@tmm1 this is still occurring at least everyday if not on multiple shows per day. The bulk of the offending shows are from my antenna on ABC network but I’ve seen it happen on other networks too. It happens on both my TiVo stream 4Ks and nowhere else in my house (iPads, iPhones, Apple TV’s).
What can I do to help y’all get this fixed? I put the TiVo logs from a recent occurrence. the common theme I see on my logs when this does occur vs when it doesn’t is the increasing dropped count after I try to seek and it resets to the start of the video and the audio gets out of sync. When I jump forward on other shows that work correctly the dropped count is always zero after the jump forward commands.
[ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.165 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.171 24557 24557 V mpv : seeking by 30.0 from 216.26999999999998
06-14 23:25:32.172 24557 24557 V mpv : command: seek 30.0
06-14 23:25:32.200 24557 24587 V mpv : event: seek
06-14 23:25:32.200 24557 24557 V PlayerActivity: state SEEKING_FORWARD -> SEEKING_FORWARD
06-14 23:25:32.305 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.310 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.374 24557 24557 V mpv : seeking by 30.0 from 246.26999999999998
06-14 23:25:32.374 24557 24557 V mpv : command: seek 30.0
06-14 23:25:32.374 24557 24557 V PlayerActivity: state SEEKING_FORWARD -> SEEKING_FORWARD
06-14 23:25:32.421 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.428 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.515 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.521 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.565 24557 24557 V mpv : seeking by 30.0 from 246.26999999999998
06-14 23:25:32.565 24557 24557 V mpv : command: seek 30.0
06-14 23:25:32.566 24557 24587 V mpv : [lavf] queuing seek to 336.270000
06-14 23:25:32.566 24557 24587 V mpv : [lavf] cached range 0: 57.327633 <-> 63.066700 (bof=0, eof=0)
06-14 23:25:32.566 24557 24587 V mpv : [lavf] cached range 1: 17.220900 <-> 32.456800 (bof=0, eof=0)
06-14 23:25:32.567 24557 24557 V PlayerActivity: state SEEKING_FORWARD -> SEEKING_FORWARD
06-14 23:25:32.624 24557 24587 V mpv : event: seek
06-14 23:25:32.669 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.675 24557 24557 V mpvstats: AV: 336.270 A-V: 0.000 Dropped: 0 Cache: 0.000s + 0KB
06-14 23:25:32.677 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.780 24557 24557 V mpv : seeking by 30.0 from 336.27
06-14 23:25:32.780 24557 24557 V mpv : command: seek 30.0
06-14 23:25:32.781 24557 24557 V PlayerActivity: state SEEKING_FORWARD -> SEEKING_FORWARD
06-14 23:25:32.914 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.921 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:32.925 24557 24587 V mpv : [lavf] queuing seek to 366.270000 (cascade)
06-14 23:25:32.925 24557 24587 V mpv : [lavf] cached range 0: 57.327633 <-> 63.066700 (bof=0, eof=0)
06-14 23:25:32.925 24557 24587 V mpv : [lavf] cached range 1: 17.220900 <-> 32.456800 (bof=0, eof=0)
06-14 23:25:32.988 24557 24587 V mpv : event: seek
06-14 23:25:32.988 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:32.999 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.212 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.225 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.231 24557 24587 V mpv : [lavf] seek done
06-14 23:25:33.231 24557 24587 V mpv : [lavf] execute seek (to 366.342800 flags 4)
06-14 23:25:33.232 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.235 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.331 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.338 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.408 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.416 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.619 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.625 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.713 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.722 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.852 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.856 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:33.945 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:33.949 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.118 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.123 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.217 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.223 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.394 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.399 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.510 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.517 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.601 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.611 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:34.787 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:34.800 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:35.060 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:35.066 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:35.210 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:35.220 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:35.392 24557 24587 D mpv : [ffmpeg] tcp: Starting connection attempt to 192.168.1.145 port 8089
06-14 23:25:35.400 24557 24587 D mpv : [ffmpeg] tcp: Successfully connected to 192.168.1.145 port 8089
06-14 23:25:35.402 24557 24587 V mpv : [lavf] seek done
06-14 23:25:35.473 24557 24587 V mpv : [vd] Decoder format: 1920x1080 mediacodec auto/auto/auto/auto/auto CL=unknown (auto 0.000000/0.000000/0.000000)
06-14 23:25:35.482 24557 24587 V mpv : [cplayer] first video frame after restart shown
06-14 23:25:35.484 24557 24587 V mpv : event: playback-restart
06-14 23:25:35.484 24557 24587 V mpv : [cplayer] playback restart complete @ 0.000000
06-14 23:25:35.484 24557 24557 V PlayerActivity: state SEEKING_FORWARD -> PLAYING
06-14 23:25:35.675 24557 24557 V mpvstats: AV: 0.233 A-V: 0.000 Dropped: 0 Cache: 2.169s + 0KB
06-14 23:25:38.785 24557 24557 V mpvstats: AV: 3.135 A-V: 0.000 Dropped: 2 Cache: 32.232s + 0KB
06-14 23:25:38.888 24557 24557 V mpvstats: AV: 3.269 A-V: 0.000 Dropped: 4 Cache: 33.267s + 0KB
06-14 23:25:40.032 24557 24557 V mpvstats: AV: 4.336 A-V: 0.000 Dropped: 27 Cache: 40.307s + 0KB
06-14 23:25:41.155 24557 24557 V mpvstats: AV: 5.470 A-V: 0.000 Dropped: 50 Cache: 40.240s + 0KB
06-14 23:25:41.580 24557 31447 V ApiServer: REQUEST: GET /log
06-14 23:25:41.885 24557 24557 V mpvstats: AV: 6.137 A-V: 0.000 Dropped: 56 Cache: 40.173s + 0KB
06-14 23:25:42.310 24557 24557 V mpvstats: AV: 6.437 A-V: 0.000 Dropped: 56 Cache: 40.140s + 0KB
06-14 23:25:44.904 24557 24557 V mpvstats: AV: 9.473 A-V: 0.000 Dropped: 56 Cache: 39.907s + 0KB
06-14 23:25:47.944 24557 24557 V mpvstats: AV: 12.441 A-V: 0.000 Dropped: 56 Cache: 39.706s + 0KB
06-14 23:25:49.092 24557 31466 V ApiServer: REQUEST: GET /log
