 [HLS] Error while serving segment 343 for file40-b07475e013b7: Couldn't open playlist: Z:\Channels\Streaming\m3u8\40\stream.m3u8: open Z:\Channels\Streaming\m3u8\40\stream.m3u8: The process cannot access the file because it is being used by another process.
2019/09/16 17:02:00 [ENC] Stopped encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-331-143839759 after encoding 331 to 341
2019/09/16 17:02:01 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-344-324701938 at 344 (564.149156) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 0000000000e9e140] SPS unavailable in decode_picture_timing
[h264 @ 0000000000e9e140] Increasing reorder buffer to 2
[mpegts @ 0000000000d2c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 0000000000d2c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0000000000d2c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0000000000d2c140] Dropped corrupted packet (stream = 1)
[mpegts @ 0000000000d2c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:03 [ENC] Request for 342 is lower than current start segment of 344
2019/09/16 17:02:03 [ENC] Stopped encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-344-324701938 after starting from 344 without encoding any segments
2019/09/16 17:02:03 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-342-015512134 at 342 (561.813489) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 000000000070e140] SPS unavailable in decode_picture_timing
[h264 @ 000000000070e140] Increasing reorder buffer to 2
[mpegts @ 000000000265c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000265c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000265c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000265c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000265c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:05 [ENC] Encoder stopped for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-342-015512134 after encoding 342 to 343
2019/09/16 17:02:05 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-345-743773914 at 345 (565.233567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 00000000006fe140] SPS unavailable in decode_picture_timing
[h264 @ 00000000006fe140] Increasing reorder buffer to 2
[mpegts @ 00000000026ac140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 00000000026ac140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 00000000026ac140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 00000000026ac140] Dropped corrupted packet (stream = 1)
[mpegts @ 00000000026ac140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:20 [HLS] Pausing transcoder
2019/09/16 17:02:21 [HLS] Error while serving segment 388 for file40-b07475e013b7: Couldn't open playlist: Z:\Channels\Streaming\m3u8\40\stream.m3u8: open Z:\Channels\Streaming\m3u8\40\stream.m3u8: The process cannot access the file because it is being used by another process.
2019/09/16 17:02:21 [HLS] Resuming transcoder
2019/09/16 17:02:21 [ENC] Stopped encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-345-743773914 after encoding 345 to 387
2019/09/16 17:02:22 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-389-319054214 at 389 (653.321567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 000000000071e140] SPS unavailable in decode_picture_timing
[h264 @ 000000000071e140] Increasing reorder buffer to 2
[mpegts @ 000000000262c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000262c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000262c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000262c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000262c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:23 [HLS] Pausing transcoder
2019/09/16 17:02:24 [HLS] Error while serving segment 388 for file40-b07475e013b7: Couldn't open playlist: Z:\Channels\Streaming\m3u8\40\stream.m3u8: open Z:\Channels\Streaming\m3u8\40\stream.m3u8: The process cannot access the file because it is being used by another process.
2019/09/16 17:02:24 [HLS] Resuming transcoder
2019/09/16 17:02:24 [ENC] Stopped encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-389-319054214 after encoding 389 to 389
2019/09/16 17:02:24 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-391-465363994 at 391 (657.325567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 0000000000ffe140] SPS unavailable in decode_picture_timing
[h264 @ 0000000000ffe140] Increasing reorder buffer to 2
2019/09/16 17:02:26 [HLS] Pausing transcoder
2019/09/16 17:02:30 [HLS] Resuming transcoder
2019/09/16 17:02:30 [ENC] Request for 388 is lower than current start segment of 391
2019/09/16 17:02:30 [ENC] Stopped encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-391-465363994 after starting from 391 without encoding any segments
2019/09/16 17:02:30 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-388-219989762 at 388 (651.319567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 0000000000d9e140] SPS unavailable in decode_picture_timing
[h264 @ 0000000000d9e140] Increasing reorder buffer to 2
[mpegts @ 000000000255c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000255c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000255c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000255c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000255c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:32 [ENC] Encoder stopped for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-388-219989762 after starting from 388 without encoding any segments
2019/09/16 17:02:32 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-390-835377494 at 390 (655.323567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 0000000000ece140] SPS unavailable in decode_picture_timing
[h264 @ 0000000000ece140] Increasing reorder buffer to 2
[mpegts @ 000000000268c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000268c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000268c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000268c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000268c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:35 [ENC] Encoder stopped for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-390-835377494 after starting from 390 without encoding any segments
2019/09/16 17:02:35 [ENC] Starting encoder for The Aftermath 2019-09-16 2019-09-16-1651.mpg in Z:\Channels\Streaming\file40-b07475e013b7\encoder-392-829125354 at 392 (659.327567) (encoder=libx264, resolution=480, deinterlacer=blend, bitrate=808 segment_size=1)
[h264 @ 0000000002691b40] SPS unavailable in decode_picture_timing
[h264 @ 0000000002691b40] Increasing reorder buffer to 2
[mpegts @ 000000000266c140] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 000000000266c140] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 000000000266c140] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 000000000266c140] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000266c140] Dropped corrupted packet (stream = 2)
2019/09/16 17:02:38 [HLS] Pausing transcoder
2019/09/16 17:02:42 [HLS] Resuming transcoder
2019/09/16 17:02:43 [HLS] Pausing transcoder
2019/09/16 17:02:46 [HLS] Resuming transcoder
2019/09/16 17:02:47 [HLS] Pausing transcoder
2019/09/16 17:02:47 [HLS] Resuming transcoder
2019/09/16 17:02:50 [HLS] Resuming transcoder
2019/09/16 17:02:50 [HLS] Pausing transcoder
2019/09/16 17:02:51 [HLS] Resuming transcoder
2019/09/16 17:02:52 [HLS] Pausing transcoder
2019/09/16 17:02:54 [HLS] Resuming transcoder
2019/09/16 17:02:54 [HLS] Pausing transcoder
2019/09/16 17:02:56 [HLS] Resuming transcoder
2019/09/16 17:02:56 [HLS] Pausing transcoder
2019/09/16 17:02:58 [HLS] Resuming transcoder
2019/09/16 17:02:58 [HLS] Pausing transcoder
2019/09/16 17:02:59 [HLS] Resuming transcoder
2019/09/16 17:02:59 [HLS] Pausing transcoder
2019/09/16 17:03:01 [M3U8] Generator: err=cannot replace "Z:\Channels\Streaming\m3u8\40\stream.m3u8" with tempfile "Z:\Channels\Streaming\m3u8\40\stream.m3u8466262386": replace Z:\Channels\Streaming\m3u8\40\stream.m3u8466262386 Z:\Channels\Streaming\m3u8\40\stream.m3u8: Access is denied.
2019/09/16 17:03:03 [HLS] Resuming transcoder
2019/09/16 17:03:04 [HLS] Pausing transcoder
2019/09/16 17:03:09 [HLS] Resuming transcoder
2019/09/16 17:03:10 [HLS] Pausing transcoder
2019/09/16 17:03:12 [HLS] Resuming transcoder
2019/09/16 17:03:12 [HLS] Pausing transcoder
2019/09/16 17:03:14 [HLS] Resuming transcoder
2019/09/16 17:03:15 [HLS] Pausing transcoder
2019/09/16 17:03:16 [HLS] Resuming transcoder
2019/09/16 17:03:16 [HLS] Pausing transcoder
2019/09/16 17:03:17 [HLS] Resuming transcoder
2019/09/16 17:03:18 [HLS] Pausing transcoder
2019/09/16 17:03:20 [HLS] Resuming transcoder
2019/09/16 17:03:20 [HLS] Pausing transcoder
2019/09/16 17:03:21 [HLS] Pausing transcoder
2019/09/16 17:03:26 [HLS] Resuming transcoder
2019/09/16 17:03:26 [HLS] Pausing transcoder
2019/09/16 17:03:28 [HLS] Resuming transcoder
2019/09/16 17:03:29 [HLS] Pausing transcoder
2019/09/16 17:03:29 [HLS] Resuming transcoder
2019/09/16 17:03:30 [HLS] Pausing transcoder
2019/09/16 17:03:31 [HLS] Resuming transcoder
2019/09/16 17:03:32 [HLS] Pausing transcoder
2019/09/16 17:03:34 [HLS] Resuming transcoder
2019/09/16 17:03:35 [HLS] Pausing transcoder
2019/09/16 17:03:42 [HLS] Resuming transcoder
2019/09/16 17:03:42 [HLS] Pausing transcoder
2019/09/16 17:03:44 [HLS] Resuming transcoder
2019/09/16 17:03:45 [HLS] Pausing transcoder
2019/09/16 17:03:46 [HLS] Resuming transcoder
2019/09/16 17:03:46 [HLS] Pausing transcoder
2019/09/16 17:03:50 [HLS] Resuming transcoder
2019/09/16 17:03:51 [HLS] Pausing transcoder
2019/09/16 17:03:51 [HLS] Resuming transcoder
2019/09/16 17:03:52 [HLS] Pausing transcoder
Hunk of time in the middle missing from all the logging
