Some recordings are not listed
Another workaround that will allow me to not confuse Plex:
I have temporarily made aliases (Mac) or symlinks (*nix) for the so-called unlisted files in the imports folder.
This allows me to let Channels DVR to do its normal recordings and Plex to scan the normal location.
If any FURTHER files show as unlisted I can simply alias/symlink them until this bug is fixed.
I am at your service to help in any way to permanently resolve this issue.
Followup question: could relocating the library cause something like this?
I first tested Channels DVR using an USB Stick. I subsequently decided to put the library on my main drive (had almost a TB free). I do not recall any issues but I think I did the move more than once for some reason.
QUESTIONS:
  1. Is it possible that during this move that the database scan could have been interrupted or not completed?
  2. If I "pretend" to move it again (IOW, make new storage path to same location) and left it alone while scanning, do you think this would straighten out the database?
There is no database scan. No such scan occurs when you change the dvr path.
Maybe check the Trash tab of the dvr web UI
OK - This matter can be considered closed.
Thanks for all your help and patience.
